Hi
Still pulling my hair out over this one. It still tries to create /etc/etc and /etc/static/etc
I cannot get it to install tumx either but I have commented it out for the time being.
This is my installation. Can you see anything wrong please.
> bash <(curl -L https://releases.nixos.org/nix/nix-2.14.0/install)
[restart]
> mkdir ~/.config/nix
> echo "experimental-features = nix-command flakes" >> ~/.config/nix/nix.conf
> nix build --extra-experimental-features 'nix-command flakes' .#darwinConfigurations.Andrews-MBP.system
> /result/activate
setting up /Applications/Nix Apps...
setting up pam...
applying patches...
setting up /etc...
ln: failed to create symbolic link '/etc/static/etc': Permission denied
> sudo ./result/activate 198ms X 12:55:38
setting up pam...
applying patches...
setting up /etc...
system defaults...
setting up launchd services...
creating service org.nixos.activate-system
reloading service org.nixos.nix-daemon
reloading nix-daemon...
waiting for nix-daemon
configuring networking...
ln: failed to create symbolic link '/run': Read-only file system
> printf 'run\tprivate/var/run\n' | sudo tee -a /etc/synthetic.conf
> /System/Library/Filesystems/apfs.fs/Contents/Resources/apfs.util -t # For Big Sur and later
> ./result/sw/bin/darwin-rebuild switch --flake .#Andrews-MBP --verbose
flake.nix
description = "Andrews MBP";
nixpkgs.url = "github:nixos/nixpkgs/bf554dabe0b0eb07d9148fedcf67adb9583217b8";
nix-darwin.url = "github:lnl7/nix-darwin/379d42fad6bc5c28f79d5f7ff2fa5f1c90cb7bf8";
nix-darwin.inputs.nixpkgs.follows = "nixpkgs";
home-manager.url = "github:nix-community/home-manager/0e4c33d76006c9080d2f228ba1c2308e3e4d7be6";
home-manager.inputs.nixpkgs.follows = "nixpkgs";
outputs = inputs:
flakeContext = {
inherit inputs;
darwinConfigurations = {
Andrews-MBP = import ./darwinConfigurations/Andrews-MBP.nix flakeContext;
homeConfigurations = {
andrew = import ./homeConfigurations/andrew.nix flakeContext;
{ inputs, ... }@flakeContext:
darwinModule = { config, lib, pkgs, ... }: {
config = {
documentation = {
enable = false;
programs = {
bash = {
zsh = {
# tmux.enable = true;
services = {
nix-daemon = {
users.users.andrew = {
home = "/Users/andrew";
system = {
stateVersion = 4;
inputs.nix-darwin.lib.darwinSystem {
modules = [
darwinModule
system = "aarch64-darwin";
homeModule = { config, lib, pkgs, ... }: {
config = {
home = {
stateVersion = "22.11";
# programs = { # Shell needs to be enabled
nixosModule = { ... }: {
home-manager.users.andrew = homeModule;
inputs.home-manager.lib.homeManagerConfiguration {
modules = [
homeModule
pkgs = inputs.nixpkgs.legacyPackages.aarch64-darwin;
) // { inherit nixosModule; }
this is the ./result/activate script it produced
cat ./result/activate
#! /nix/store/z1yy2vigwp1ggvyizskwil61rjhsbxjf-bash-5.1-p16/bin/bash
set -e
set -o pipefail
export PATH="/nix/store/yplkfzn4wnjcyvc37m1iyd4din2kzwz3-gnugrep-3.7/bin:/nix/store/pi5gzs3772xp6mnlmq96kw36z0jl4nbw-coreutils-9.1/bin:/nix/store/ncfgmsw8dgmjcj35k31dj6cdbgfgjgzn-darwin-system-22.11.20230507.bf554da+darwin4.379d42f/sw/bin:/usr/bin:/bin:/usr/sbin:/sbin"
systemConfig=/nix/store/ncfgmsw8dgmjcj35k31dj6cdbgfgjgzn-darwin-system-22.11.20230507.bf554da+darwin4.379d42f
_status=0
trap "_status=1" ERR
# Ensure a consistent umask.
umask 0022
# Set up applications.
echo "setting up /Applications/Nix Apps..." >&2
ourLink () {
local link
link=$(readlink "$1")
[ -L "$1" ] && [ "${link#*-}" = 'system-applications/Applications' ]
# Clean up for links created at the old location in HOME
if ourLink ~/Applications; then
rm ~/Applications
elif ourLink ~/Applications/'Nix Apps'; then
rm ~/Applications/'Nix Apps'
fi
if [ ! -e '/Applications/Nix Apps' ] \
|| ourLink '/Applications/Nix Apps'; then
ln -sfn /nix/store/3vxs012p38b34qnryxh01vjqpp7wwwf9-system-applications/Applications '/Applications/Nix Apps'
else
echo "warning: /Applications/Nix Apps is not owned by nix-darwin, skipping App linking..." >&2
fi
# PAM settings
echo >&2 "setting up pam..."
