No sound on Headphone Pipewire
hello
Out of nowhere my headset (wireless) is not showing in pavucontrol as an output anymore.
Befor that I had the issue that i could only have it as input or output (not both at the same time) but now suddenly i can only use it as an input.
However my Speakers work fine.
I even tested the headset on my laptop with nixos and the same audio configuration and there it worked.
I have absolutly no idea why it does that.
Pipewire setup as following:
  security.rtkit.enable = true;
  services.pipewire = {
    alsa.enable = true;
    alsa.support32Bit = true;
    pulse.enable = true;
    #jack.enable = true;
    #media-session.enable = true;
nixos: NixOS 25.05.20241229.88195a9 (Warbler) x86_64
pipewire: Compiled with libpipewire 1.2.7
Linked with libpipewire 1.2.7
So a quick update
The option for output is there again. After i left and shut the PC down it “spawned” again.
But unfortunately i still can´t define it as input and output at the same time.
After further investigating the issue (I only could use it as input after reboot) i found out that if I
plug the USB Wireless connector in after the startup I can define it as input or output.
Unfortunately still not as both at the same time
I notice you are using nixOS 25.05, so i’d assume you are also using nixos unstable pkgs.
I was too, had to roll back after a recent channel update completely borked mine as well. Granted mine is an integrated BT chip not a usb plug, but it still registers to the OS and dmesg as a USB device tho so i think it still applies here. This may be the issue you are having.
Does it work if you roll back the channel update?
But the problem that I can only configure it as an input or an output existed before the update.
Fair.
When you say input and output, does this headset have a built in mic?
What’s the model and name of the BT adapter you are using and the headset you are wirelessly connecting?
Also, if your cool with it, dump your dmesg logs, and the last 5,000 lines of your journal to text files and post them here so I can take a look at how it’s talking to system
So I have an roccat elo 7.1 Air which has a build in mic.
The headset does not use Bluetooth.
The Wireless Dongle of the Headset is plugged into a USB 3 Port.
dmesg
[    2.945378] input: Logitech Logitech Extreme 3D as /devices/pci0000:00/0000:00:14.0/usb1/1-7/1-7:1.0/0003:046D:C215.0002/input/input14
[    2.946609] PTP clock support registered
[    2.946735] thermal LNXTHERM:00: registered as thermal_zone0
[    2.946737] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[    2.946770] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[    2.946810] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[    2.948516] mousedev: PS/2 mouse device common for all mice
[    2.949874] i2c i2c-0: Successfully instantiated SPD at 0x51
[    2.950588] i2c i2c-0: Successfully instantiated SPD at 0x53
[    2.966876] Error: Driver 'logitech' is already registered, aborting...
[    2.982123] RAPL PMU: API unit is 2^-32 Joules, 2 fixed counters, 655360 ms ovfl timer
[    2.982126] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[    2.982127] RAPL PMU: hw unit of domain package 2^-14 Joules
[    2.984788] Adding 9810124k swap on /dev/zram0.  Priority:5 extents:1 across:9810124k SSDsc
[    2.987603] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  565.77  Wed Nov 27 23:33:08 UTC 2024
[    2.990146] Bluetooth: Core ver 2.22
[    2.990162] NET: Registered PF_BLUETOOTH protocol family
[    2.990163] Bluetooth: HCI device and connection manager initialized
[    2.990167] Bluetooth: HCI socket layer initialized
[    2.990169] Bluetooth: L2CAP socket layer initialized
[    2.990173] Bluetooth: SCO socket layer initialized
[    2.994326] spd5118 0-0051: DDR5 temperature sensor: vendor 0x06:0x32 revision 1.6
[    2.998898] spd5118 0-0053: DDR5 temperature sensor: vendor 0x06:0x32 revision 1.6
[    3.021153] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[    3.033660] Intel(R) 2.5G Ethernet Linux Driver
[    3.033663] Copyright(c) 2018 Intel Corporation.
[    3.033698] igc 0000:04:00.0: enabling device (0000 -> 0002)
[    3.033706] cryptd: max_cpu_qlen set to 1000
[    3.033900] igc 0000:04:00.0: PCIe PTM not supported by PCIe bus/controller
[    3.034165] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    3.035934] Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    3.036093] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[    3.080830] pps pps0: new PPS source ptp0
[    3.080856] igc 0000:04:00.0 (unnamed net_device) (uninitialized): PHC added
[    3.091678] iTCO_wdt iTCO_wdt: Found a Intel PCH TCO device (Version=6, TCOBASE=0x0400)
[    3.091769] iTCO_wdt iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[    3.092889] AES CTR mode by8 optimization enabled
[    3.094737] nvidia-uvm: Loaded the UVM driver, major device number 235.
[    3.095218] Btrfs loaded, zoned=yes, fsverity=no
[    3.098604] logitech 0003:046D:C215.0002: input,hidraw10: USB HID v1.10 Joystick [Logitech Logitech Extreme 3D] on usb-0000:00:14.0-7/input0
[    3.107673] igc 0000:04:00.0: 4.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x1 link)
[    3.107676] igc 0000:04:00.0 eth0: MAC: 04:7c:16:7a:87:e1
[    3.124858] Creating 1 MTD partitions on "0000:00:1f.5":
[    3.124878] 0x000000000000-0x000002000000 : "BIOS"
[    3.132156] igc 0000:04:00.0 enp4s0: renamed from eth0
[    3.145132] Intel(R) Wireless WiFi driver for Linux
[    3.145183] iwlwifi 0000:00:14.3: enabling device (0000 -> 0002)
[    3.145744] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  565.77  Wed Nov 27 22:53:48 UTC 2024
[    3.146469] usbcore: registered new interface driver btusb
[    3.148710] Error: Driver 'logitech' is already registered, aborting...
