NixVim Installation Issue on VMware
Environment
Platform: VMware
Resources: 4 cores, 4GB RAM
OS: NixOS with flake configuration
Problem Description
I’m testing my NixOS flake configuration and encountered an issue where nixvim gets completely stuck after the flake pulls dependencies.
Symptoms
No error messages displayed
100% CPU usage
Process appears frozen/unresponsive
Additional Context
My computer has limited memory, so I cannot determine if this is a memory-related issue. However, I don’t believe nixvim build should require significant memory resources.
Configuration Details
Configuration only enables nixvim (minimal setup)
nix-community cache is enabled (unsure if required)
Workaround Found
The following workaround works successfully:
Temporarily disable nixvim in configuration
Install the base system
Re-enable nixvim after installation
Run
nixos-rebuild
- works normally
Question
Has anyone encountered a similar issue with nixvim during initial flake installation? Any suggestions for resolving this during the initial install process?