# Disable sudo Touch ID authentication, if added by nix-darwin
if grep 'security.pam.enableSudoTouchIdAuth' /etc/pam.d/sudo > /dev/null; then
/nix/store/47i4bgm0rj0vjs3h30v0l5s01yslagni-gnused-4.8/bin/sed -i '/security.pam.enableSudoTouchIdAuth/d' /etc/pam.d/sudo
fi
# Applying patches to /.
echo "applying patches..." >&2
for f in $(ls /run/current-system/patches 2> /dev/null); do
if test ! -e "/nix/store/iw6innlp038km65v2c7sfmql2gzwav2w-patches/patches/$f"; then
patch --reverse --backup -d / -p1 < "/run/current-system/patches/$f" || true
fi
done
# Set up the statically computed bits of /etc.
echo "setting up /etc..." >&2
declare -A etcSha256Hashes
etcSha256Hashes['/etc/bashrc']='444c716ac2ccd9e1e3347858cb08a00d2ea38e8c12fdc5798380dc261e32e9ef 617b39e36fa69270ddbee19ddc072497dbe7ead840cbd442d9f7c22924f116f4 6be16cf7c24a3c6f7ae535c913347a3be39508b3426f5ecd413e636e21031e66'
etcSha256Hashes['/etc/nix/nix.conf']='7c2d80499b39256b03ee9abd3d6258343718306aca8d472c26ac32c9b0949093 19299897fa312d9d32b3c968c2872dd143085aa727140cec51f57c59083e93b9 c4ecc3d541c163c8fcc954ccae6b8cab28c973dc283fea5995c69aaabcdf785f'
etcSha256Hashes['/etc/nix/registry.json']=''
etcSha256Hashes['/etc/ssh/ssh_known_hosts']=''
etcSha256Hashes['/etc/ssl/certs/ca-certificates.crt']=''
etcSha256Hashes['/etc/zprofile']='db8422f92d8cff684e418f2dcffbb98c10fe544b5e8cd588b2009c7fa89559c5 0235d3c1b6cf21e7043fbc98e239ee4bc648048aafaf6be1a94a576300584ef2'
etcSha256Hashes['/etc/zshenv']=''
etcSha256Hashes['/etc/zshrc']='19a2d673ffd47b8bed71c5218ff6617dfc5e8533b240b9ba79142a45f8823c23 fb5827cb4712b7e7932d438067ec4852c8955a9ff0f55e282473684623ebdfa1 c5a00c072c920f46216454978c44df044b2ec6d03409dc492c7bdcd92c94a110 40b0d8751adae5b0100a4f863be5b75613a49f62706427e92604f7e04d2e2261'
ln -sfn "$(readlink -f $systemConfig/etc)" /etc/static
for f in $(find /etc/static/* -type l); do
l=/etc/${f#/etc/static/}
d=${l%/*}
if [ ! -e "$d" ]; then
mkdir -p "$d"
fi
if [ -e "$l" ]; then
if [ "$(readlink "$l")" != "$f" ]; then
if ! grep -q /etc/static "$l"; then
o=$(shasum -a256 "$l")
o=${o%% *}
for h in ${etcSha256Hashes["$l"]}; do
if [ "$o" = "$h" ]; then
mv "$l" "$l.orig"
ln -s "$f" "$l"
break
else
h=
fi
done
if [ -z "$h" ]; then
echo "error: not linking environment.etc.\"${l#/etc/}\" because $l already exists, skipping..." >&2
echo "existing file has unknown content $o, move and activate again to apply" >&2
fi
fi
fi
else
ln -s "$f" "$l"
fi
done
for l in $(find /etc/* -type l 2> /dev/null); do
f="$(echo $l | sed 's,/etc/,/etc/static/,')"
f=/etc/static/${l#/etc/}
if [ "$(readlink "$l")" = "$f" -a ! -e "$(readlink -f "$l")" ]; then
rm "$l"
fi
done
# Set defaults
echo >&2 "system defaults..."