[    3.149515] iwlwifi 0000:00:14.3: Detected crf-id 0x400410, cnv-id 0x80401 wfpm id 0x80000020
[    3.149947] iwlwifi 0000:00:14.3: PCI dev 7a70/0094, rev=0x430, rfid=0x2010d000
[    3.149953] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 6E AX211 160MHz
[    3.150618] Bluetooth: hci0: Device revision is 0
[    3.150623] Bluetooth: hci0: Secure boot is enabled
[    3.150625] Bluetooth: hci0: OTP lock is enabled
[    3.150626] Bluetooth: hci0: API lock is enabled
[    3.150627] Bluetooth: hci0: Debug lock is disabled
[    3.150628] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[    3.150631] Bluetooth: hci0: Bootloader timestamp 2019.40 buildtype 1 build 38
[    3.150884] Bluetooth: hci0: DSM reset method type: 0x00
[    3.154668] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[    3.157902] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.2.42
[    3.158398] iwlwifi 0000:00:14.3: loaded firmware version 89.6b44fa0b.0 so-a0-gf-a0-89.ucode op_mode iwlmvm
[    3.158801] Bluetooth: hci0: Found device firmware: intel/ibt-1040-0041.sfi
[    3.158816] Bluetooth: hci0: Boot Address: 0x100800
[    3.158818] Bluetooth: hci0: Firmware Version: 91-33.24
[    3.168580] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[    3.168966] snd_hda_intel 0000:01:00.1: enabling device (0000 -> 0002)
[    3.169074] snd_hda_intel 0000:01:00.1: Disabling MSI
[    3.169086] snd_hda_intel 0000:01:00.1: Handle vga_switcheroo audio client
[    3.170788] usb 1-5.3: 2:1: cannot get freq at ep 0x2
[    3.176738] usb 1-5.3: 3:1: cannot get freq at ep 0x82
[    3.179223] usb 1-5.3: Warning! Unlikely big volume range (=4608), cval->res is probably wrong.
[    3.179226] usb 1-5.3: [2] FU [Mic Capture Volume] ch = 1, val = -4608/0/1
[    3.181219] usb 1-5.3: Warning! Unlikely big volume range (=5632), cval->res is probably wrong.
[    3.181222] usb 1-5.3: [9] FU [Main Configuration Playback Volume] ch = 1, val = -2560/3072/1
[    3.183498] usb 1-5.3: Warning! Unlikely big volume range (=18432), cval->res is probably wrong.
[    3.183501] usb 1-5.3: [6] FU [Speaker Playback Volume] ch = 1, val = -18432/0/1
[    3.183641] usbcore: registered new interface driver snd-usb-audio
[    3.219852] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input15
[    3.219876] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input16
[    3.219892] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input17
[    3.219931] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card2/input18
[    3.243371] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC897: line_outs=4 (0x14/0x15/0x16/0x17/0x0) type:line
[    3.243376] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    3.243378] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[    3.243379] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[    3.243381] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[    3.243382] snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
[    3.243383] snd_hda_codec_realtek hdaudioC1D0:      Front Mic=0x19
[    3.243384] snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
[    3.351785] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1f.3/sound/card1/input19
[    3.351810] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1f.3/sound/card1/input20
[    3.351833] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1f.3/sound/card1/input21
[    3.351855] input: HDA Intel PCH Line Out Front as /devices/pci0000:00/0000:00:1f.3/sound/card1/input22
[    3.351872] input: HDA Intel PCH Line Out Surround as /devices/pci0000:00/0000:00:1f.3/sound/card1/input23
[    3.351887] input: HDA Intel PCH Line Out CLFE as /devices/pci0000:00/0000:00:1f.3/sound/card1/input24
[    3.351900] input: HDA Intel PCH Line Out Side as /devices/pci0000:00/0000:00:1f.3/sound/card1/input25
[    3.351937] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card1/input26
[    3.434671] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
[    3.434681] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[    3.434708] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[    3.434715] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[    3.435086] iwlwifi 0000:00:14.3: loaded PNVM version 16611aa6
[    3.435840] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 5
[    3.452377] iwlwifi 0000:00:14.3: Detected RF GF, rfid=0x2010d000
[    3.520751] iwlwifi 0000:00:14.3: base HW address: 70:d8:23:96:18:79
[    3.548574] iwlwifi 0000:00:14.3 wlo1: renamed from wlan0
[    3.577164] intel_tcc_cooling: Programmable TCC Offset detected
[    3.581386] intel_rapl_msr: PL4 support detected.
[    3.581477] intel_rapl_common: Found RAPL domain package
[    3.581479] intel_rapl_common: Found RAPL domain core
[    3.776796] BTRFS: device label GamesShared devid 1 transid 2178 /dev/nvme1n1p1 (259:5) scanned by mount (959)
[    3.779525] BTRFS info (device nvme1n1p1): first mount of filesystem 539c1881-f64c-4fc2-9d6f-b16e626471df
[    3.779532] BTRFS info (device nvme1n1p1): using crc32c (crc32c-intel) checksum algorithm
[    3.779536] BTRFS info (device nvme1n1p1): using free-space-tree
[    3.780603] EXT4-fs (nvme0n1p3): mounted filesystem d6d98e81-af88-403c-b4bc-286d07d19515 r/w with ordered data mode. Quota mode: none.
[    3.784221] EXT4-fs (sda1): mounted filesystem 21a6a8d5-ad9f-4857-b6b2-720298093b99 r/w with ordered data mode. Quota mode: none.
[    3.812024] [drm] Initialized nvidia-drm 0.0.0 for 0000:01:00.0 on minor 1
[    3.828541] Console: switching to colour dummy device 80x25
[    3.838879] nvidia 0000:01:00.0: vgaarb: deactivate vga console
[    3.856190] fbcon: nvidia-drmdrmfb (fb0) is primary device
[    4.110274] Console: switching to colour frame buffer device 160x45
[    4.111989] nvidia 0000:01:00.0: [drm] fb0: nvidia-drmdrmfb frame buffer device
[    4.132039] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    4.135148] tun: Universal TUN/TAP device driver, 1.6
[    4.137281] loop: module loaded
[    4.154337] Error: Driver 'logitech' is already registered, aborting...
