The draft PR is here:
Basically the error I get is:
Which I don’t know how to solve. The settings window works and seems functional (thanks to a patch I applied) but I can’t enable the extension at all.
jtojnar
2
Yea I was aware of that, and the patch that fixed it, but I forgot to take the patch correctly (fixed outputs derivations
): https://github.com/EasyScreenCast/EasyScreenCast/pull/276
