Using systemd-boot with NixOS, systemd-boot auto-generates an entry for Windows installations on the shared ESP, but that auto-generated entry always appears at the end of the boot menu.
I’ve been creating a custom entry file by hand as a workaround.
Is there an official or recommended way—via NixOS configuration or systemd-boot options—to specify a sort order (or sort key) for auto-generated entries so I can control their position in the menu?
I was using this solution but that only works for manual boot choices, and will create duplicate entries as sd-boot will still create something like auto_windows.
Well, after checking sd-boot’s source code, it seems those “well known” external boot managers are forced written, and could not be modified unless one changes the code.
That’s not really a “solution” lol.
As @truh mentioned you could set the sort key for the nixos entries instead.
Using the same option search I provided.