[    4.297778] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    4.297784] Bluetooth: BNEP socket layer initialized
[    4.441350] Bluetooth: hci0: Waiting for firmware download to complete
[    4.442206] Bluetooth: hci0: Firmware loaded in 1253320 usecs
[    4.442225] Bluetooth: hci0: Waiting for device to boot
[    4.458205] Bluetooth: hci0: Device booted in 15613 usecs
[    4.461226] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-1040-0041.ddc
[    4.463248] Bluetooth: hci0: Applying Intel DDC parameters completed
[    4.466229] Bluetooth: hci0: Firmware timestamp 2024.33 buildtype 1 build 81755
[    4.466232] Bluetooth: hci0: Firmware SHA1: 0xd028ffe4
[    4.470266] Bluetooth: hci0: Fseq status: Success (0x00)
[    4.470270] Bluetooth: hci0: Fseq executed: 00.00.02.41
[    4.470274] Bluetooth: hci0: Fseq BT Top: 00.00.02.41
[    4.536382] Bluetooth: MGMT ver 1.23
[    4.539627] NET: Registered PF_ALG protocol family
[    4.612133] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
[    4.612162] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[    4.612192] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[    4.612203] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[    4.613320] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 5
[    4.703903] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 1
[    4.912414] iwlwifi 0000:00:14.3: WFPM_UMAC_PD_NOTIFICATION: 0x20
[    4.912450] iwlwifi 0000:00:14.3: WFPM_LMAC2_PD_NOTIFICATION: 0x1f
[    4.912514] iwlwifi 0000:00:14.3: WFPM_AUTH_KEY_0: 0x90
[    4.912526] iwlwifi 0000:00:14.3: CNVI_SCU_SEQ_DATA_DW9: 0x0
[    4.913526] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 5
[    5.052250] NET: Registered PF_PACKET protocol family
[   11.219949] igc 0000:04:00.0 enp4s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[   12.178483] usb 1-5.3: 3:1: cannot get freq at ep 0x82
[   12.188134] usb 1-5.3: Not enough bandwidth for new device state.
[   12.188140] usb 1-5.3: Not enough bandwidth for altsetting 1
[   12.328376] Bluetooth: RFCOMM TTY layer initialized
[   12.328385] Bluetooth: RFCOMM socket layer initialized
[   12.328389] Bluetooth: RFCOMM ver 1.11
[   14.404011] platform INT3515:01: deferred probe pending: Serial bus multi instantiate pseudo device driver: Error creating i2c-client, idx 0
[   14.485007] x86/split lock detection: #AC: CJobMgr::m_Work/3081 took a split_lock trap at address: 0xed3cd49f
[   14.567641] x86/split lock detection: #AC: CJobMgr::m_Work/3106 took a split_lock trap at address: 0xed3cd49f
[   15.160081] x86/split lock detection: #AC: CJobMgr::m_Work/3243 took a split_lock trap at address: 0xed3cd49f
[   16.329298] x86/split lock detection: #AC: CJobMgr::m_Work/3460 took a split_lock trap at address: 0xed3cd49f
[   16.515389] block nvme0n1: No UUID available providing old NGUID
[   24.127463] systemd-journald[700]: Time jumped backwards, rotating.
[   24.140009] usb 1-5.3: USB disconnect, device number 9
[   28.658528] usb 1-5.3: new full-speed USB device number 11 using xhci_hcd
[   28.735144] usb 1-5.3: config 1 has an invalid interface number: 5 but max is 4
[   28.735152] usb 1-5.3: config 1 has no interface number 4
[   28.735841] usb 1-5.3: New USB device found, idVendor=1e7d, idProduct=3a37, bcdDevice= 1.23
[   28.735845] usb 1-5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[   28.735847] usb 1-5.3: Product: Elo 7.1 Air
[   28.735849] usb 1-5.3: Manufacturer: Turtle Beach
[   28.735851] usb 1-5.3: SerialNumber: 3202FFFF3502
[   28.744739] hid-generic 0003:1E7D:3A37.000C: hiddev100,hidraw8: USB HID v1.11 Device [Turtle Beach Elo 7.1 Air] on usb-0000:00:14.0-5.3/input0
[   28.746489] usb 1-5.3: 2:1: cannot get freq at ep 0x2
[   28.748490] usb 1-5.3: 3:1: cannot get freq at ep 0x82
[   28.750315] usb 1-5.3: Warning! Unlikely big volume range (=4608), cval->res is probably wrong.
[   28.750320] usb 1-5.3: [2] FU [Mic Capture Volume] ch = 1, val = -4608/0/1
[   28.752015] usb 1-5.3: Warning! Unlikely big volume range (=5632), cval->res is probably wrong.
[   28.752023] usb 1-5.3: [9] FU [Main Configuration Playback Volume] ch = 1, val = -2560/3072/1
[   28.753614] usb 1-5.3: Warning! Unlikely big volume range (=18432), cval->res is probably wrong.
[   28.753616] usb 1-5.3: [6] FU [Speaker Playback Volume] ch = 1, val = -18432/0/1
[   28.755272] input: Turtle Beach Elo 7.1 Air as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.5/0003:1E7D:3A37.000D/input/input27
[   28.805565] hid-generic 0003:1E7D:3A37.000D: input,hidraw9: USB HID v1.11 Device [Turtle Beach Elo 7.1 Air] on usb-0000:00:14.0-5.3/input5
[   28.841701] usb 1-5.3: 3:1: cannot get freq at ep 0x82
[   28.850509] usb 1-5.3: Not enough bandwidth for new device state.
[   28.850514] usb 1-5.3: Not enough bandwidth for altsetting 1
[   28.850515] endpoint_set_interface: 70 callbacks suppressed
[   28.850517] usb 1-5.3: 3:1: usb_set_interface failed (-28)
[   28.850861] usb 1-5.3: Not enough bandwidth for new device state.
[   28.850862] usb 1-5.3: Not enough bandwidth for altsetting 1
[   28.850863] usb 1-5.3: 3:1: usb_set_interface failed (-28)
[   28.851209] usb 1-5.3: Not enough bandwidth for new device state.
[   28.851210] usb 1-5.3: Not enough bandwidth for altsetting 1
[   28.851211] usb 1-5.3: 3:1: usb_set_interface failed (-28)
[   28.851586] usb 1-5.3: Not enough bandwidth for new device state.
[   28.851587] usb 1-5.3: Not enough bandwidth for altsetting 1
[   28.851588] usb 1-5.3: 3:1: usb_set_interface failed (-28)
[   28.851956] usb 1-5.3: Not enough bandwidth for new device state.
[   28.851960] usb 1-5.3: Not enough bandwidth for altsetting 1
sadly there is a 32000 charachter limit. So i needed to shorten it a little.
And the journalctl
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) config/udev: Adding input device MSI MYSTIC LIGHT  (/dev/input/event0)
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) No input driver specified, ignoring this device.
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) This device may have been added with another device file.
