Nixos - HD Audio Controller Starship/Matisse multisound
With me the following sound card is displayed under nixos:
“HD Audio Controller Starship/Matisse”
unfortunately, he only supports stereo at the moment. Is there a way to enable 7.1 channel support?
I use Gnome.
Thanks
Did you find a solution to this?
I’m in the same boat (I can only use Digital Stereo (IC958) Output for Starship/Matisse HD Audio Controller)
