I’m developing a C++ program right now and I’m using cmake to build it. The C++ standard I chose is C++17, so I added
set_target_propreties (mytarget PROPERTIES CXX_STANDARD 17)
to my CMakeLists.txt
. This works, and builds (using a very simple default.nix
using just nativeBuildInputs = [cmake];
, but my emacs doesn’t seem to use these flags to check the code. Can I mitigate that?
