Edit 2 [issue mostly solved]: It looks like I need to look for the drv name during the build step, then use cat $(nix-store -q --outputs <drvpath>)
to see the file contents I want. I’d still appreciate any comments on a more convenient way to do this. Also, is the symlinking postfix does to /var/lib/postfix
normal? Maybe it only bit me, but it seems dirty and unnecessarily complex.
I’m building a mailserver in NixOS and wanted to use nixos-rebuild build
to preview my outputted configuration files before "switch"ing to them. I can’t get my changes to the nix file to show up in the output! nixos-rebuild switch
does work, but I don’t want to actually switch until I check the output.
If this is just the wrong way of doing what I’m trying to do, I’ll take another way, but at this point I’m also curious why “build” doesn’t seem to work.
Here’s some summarized terminal output from a minimal testcase.
# nixos-rebuild switch
[scintill@nixos:/etc/nixos]$ grep inet_protocols configuration.nix result/etc/postfix/main.cf /etc/postfix/main.cf ; ls -l result/etc/postfix/main.cf
configuration.nix: inet_protocols = "ipv6";
result/etc/postfix/main.cf:inet_protocols = ipv6
lrwxrwxrwx 1 root root 59 Jun 26 00:45 result/etc/postfix/main.cf -> /nix/store/abjppmrwp94lwh71jadh8yndqv8w9nzr-postfix-main.cf
# change configuration.nix (to ipv4)
[scintill@nixos:/etc/nixos]$ nixos-rebuild build
building Nix...
/nix/store/i0kk0cg3wv23aj2y24wpsm7xqm8kiil3-postfix-main.cf.drv
/nix/store/2gam9pfyfa8pzi4mbikn319jxdqrc9ir-unit-script-postfix-pre-start.drv
/nix/store/i1dg5skdilyqrg9nnfqa1gp73ixfyxv1-unit-postfix.service.drv
/nix/store/8dqv3v93n6b7hv9wrr5s76zmb7bzkfxg-system-units.drv
/nix/store/92gcsb32s5ac9w3dyacdi236zlbdw5pk-etc.drv
/nix/store/5yp8ds46bqf61qaxlxbcs2gh4q3y92in-nixos-system-nixos-19.03.172927.30a82bba734.drv
building '/nix/store/i0kk0cg3wv23aj2y24wpsm7xqm8kiil3-postfix-main.cf.drv'...
building '/nix/store/2gam9pfyfa8pzi4mbikn319jxdqrc9ir-unit-script-postfix-pre-start.drv'...
building '/nix/store/i1dg5skdilyqrg9nnfqa1gp73ixfyxv1-unit-postfix.service.drv'...
building '/nix/store/8dqv3v93n6b7hv9wrr5s76zmb7bzkfxg-system-units.drv'...
building '/nix/store/92gcsb32s5ac9w3dyacdi236zlbdw5pk-etc.drv'...
building '/nix/store/5yp8ds46bqf61qaxlxbcs2gh4q3y92in-nixos-system-nixos-19.03.172927.30a82bba734.drv'...
configuration.nix: inet_protocols = "ipv4";
result/etc/postfix/main.cf:inet_protocols = ipv4
lrwxrwxrwx 1 root root 59 Jun 26 00:49 result/etc/postfix/main.cf -> /nix/store/vhpcrhxkg9rwxs48mhp6pncmn25vcisr-postfix-main.cf
It seems noteworthy that the symlink under result/ changes after “switch”, which I would think shouldn’t happen.
This is on the live CD nixos-minimal-19.03.172927.30a82bba734-i686-linux.iso with the following in /etc/nixos/configuration.nix
{ config, pkgs, ... }:
imports = [ <nixpkgs/nixos/modules/installer/cd-dvd/installation-cd-minimal.nix> ];
services.postfix = {
config = {
smtpd_tls_received_header = true;
Any ideas what’s going on? Thanks.
Edit: I think I found a clue:
[scintill@nixos:/etc/nixos]$ ls -l result result/etc result/etc/postfix result/etc/postfix/main.cf
lrwxrwxrwx 1 scintill users 87 Jun 26 00:47 result -> /nix/store/ql5w6dcyq63cjxzawj3krkkcmyhr34yp-nixos-system-nixos-19.03.172927.30a82bba734
lrwxrwxrwx 1 root root 51 Jan 1 1970 result/etc -> /nix/store/917vsg9ywbhf7kqnxr40369cw67y042z-etc/etc
lrwxrwxrwx 1 root root 21 Jan 1 1970 result/etc/postfix -> /var/lib/postfix/conf
result/etc/postfix symlinks to /var/lib/postfix/conf, which I did not expect. Where can I find the nixstore path of the newly built main.cf ?
