I installed Nixos on my Notebook, however, I am having problems with the Audio Volume, how do I fix it?
Can you provide exact notebook brand type etc?
In My Lenovo P53 and HP env 17 and Lenovo P1 sounds works without any issues.
I use below config in my configuration.nix
pulseaudio = {
support32Bit = true;
package = pkgs.pulseaudioFull;
sound.enable = true;
nixpkgs.config = {
pulseaudio = true;
allowBroken = true;
allowUnfree = true;
Full config for Lenovo P53 you can find
My notebook is Itautec Infoway Note w7430
I already tried this configurations, but it didn’t work. How can i debug it?
Few options to debug
Run in the shell below
Chekh sound kernel module if loaded
lsmod | grep snd
Check dmesg output related to audio
dmesg | grep 'sound\|snd\|audio'
Get more info on audio
aplay -l
lspci | grep -i audio
ls -l /dev/snd/
Check alsamixer volume
alsamixer
Check sound
speaker-test -c 2
Try this:
rm -rf .config/pulse && reboot