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) config/udev: Adding input device Logitech G923 Racing Wheel for PlayStation 4 and PC (/dev/input/event1)
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) config/udev: Adding input device Logitech G923 Racing Wheel for PlayStation 4 and PC (/dev/input/js0)
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) config/udev: Adding input device Logitech Gaming Mouse G402 (/dev/input/event6)
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402: Applying InputClass "evdev pointer catchall"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402: Applying InputClass "libinput pointer catchall"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402: Applying InputClass "libinput mouse configuration"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G402'
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402: always reports core events
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "Device" "/dev/input/event6"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) event6  - Logitech Gaming Mouse G402: is tagged by udev as: Mouse
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) event6  - Logitech Gaming Mouse G402: device set to 800 DPI
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) event6  - Logitech Gaming Mouse G402: device is a pointer
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) event6  - Logitech Gaming Mouse G402: device removed
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "AccelProfile" "adaptive"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) libinput: Logitech Gaming Mouse G402: Step value 0 was provided, libinput Fallback acceleration function is used.
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "NaturalScrolling" "off"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "SendEventsMode" "enabled"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "LeftHanded" "off"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "ScrollMethod" "twofinger"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "MiddleEmulation" "on"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "HorizontalScrolling" "on"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.2/1-5.2:1.0/0003:046D:C07E.0008/input/input6/event6"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G402" (type: MOUSE, id 13)
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (EE) libinput: Logitech Gaming Mouse G402: Failed to set scroll to twofinger
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "AccelerationScheme" "none"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402: (accel) selected scheme none/0
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402: (accel) acceleration factor: 2.000
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402: (accel) acceleration threshold: 4
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) config/udev: Adding input device Logitech Gaming Mouse G402 (/dev/input/mouse1)
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) config/udev: Adding input device Logitech Gaming Mouse G402 Keyboard (/dev/input/event7)
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402 Keyboard: Applying InputClass "Keyboard catchall"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402 Keyboard: Applying InputClass "evdev keyboard catchall"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402 Keyboard: Applying InputClass "libinput keyboard catchall"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) Using input driver 'libinput' for 'Logitech Gaming Mouse G402 Keyboard'
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402 Keyboard: always reports core events
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "Device" "/dev/input/event7"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) event7  - Logitech Gaming Mouse G402 Keyboard: is tagged by udev as: Keyboard
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) event7  - Logitech Gaming Mouse G402 Keyboard: device is a keyboard
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) event7  - Logitech Gaming Mouse G402 Keyboard: device removed
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) libinput: Logitech Gaming Mouse G402 Keyboard: needs a virtual subdevice
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.2/1-5.2:1.1/0003:046D:C07E.0009/input/input7/event7"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) XINPUT: Adding extended input device "Logitech Gaming Mouse G402 Keyboard" (type: MOUSE, id 14)
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402 Keyboard: (accel) selected scheme none/0
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402 Keyboard: (accel) acceleration factor: 2.000
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Logitech Gaming Mouse G402 Keyboard: (accel) acceleration threshold: 4
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) config/udev: Adding input device Turtle Beach Elo 7.1 Air (/dev/input/event8)
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Turtle Beach Elo 7.1 Air: Applying InputClass "Keyboard catchall"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Turtle Beach Elo 7.1 Air: Applying InputClass "evdev keyboard catchall"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Turtle Beach Elo 7.1 Air: Applying InputClass "libinput keyboard catchall"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) Using input driver 'libinput' for 'Turtle Beach Elo 7.1 Air'
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Turtle Beach Elo 7.1 Air: always reports core events
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "Device" "/dev/input/event8"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) event8  - Turtle Beach Elo 7.1 Air: is tagged by udev as: Keyboard
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) event8  - Turtle Beach Elo 7.1 Air: device is a keyboard
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) event8  - Turtle Beach Elo 7.1 Air: device removed
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.5/0003:1E7D:3A37.000B/input/input10/event8"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) XINPUT: Adding extended input device "Turtle Beach Elo 7.1 Air" (type: KEYBOARD, id 15)
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "xkb_model" "pc104"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "xkb_layout" "de"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (WW) Option "xkb_variant" requires a string value
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) config/udev: Adding input device Logitech Logitech Extreme 3D (/dev/input/event12)
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) tshort Dactyl-Manuform (5x6) Consumer Control: Applying InputClass "Keyboard catchall"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) tshort Dactyl-Manuform (5x6) Consumer Control: Applying InputClass "evdev keyboard catchall"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) tshort Dactyl-Manuform (5x6) Consumer Control: Applying InputClass "libinput keyboard catchall"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) Using input driver 'libinput' for 'tshort Dactyl-Manuform (5x6) Consumer Control'
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) tshort Dactyl-Manuform (5x6) Consumer Control: always reports core events
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "Device" "/dev/input/event5"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) libinput: tshort Dactyl-Manuform (5x6) Consumer Control: is a virtual subdevice
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-12/1-12:1.1/0003:444D:3536.0007/input/input5/event5"
Jan 08 18:13:12 nixos xserver-wrapper[1904]: (II) XINPUT: Adding extended input device "tshort Dactyl-Manuform (5x6) Consumer Control" (type: KEYBOARD, id 16)
Jan 08 18:13:16 nixos systemd[1]: Created slice Slice /user/1000.
Jan 08 18:13:16 nixos systemd[1]: Starting User Runtime Directory /run/user/1000...
Jan 08 18:13:16 nixos systemd-logind[1179]: New session 2 of user matt.
Jan 08 18:13:16 nixos sddm-helper[1932]: [PAM] Closing session
Jan 08 18:13:16 nixos sddm-helper[1932]: [PAM] Ended.
Jan 08 18:13:16 nixos sddm[1900]: Auth: sddm-helper exited successfully
Jan 08 18:13:16 nixos sddm[1900]: Greeter stopped. SDDM::Auth::HELPER_SUCCESS
Jan 08 18:13:16 nixos systemd[1]: session-c1.scope: Deactivated successfully.
Jan 08 18:13:16 nixos systemd[1]: session-c1.scope: Consumed 340ms CPU time, 138.4M memory peak, 50.2M read from disk, 4K written to disk.
Jan 08 18:13:16 nixos systemd-logind[1179]: Session c1 logged out. Waiting for processes to exit.
Jan 08 18:13:16 nixos systemd-logind[1179]: Removed session c1.
Jan 08 18:13:16 nixos systemd[1]: Finished User Runtime Directory /run/user/1000.
