Need Help with some Software
Hi there,
I have just moved from Arch to NixOS… still getting used to some things, but I got it pretty much setup so far. There are just two problems I have run into.
The first one is the Vivaldi browser. It is not working and crashes with the following error:
qt.qpa.plugin: Could not find the Qt platform plugin "xcb" in ""
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
[0210/082217.812709:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0210/082217.812946:ERROR:elf_dynamic_array_reader.h(64)] tag not found
[0210/082217.814426:ERROR:process_memory_range.cc(75)] read out of range
Aborted (core dumped)
I noticed in the wiki, that there is an issue with the current build and it suggests that adding
(vivaldi.overrideAttrs
      (oldAttrs: {
        dontWrapQtApps = false;
        dontPatchELF = true;
        nativeBuildInputs = oldAttrs.nativeBuildInputs ++ [pkgs.kdePackages.wrapQtAppsHook];
should fix it… so my config looks like this:
  vim # Do not forget to add an editor to edit configuration.nix! The Nano editor is also installed by default.
  wget
  htop
  gparted
  brave
  vivaldi
        (oldAttrs: {
  lutris
  heroic
I am not sure, if I applied this correctly, but it does not seem to work. Vivaldi is not launching.
In addition, I got another issue. When I try to install KDE AudioTube, I get the following error:
CMake Error at CMakeLists.txt:52 (message):
  QtMultimedia gstreamer backend not found.  AudioTube only works with the
  gstreamer backend.
I have installed gstreamer plugins, but apparently I am unable to find the right one…
Any help would be appreciated.
Cheers
Hello
there you only need vivaldi.ovverrideAttrs… . The package vivaldi should be deleted.
Second:
Which Audio Tube package have you installed?
https://search.nixos.org/packages?channel=unstable&size=50&sort=relevance&type=packages&query=audiotube
This worked. Thank you!
I have switched from stable to unstable… AudioTube works now… I think for now I am all set and I got most of my stuff running again… Cool acually…
Now I gotta look into garbage collection and remove some of the old packages, I installed originally.
Thanks for your help.
