figsoda
21
Just released nix-init 0.3.3! Here is the full list of changes:
Changes
- Use
finalAttrs pattern instead of rec
- Drop compatibility with nurl < 0.4
Features
- Rust:
fetchCargoVendor support
- Headless mode
stdenvNoCC.mkDerivation support
- Automatically format with nixfmt if it’s found
- Better license detection
- Rust: emit
LIBGIT2_NO_VENDOR when needed
- Improve error messages
Fixes
- Remove legacy darwin sdk
- Go: drop
-w from default ldflags
- Prefix unstable versions with
0-
fetchCrate now works correctly
- GitHub: sort tags
- Python: fully remove outdated behavior of adding wheel to dependencies
- Normalize homepage URLs
- More consistency with nixfmt formatting
just released v0.3.4 that fixes a crash that happens with github repositories
Changes
- Rust: demote
importCargoLock when suggesting builders
Features
- Rust: improve dependency inference for a few crates
Fixes
- GitHub: fix crash caused by non-total comparison of tags
- Headless: convert pname to kebab case
- Zig: use
zig directly instead of zig.hook
Chores
- Flake: remove dependency on the nurl flake
just released nix-init 0.3.5, thank you @KiaraGrouwstra and @eclairevoyant for your contributions!
Changes
- Set
__structuredAttrs
- Set
strictDeps when needed
Features
- Set
passthru.updateScript for supported fetchers
- Use release page as a fallback for changelogs
- Commit: Add assisted-by trailer
- Rust: force libsqlite3-sys to use pkg-config when needed
Fixes
- Use
wrapGAppsHook3 instead of wrapGAppsHook