Jan 08 18:13:16 nixos systemd[1]: Starting User Manager for UID 1000...
Jan 08 18:13:16 nixos (systemd)[1967]: pam_unix(systemd-user:session): session opened for user matt(uid=1000) by (uid=0)
Jan 08 18:13:16 nixos systemd-logind[1179]: New session 3 of user matt.
Jan 08 18:13:17 nixos systemd[1967]: Queued start job for default target Main User Target.
Jan 08 18:13:17 nixos systemd[1967]: Created slice User Application Slice.
Jan 08 18:13:17 nixos systemd[1967]: Reached target Paths.
Jan 08 18:13:17 nixos systemd[1967]: Reached target Timers.
Jan 08 18:13:17 nixos systemd[1967]: Starting D-Bus User Message Bus Socket...
Jan 08 18:13:17 nixos systemd[1967]: Listening on PipeWire PulseAudio.
Jan 08 18:13:17 nixos systemd[1967]: Listening on PipeWire Multimedia System Sockets.
Jan 08 18:13:17 nixos systemd[1967]: Listening on D-Bus User Message Bus Socket.
Jan 08 18:13:17 nixos systemd[1967]: Reached target Sockets.
Jan 08 18:13:17 nixos systemd[1967]: Reached target Basic System.
Jan 08 18:13:17 nixos systemd[1]: Started User Manager for UID 1000.
Jan 08 18:13:17 nixos systemd[1967]: Starting Run user-specific NixOS activation...
Jan 08 18:13:17 nixos systemd[1]: Started Session 2 of User matt.
Jan 08 18:13:17 nixos systemd[1967]: Finished Run user-specific NixOS activation.
Jan 08 18:13:17 nixos systemd[1967]: Reached target Main User Target.
Jan 08 18:13:17 nixos systemd[1967]: Startup finished in 154ms.
Jan 08 18:13:17 nixos sddm-helper[1958]: gkr-pam: gnome-keyring-daemon started properly and unlocked keyring
Jan 08 18:13:17 nixos sddm-helper[1958]: Starting Wayland user session: "/nix/store/wyx7j0y0l5hpjhsjps2q47yfi4vsyvj7-sddm-unwrapped-0.21.0/share/sddm/scripts/wayland-session" "Hyprland"
Jan 08 18:13:17 nixos sddm-helper[1985]: Jumping to VT 3
Jan 08 18:13:17 nixos sddm-helper[1985]: VT mode didn't need to be fixed
Jan 08 18:13:17 nixos xserver-wrapper[1904]: (II) event11 - Power Button: device removed
Jan 08 18:13:17 nixos xserver-wrapper[1904]: (II) event10 - Power Button: device removed
Jan 08 18:13:17 nixos xserver-wrapper[1904]: (II) event9  - Sleep Button: device removed
Jan 08 18:13:17 nixos xserver-wrapper[1904]: (II) event2  - tshort Dactyl-Manuform (5x6): device removed
Jan 08 18:13:17 nixos xserver-wrapper[1904]: (II) event3  - tshort Dactyl-Manuform (5x6) Mouse: device removed
Jan 08 18:13:17 nixos xserver-wrapper[1904]: (II) event4  - tshort Dactyl-Manuform (5x6) System Control: device removed
Jan 08 18:13:17 nixos xserver-wrapper[1904]: (II) event6  - Logitech Gaming Mouse G402: device removed
Jan 08 18:13:17 nixos xserver-wrapper[1904]: (II) event8  - Turtle Beach Elo 7.1 Air: device removed
Jan 08 18:13:17 nixos xserver-wrapper[1904]: (II) event5  - tshort Dactyl-Manuform (5x6) Consumer Control: device removed
Jan 08 18:13:17 nixos xserver-wrapper[1904]: (II) event7  - Logitech Gaming Mouse G402 Keyboard: device removed
Jan 08 18:13:18 nixos systemd[1]: Started RealtimeKit Scheduling Policy Service.
Jan 08 18:13:18 nixos systemd[1967]: Started PipeWire Multimedia Service.
Jan 08 18:13:18 nixos wireplumber[2260]: wp-internal-comp-loader: Loading profile 'main'
Jan 08 18:13:18 nixos dbus-daemon[2103]: [session uid=1000 pid=2103] Activating via systemd: service name='org.freedesktop.impl.portal.desktop.hyprland' unit='xdg-desktop-portal-hyprland.service' requested by ':1.8' (uid=1000 pid=2142 comm="/nix/store/wf3kgxaf86gainbbzzwcln8xk4742238-xdg-de")
Jan 08 18:13:18 nixos systemd[1967]: Starting Portal service (Hyprland implementation)...
Jan 08 18:13:18 nixos polkitd[2261]: Started polkitd version 124
Jan 08 18:13:18 nixos dbus-daemon[2103]: [session uid=1000 pid=2103] Successfully activated service 'org.freedesktop.impl.portal.desktop.hyprland'
Jan 08 18:13:18 nixos polkitd[2261]: Loading rules from directory /etc/polkit-1/rules.d
Jan 08 18:13:18 nixos systemd[1967]: Started Portal service (Hyprland implementation).
Jan 08 18:13:18 nixos polkitd[2261]: Loading rules from directory /run/current-system/sw/share/polkit-1/rules.d
Jan 08 18:13:18 nixos polkitd[2261]: Finished loading, compiling and executing 5 rules
Jan 08 18:13:18 nixos dbus-daemon[1116]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Jan 08 18:13:18 nixos polkitd[2261]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Jan 08 18:13:18 nixos systemd[1]: Started Authorization Manager.
Jan 08 18:13:18 nixos dbus-daemon[2103]: [session uid=1000 pid=2103] Successfully activated service 'org.freedesktop.portal.Desktop'
Jan 08 18:13:18 nixos systemd[1967]: Started Portal service.
Jan 08 18:13:18 nixos systemd[1967]: Started PipeWire PulseAudio.
Jan 08 18:13:18 nixos rtkit-daemon[2244]: Successfully made thread 2259 of process 2259 owned by '1000' high priority at nice level -11.
Jan 08 18:13:27 nixos systemd[1]: user@175.service: Deactivated successfully.
Jan 08 18:13:27 nixos systemd[1]: Stopped User Manager for UID 175.
