I’ve heard of flake-compat and unflake, but I don’t know how to use them, or if they even solve my issue. I want to use flakes without converting my entire system into a flake. I just learned stable nix and I don’t want to learn flakes.
Is this even possible?
NobbZ
April 13, 2026, 12:55pm
2
You can use flakes without having your system as a flake. The question is, what exactly do you expect from “using flakes”, as they way you want to use them, will change how we introduce them to you.
nix.settings.experimental-features = [ "flakes" "nix-command" ];
in your NixOS config.
But if you don’t want to learn, why use it?
I want to use a specific package that is a flake on Github, from stable nix. In other words, I want to use a flake from Github in my configuration.nix without needing to make a flake.nix.
NobbZ
April 13, 2026, 1:15pm
5
Which one exactly, is the flake really the only way the distribute that package? And is it really only a package you want to consume?
Yes. It’s only a flake, I think. Package is here , in case I’m wrong.
NobbZ
April 13, 2026, 1:31pm
7
You can in theory use the repos package.nix directly.
Though using anything hyprland related from a random repo, while not using hyprland nightly itself, is usually deemed to fail.
I would not recommend mixing a stable channels HL, with some nightly repos plugin.
raboof
April 13, 2026, 1:34pm
8
builtins.getFlake exists, but tbh without Override inputs when using `builtins.getFlake` · Issue #9154 · NixOS/nix · GitHub it doesn’t seem very practical to me.
(note that while the issue is old, there is some recent-ish work on it)
How would I go about doing this?
NobbZ
April 13, 2026, 1:54pm
10
Depends on whether you want to avoid/care for IFD.
But roughly the following should return a package, ready to be installed by whatever means HL plugins or toolings require to be used:
repo = pkgs.fetchFromGitHub {
owner = "WhySoBad";
repo = "hyprland-preview-share-picker";
tag = "…";
hash = "…";
fetchSubmodules = true;
picker = pkgs.callPackage "${repo}/package.nix" {rev = repo.hash;};
This worked thank you so much.
For noobs (like me), put this in like:
{ pkgs, lib, ... }:
owner = "WhySoBad";
rev = "344394a8669fb82ff2744d2780327dd402ffb76a";
hash = "sha256-dreIL3+GfrTxzN5ZoQvLvEc8qFlTs/qwQZjPFJS1eJQ=";
picker = pkgs.callPackage "${repo}/package.nix" {rev = repo.rev;};
# for system-wide nix
picker
# for home-manager
home.packages = with pkgs; [
picker
