Nixos installation with lustrate or iso
Hey everyone,
I’ve been struggling to install nixos the past few days.
First the iso (all the available isos in nix site) won’t work for me, I get errors when trying to mount /dev/root.
Then I tried installing in place using manual: installing from other distro. Everything worked okay but the last step, in which I need to backup boot and run sudo /nix/var/nix/profiles/system/bin/switch-to-configuration boot
This failed saying doesn’t look like efi partition, First I thought maybe I need to change something in my configuration.nix and set the value of boot to boot/efi. Nope same error:
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
	LANGUAGE = (unset),
	LC_ALL = (unset),
	LC_ADDRESS = "cs_CZ.UTF-8",
	LC_NAME = "cs_CZ.UTF-8",
	LC_MONETARY = "cs_CZ.UTF-8",
	LC_PAPER = "cs_CZ.UTF-8",
	LC_IDENTIFICATION = "cs_CZ.UTF-8",
	LC_TELEPHONE = "cs_CZ.UTF-8",
	LC_MEASUREMENT = "cs_CZ.UTF-8",
	LC_TIME = "cs_CZ.UTF-8",
	LC_NUMERIC = "cs_CZ.UTF-8",
	LANG = "en_US.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
updating GRUB 2 menu...
installing the GRUB 2 EFI boot loader into /boot/efi...
Installing for x86_64-efi platform.
/nix/store/vmhdhnp1k4ra0qkvwy824hsxh549jkqd-grub-2.04/sbin/grub-install: error: /boot/efi doesn't look like an EFI partition.
/nix/store/2izvy01l5hwlscc0glwxzrl2lhc8midc-install-grub.pl: installation of GRUB EFI into /boot/efi failed: No such file or directory
my old boot dir
├── efi
│   └── EFI
│       ├── boot
│       ├── Garuda
│       ├── GRUB
│       └── Manjaro
├── grub
│   ├── fonts
│   │   └── unicode.pf2
│   ├── grub-btrfs.cfg
│   ├── grub.cfg
│   ├── grubenv
│   └── themes
│       └── starfield
├── initramfs-linux-lts-fallback.img
├── initramfs-linux-lts.img
├── initramfs-linux-zen-fallback.img
├── initramfs-linux-zen.img
├── intel-ucode.img
├── memtest86+
│   └── memtest.bin
├── vmlinuz-linux-lts
└── vmlinuz-linux-zen
The generate one:
├── converted-font.pf2
└── grub
    └── grub.cfg
Now what I’m doing wrong and did I miss read the manual in some way?
Current Distro: Arch
boot: UEFI