Jan 08 18:13:27 nixos systemd[1]: user@175.service: Consumed 202ms CPU time, 14.3M memory peak, 7.2M read from disk.
Jan 08 18:13:27 nixos systemd[1]: Stopping User Runtime Directory /run/user/175...
Jan 08 18:13:27 nixos systemd[1]: run-user-175.mount: Deactivated successfully.
Jan 08 18:13:27 nixos systemd[1]: user-runtime-dir@175.service: Deactivated successfully.
Jan 08 18:13:27 nixos systemd[1]: Stopped User Runtime Directory /run/user/175.
Jan 08 18:13:27 nixos systemd-logind[1179]: Removed session 1.
Jan 08 18:13:27 nixos pipewire[2259]: pw.node: (alsa_output.usb-Turtle_Beach_Elo_7.1_Air_3202FFFF3502-01.analog-stereo-47) graph xrun not-triggered (0 suppressed)
Jan 08 18:13:27 nixos pipewire[2259]: pw.node: (alsa_output.usb-Turtle_Beach_Elo_7.1_Air_3202FFFF3502-01.analog-stereo-47) xrun state:0x7faa76005008 pending:1/1 s:21127745670 a:21127756446 f:21127768178 waiting:10776 process:11732 status:triggered
Jan 08 18:13:27 nixos pipewire[2259]: pw.node: (alsa_input.pci-0000_00_1f.3.analog-stereo-59) graph xrun not-triggered (0 suppressed)
Jan 08 18:13:27 nixos pipewire[2259]: pw.node: (alsa_input.pci-0000_00_1f.3.analog-stereo-59) xrun state:0x7faa7405b008 pending:1/1 s:21131583339 a:21131604515 f:21131605154 waiting:21176 process:639 status:triggered
Jan 08 18:13:27 nixos assert_20250108181327_34.dmp[3583]: Uploading dump (out-of-process)
Jan 08 18:13:28 nixos assert_20250108181328_37.dmp[3593]: Uploading dump (out-of-process)
Jan 08 18:13:29 nixos assert_20250108181327_34.dmp[3583]: Finished uploading minidump (out-of-process): success = yes
Jan 08 18:13:29 nixos assert_20250108181327_34.dmp[3583]: response: CrashID=bp-a9cb87a8-c3c5-4364-8cc9-3356e2250108
Jan 08 18:13:29 nixos assert_20250108181327_34.dmp[3583]: file ''/tmp/dumps/assert_20250108181327_34.dmp'', upload yes: ''CrashID=bp-a9cb87a8-c3c5-4364-8cc9-3356e2250108''
Jan 08 18:13:30 nixos systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
Jan 08 18:13:30 nixos systemd[1]: NetworkManager-dispatcher.service: Consumed 36ms CPU time, 12.3M memory peak, 7.9M read from disk.
Jan 08 18:13:30 nixos dbus-daemon[1116]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service' requested by ':1.73' (uid=1000 pid=3653 comm="zen")
Jan 08 18:13:30 nixos systemd[1]: Starting Time & Date Service...
Jan 08 18:13:30 nixos systemd-timesyncd[1095]: Network configuration changed, trying to establish connection.
Jan 08 18:13:30 nixos systemd[1]: Started Time & Date Service.
Jan 08 18:13:30 nixos dbus-daemon[1116]: [system] Successfully activated service 'org.freedesktop.timedate1'
Jan 08 18:13:30 nixos assert_20250108181328_37.dmp[3593]: Finished uploading minidump (out-of-process): success = yes
Jan 08 18:13:30 nixos assert_20250108181328_37.dmp[3593]: response: CrashID=bp-9b0521ea-a8a4-4d8f-91b0-3af482250108
Jan 08 18:13:30 nixos assert_20250108181328_37.dmp[3593]: file ''/tmp/dumps/assert_20250108181328_37.dmp'', upload yes: ''CrashID=bp-9b0521ea-a8a4-4d8f-91b0-3af482250108''
Jan 08 18:13:30 nixos rtkit-daemon[2244]: Successfully made thread 3775 of process 3653 owned by '1000' RT at priority 10.
Jan 08 18:13:30 nixos systemd-timesyncd[1095]: Contacted time server [2001:1640:3::3]:123 (2.nixos.pool.ntp.org).
Jan 08 18:13:30 nixos systemd-journald[700]: Time jumped backwards, rotating.
Jan 08 18:13:30 nixos kernel: usb 1-5.3: USB disconnect, device number 9
Jan 08 18:13:30 nixos systemd-timesyncd[1095]: Initial clock synchronization to Wed 2025-01-08 18:13:30.184582 CET.
Jan 08 18:13:30 nixos xserver-wrapper[1904]: (II) config/udev: removing device Turtle Beach Elo 7.1 Air
Jan 08 18:13:30 nixos xserver-wrapper[1904]: (II) UnloadModule: "libinput"
Jan 08 18:13:30 nixos acpid[1107]: input device has been disconnected, fd 22
Jan 08 18:13:30 nixos pipewire[2259]: spa.alsa: front:0p: snd_pcm_status error: No such device
Jan 08 18:13:30 nixos pipewire[2259]: spa.alsa: front:0p: snd_pcm_drop: No such device
Jan 08 18:13:30 nixos pipewire[2259]: spa.alsa: sw_params: No such device
Jan 08 18:13:30 nixos pipewire[2259]: spa.alsa: swparams: No such device
Jan 08 18:13:30 nixos pipewire[2259]: spa.alsa: front:0p: (0 suppressed) snd_pcm_avail after recover: No such device
Jan 08 18:13:30 nixos pipewire[2259]: spa.alsa: front:0p: close failed: No such device
Jan 08 18:13:34 nixos kernel: usb 1-5.3: new full-speed USB device number 11 using xhci_hcd
Jan 08 18:13:34 nixos kernel: usb 1-5.3: config 1 has an invalid interface number: 5 but max is 4
Jan 08 18:13:34 nixos kernel: usb 1-5.3: config 1 has no interface number 4
Jan 08 18:13:34 nixos kernel: usb 1-5.3: New USB device found, idVendor=1e7d, idProduct=3a37, bcdDevice= 1.23
Jan 08 18:13:34 nixos kernel: usb 1-5.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jan 08 18:13:34 nixos kernel: usb 1-5.3: Product: Elo 7.1 Air
Jan 08 18:13:34 nixos kernel: usb 1-5.3: Manufacturer: Turtle Beach
Jan 08 18:13:34 nixos kernel: usb 1-5.3: SerialNumber: 3202FFFF3502
Jan 08 18:13:34 nixos kernel: hid-generic 0003:1E7D:3A37.000C: hiddev100,hidraw8: USB HID v1.11 Device [Turtle Beach Elo 7.1 Air] on usb-0000:00:14.0-5.3/input0
Jan 08 18:13:34 nixos kernel: usb 1-5.3: 2:1: cannot get freq at ep 0x2
Jan 08 18:13:34 nixos kernel: usb 1-5.3: 3:1: cannot get freq at ep 0x82
Jan 08 18:13:34 nixos kernel: usb 1-5.3: Warning! Unlikely big volume range (=4608), cval->res is probably wrong.