# Set up launchd services in /Library/LaunchAgents and /Library/LaunchDaemons
echo "setting up launchd services..." >&2
if ! diff '/nix/store/w4fkqfm33d05scx5frr4x91yq2g2cjk9-launchd/Library/LaunchDaemons/org.nixos.activate-system.plist' '/Library/LaunchDaemons/org.nixos.activate-system.plist' &> /dev/null; then
if test -f '/Library/LaunchDaemons/org.nixos.activate-system.plist'; then
echo "reloading service $(basename org.nixos.activate-system.plist .plist)" >&2
launchctl unload '/Library/LaunchDaemons/org.nixos.activate-system.plist' || true
else
echo "creating service $(basename org.nixos.activate-system.plist .plist)" >&2
fi
if test -L '/Library/LaunchDaemons/org.nixos.activate-system.plist'; then
rm '/Library/LaunchDaemons/org.nixos.activate-system.plist'
fi
cp -f '/nix/store/w4fkqfm33d05scx5frr4x91yq2g2cjk9-launchd/Library/LaunchDaemons/org.nixos.activate-system.plist' '/Library/LaunchDaemons/org.nixos.activate-system.plist'
launchctl load -w '/Library/LaunchDaemons/org.nixos.activate-system.plist'
fi
if ! diff '/nix/store/w4fkqfm33d05scx5frr4x91yq2g2cjk9-launchd/Library/LaunchDaemons/org.nixos.nix-daemon.plist' '/Library/LaunchDaemons/org.nixos.nix-daemon.plist' &> /dev/null; then
if test -f '/Library/LaunchDaemons/org.nixos.nix-daemon.plist'; then
echo "reloading service $(basename org.nixos.nix-daemon.plist .plist)" >&2
launchctl unload '/Library/LaunchDaemons/org.nixos.nix-daemon.plist' || true
else
echo "creating service $(basename org.nixos.nix-daemon.plist .plist)" >&2
fi
if test -L '/Library/LaunchDaemons/org.nixos.nix-daemon.plist'; then
rm '/Library/LaunchDaemons/org.nixos.nix-daemon.plist'
fi
cp -f '/nix/store/w4fkqfm33d05scx5frr4x91yq2g2cjk9-launchd/Library/LaunchDaemons/org.nixos.nix-daemon.plist' '/Library/LaunchDaemons/org.nixos.nix-daemon.plist'
launchctl load -w '/Library/LaunchDaemons/org.nixos.nix-daemon.plist'
fi
for f in $(ls /run/current-system/Library/LaunchAgents 2> /dev/null); do
if test ! -e "/nix/store/w4fkqfm33d05scx5frr4x91yq2g2cjk9-launchd/Library/LaunchAgents/$f"; then
echo "removing service $(basename $f .plist)" >&2
launchctl unload "/Library/LaunchAgents/$f" || true
if test -e "/Library/LaunchAgents/$f"; then rm -f "/Library/LaunchAgents/$f"; fi
fi
done
for f in $(ls /run/current-system/Library/LaunchDaemons 2> /dev/null); do
if test ! -e "/nix/store/w4fkqfm33d05scx5frr4x91yq2g2cjk9-launchd/Library/LaunchDaemons/$f"; then
launchctl unload "/Library/LaunchDaemons/$f" || true
if test -e "/Library/LaunchDaemons/$f"; then rm -f "/Library/LaunchDaemons/$f"; fi
fi
done
if ! diff /etc/nix/nix.conf /run/current-system/etc/nix/nix.conf &> /dev/null; then
echo "reloading nix-daemon..." >&2
launchctl kill HUP system/org.nixos.nix-daemon
fi
while ! nix-store --store daemon -q --hash /nix/store/z1yy2vigwp1ggvyizskwil61rjhsbxjf-bash-5.1-p16/bin/bash &>/dev/null; do
echo "waiting for nix-daemon" >&2
launchctl kickstart system/org.nixos.nix-daemon
done
echo "configuring networking..." >&2
# Ensure /run exists.
if [ ! -e /run ]; then
ln -sfn private/var/run /run
fi
# Make this configuration the current configuration.
# The readlink is there to ensure that when $systemConfig = /system
# (which is a symlink to the store), /run/current-system is still
# used as a garbage collection root.
ln -sfn "$(readlink -f "$systemConfig")" /run/current-system
# Prevent the current configuration from being garbage-collected.
ln -sfn /run/current-system /nix/var/nix/gcroots/current-system
exit $_status