Jan 08 18:13:34 nixos kernel: usb 1-5.3: [2] FU [Mic Capture Volume] ch = 1, val = -4608/0/1
Jan 08 18:13:34 nixos kernel: usb 1-5.3: Warning! Unlikely big volume range (=5632), cval->res is probably wrong.
Jan 08 18:13:34 nixos kernel: usb 1-5.3: [9] FU [Main Configuration Playback Volume] ch = 1, val = -2560/3072/1
Jan 08 18:13:34 nixos kernel: usb 1-5.3: Warning! Unlikely big volume range (=18432), cval->res is probably wrong.
Jan 08 18:13:34 nixos kernel: usb 1-5.3: [6] FU [Speaker Playback Volume] ch = 1, val = -18432/0/1
Jan 08 18:13:34 nixos kernel: input: Turtle Beach Elo 7.1 Air as /devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.5/0003:1E7D:3A37.000D/input/input27
Jan 08 18:13:34 nixos kernel: hid-generic 0003:1E7D:3A37.000D: input,hidraw9: USB HID v1.11 Device [Turtle Beach Elo 7.1 Air] on usb-0000:00:14.0-5.3/input5
Jan 08 18:13:34 nixos mtp-probe[4132]: checking bus 1, device 11: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3"
Jan 08 18:13:34 nixos mtp-probe[4132]: bus: 1, device: 11 was not an MTP device
Jan 08 18:13:34 nixos systemd[1967]: Reached target Sound Card.
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (II) config/udev: Adding input device Turtle Beach Elo 7.1 Air (/dev/input/event8)
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (**) Turtle Beach Elo 7.1 Air: Applying InputClass "Keyboard catchall"
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (**) Turtle Beach Elo 7.1 Air: Applying InputClass "evdev keyboard catchall"
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (**) Turtle Beach Elo 7.1 Air: Applying InputClass "libinput keyboard catchall"
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (II) Using input driver 'libinput' for 'Turtle Beach Elo 7.1 Air'
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (**) Turtle Beach Elo 7.1 Air: always reports core events
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (**) Option "Device" "/dev/input/event8"
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (II) event8  - Turtle Beach Elo 7.1 Air: is tagged by udev as: Keyboard
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (II) event8  - Turtle Beach Elo 7.1 Air: device is a keyboard
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (II) event8  - Turtle Beach Elo 7.1 Air: device removed
Jan 08 18:13:34 nixos mtp-probe[4143]: checking bus 1, device 11: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3"
Jan 08 18:13:34 nixos mtp-probe[4143]: bus: 1, device: 11 was not an MTP device
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5.3/1-5.3:1.5/0003:1E7D:3A37.000D/input/input27/event8"
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (II) XINPUT: Adding extended input device "Turtle Beach Elo 7.1 Air" (type: KEYBOARD, id 15)
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (**) Option "xkb_model" "pc104"
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (**) Option "xkb_layout" "de"
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (WW) Option "xkb_variant" requires a string value
Jan 08 18:13:34 nixos xserver-wrapper[1904]: (**) Option "xkb_options" "terminate:ctrl_alt_bksp"
Jan 08 18:13:34 nixos kernel: usb 1-5.3: Not enough bandwidth for new device state.
Jan 08 18:13:34 nixos kernel: usb 1-5.3: Not enough bandwidth for altsetting 1
Jan 08 18:13:34 nixos kernel: endpoint_set_interface: 70 callbacks suppressed
Jan 08 18:13:34 nixos kernel: usb 1-5.3: 3:1: usb_set_interface failed (-28)
Jan 08 18:13:40 nixos systemd[1]: systemd-hostnamed.service: Deactivated successfully.
Jan 08 18:13:40 nixos systemd[1967]: Started kitty child process: 4209 launched by: 4204.
Jan 08 18:13:41 nixos nix-daemon[1425]: accepted connection from pid 4233, user matt
Jan 08 18:13:42 nixos cupsd[1750]: Saving printers.conf...
Jan 08 18:13:42 nixos cupsd[1750]: Generating printcap /etc/printcap...
Jan 08 18:13:42 nixos cupsd[1750]: Saving subscriptions.conf...
Jan 08 18:14:00 nixos systemd[1]: systemd-timedated.service: Deactivated successfully.
Jan 08 18:14:04 nixos sudo[4433]:     matt : TTY=pts/0 ; PWD=/home/matt ; USER=root ; ENV=TERMINFO=/nix/store/bkvg43qwkc4hiwp6v71nlz14g745y6wg-kitty-0.38.1/lib/kitty/terminfo ; COMMAND=/run/current-system/sw/bin/dmesg
Jan 08 18:14:04 nixos sudo[4433]: pam_unix(sudo:session): session opened for user root(uid=0) by matt(uid=1000)
Jan 08 18:14:04 nixos sudo[4433]: pam_unix(sudo:session): session closed for user root
Jan 08 18:14:18 nixos systemd-coredump[4502]: Process 4496 (.spotify-wrappe) of user 1000 terminated abnormally with signal 6/ABRT, processing...
Jan 08 18:14:18 nixos systemd[1]: Created slice Slice /system/systemd-coredump.
Jan 08 18:14:18 nixos systemd[1]: Started Process Core Dump (PID 4502/UID 0).
Jan 08 18:14:18 nixos systemd-coredump[4510]: Process 4503 (.spotify-wrappe) of user 1000 terminated abnormally with signal 6/ABRT, processing...
Jan 08 18:14:18 nixos systemd[1]: Started Process Core Dump (PID 4510/UID 0).
Jan 08 18:14:18 nixos systemd-timesyncd[1095]: Network configuration changed, trying to establish connection.
Jan 08 18:14:18 nixos systemd-timesyncd[1095]: Contacted time server [2001:1640:3::3]:123 (2.nixos.pool.ntp.org).
Jan 08 18:14:18 nixos systemd-coredump[4509]: Process 4496 (.spotify-wrappe) of user 1000 dumped core.
Jan 08 18:14:18 nixos systemd-coredump[4511]: Process 4503 (.spotify-wrappe) of user 1000 dumped core.
Jan 08 18:14:18 nixos systemd[1]: systemd-coredump@0-4502-0.service: Deactivated successfully.
Jan 08 18:14:18 nixos systemd[1]: systemd-coredump@0-4502-0.service: Consumed 170ms CPU time, 129.9M memory peak, 768K read from disk, 4.8M written to disk.
Jan 08 18:14:18 nixos systemd[1]: systemd-coredump@1-4510-0.service: Deactivated successfully.
Jan 08 18:14:18 nixos systemd[1]: systemd-coredump@1-4510-0.service: Consumed 168ms CPU time, 129.7M memory peak, 4.8M written to disk.
Jan 08 18:15:11 nixos systemd[1]: libvirtd.service: Deactivated successfully.
Jan 08 18:15:11 nixos systemd[1]: libvirtd.service: Consumed 396ms CPU time, 136M memory peak, 80.2M read from disk, 180K written to disk.
Jan 08 18:20:53 nixos pipewire[2259]: pw.node: (alsa_input.pci-0000_00_1f.3.analog-stereo-59) graph xrun not-triggered (1 suppressed)
Jan 08 18:20:53 nixos pipewire[2259]: pw.node: (alsa_input.pci-0000_00_1f.3.analog-stereo-59) xrun state:0x7faa7405b008 pending:1/1 s:466963196707 a:466963203662 f:466963204098 waiting:6955 process:436 status:triggered
again not complete because of character limit. If you need more just write it.
Use pastebin:
journalctl:
dmesg
Alright, im seeing stuff in the logs i need some context for.
The dmesg logs and journal both say that the device driver is registered as an input,hidraw9 device but doesnt mention an output device.
Although it does see it as a ‘Headphone’ HID device which is strange.
More thoroughly explain the expected behavior and the actual behavior.
You mentioned pavucontrol, but do you see it as an input and output device only in pavu control? Or could you set the device as an input output in say discord?
EDIT:
Also, when you tested on your other machine, did you use the native BT interface, or the usb dock you are using on this machine?
So expected Behavior:
when using my headset i should be getting audio output to the headset and I should get an input from the headset Mic.
actual Behavior:
I can only get audio to the headset or get an input from the headset mic.
in pavucontrol:
I can set it as an output (as in this picture ) or an input. But not as both like the other one on top. This Option in the dropdown Menu does not exist (could not take a screen shot of the drop down Menu because it closes it self when doing so).
In Discord I can set it as an output when i set it in Pavucontrol as an output. But not as an input in Discord.
Also the other way around.
The Wireless adapter is directly plugged into my mainboard.
The Other Machine is a laptop. There I also used pavucontrol with the exact same configuration as on my PC.
Under the profile section, is there an option to set it analogue stereo duplex? or is that option not present at all?
So no there is not such an option.
There are some lines that are interesting.
and
For some reason its categorized as a keyboard, that is fascinating in a morbid way.
Also, you seem to be having bandwidth limitations over the USB bus, which doesnt make sense if it is indeed plugged into a USB 3 port like you mentioned AND works with a copy paste setup elsewhere.
Although looking at the product specs, it does mention using BT for communication and BT is known for serious bandwidth limitations.
My own BT headphones in fact have the exact same bandwidth problems, it WILL NOT carry a voice signal while delivering audio at 44100hz or 48000hz.
When the mic is activated by any program, It forcefully sets the mode of the headset to ‘handset’ mode which restricts bitrate from 48/44.1khz down to 16khz to make room for the input signal going out from the mic to the PC. I solved for this by simply disabling those functions in pipewire plumbing directly so the handset driver wouldnt get called, which effectively disabled the mic permanently.
This is not your desired outcome, though it does kinda explain why its complaining about bandwidth, it may be trying to load a driver that calls for more bitrate than the bus can handle and it forcefully kicks it out of that mode.
This seems to suggest to me that pipewire isnt loading the correct drivers for proper functionality.
Hmm.
Dump your entire /etc/nixos/configuration.nix file, i need to make some edits to the wireplumbing to see if we can add that functionality back given the bandwidth really shouldnt be a problem
so here is my the audio part of my configuration. The whole would be a bit to long.
{config,pkgs,lib,inputs,...}:
    alsa.enable = true;
But oddly the Headset worked fine before that. It just suddenly did this after I booted up Windows (i did not turn the headset on while being in Windows, but the adapter was plugged in) and rebootet to Linux
That is actually really good context to have, it confirms my modesetting theory actually.
Give me a few to tinker with this a bit
I have some udev rules in my configuration:
  services.udev.extraRules = ''
    ATTR{idVendor}=="046d", ATTR{idProduct}=="c267", RUN+="${pkgs.usb-modeswitch}/bin/usb_modeswitch -v 046d -p  c267 -M 30f8090701010000 -m 03 -r 03"  # udev rule for logitech g923 so it switches from PS Mode to PC mode
  services.udev.packages = [
      (pkgs.writeTextFile {
        name = "50-oculus.rules";
        text = ''
          SUBSYSTEM="usb", ATTR{idVendor}=="2833", ATTR{idProduct}=="0186", MODE="0660" group="plugdev", symlink+="ocuquest%n"
        destination = "/etc/udev/rules.d/50-oculus.rules";
        name = "52-android.rules";
        text = ''
          SUBSYSTEM=="usb", ATTR{idVendor}=="2833", ATTR{idProduct}=="0186", MODE="0666", OWNER=matt;
        destination = "/etc/udev/rules.d/52-android.rules";
however the first one is for my wheel and the second for my vr headset
i love this snip, it is beautiful. Im going to save that
Question, is it possible to pair these headphones directly or do you have to pair through USB?
So I can only pair them trough the usb wireless adapter.
When they are attached to the pc directly trough a usb cable, i can only charge them or (in windows) update them.
