Hi,
I got this warning
WARNING: The script tensorboard is installed in '/nix/store/3nf1fxmrdfkx38jjskgq9x59lv2jjinr-python3.7-tensorboardx/bin' which is not on PATH.
Consider adding this directory to PATH or, if you prefer to suppress this warning, use --no-warn-script-location.
when building
tensorboard-plugin-wit = with pkgs.python37Packages; buildPythonPackage rec {
name = "tensorboard-plugin-wit";
version = "1.6.0.post3";
format = "wheel";
src = builtins.fetchurl {
url = https://files.pythonhosted.org/packages/51/cd/a0c1f9e4582ea64dddf76c1b808b318d01e3b858a51c715bffab1016ecc7/tensorboard_plugin_wit-1.6.0.post3-py3-none-any.whl;
sha256 = "0krxmwfrnl6l5qnpkyszpf9lh85h4yr8pvss419m8rpi8g1lmpqz";
tensorboardx = with pkgs.python37Packages; buildPythonPackage rec {
name = "tensorboardx";
version = "2.2.1";
format = "wheel";
url = https://files.pythonhosted.org/packages/1d/fd/4f3ca1516cbb3713259ef229abd9314bba0077ef6070285dde0dd1ed21b2/tensorboard-2.2.1-py3-none-any.whl;
sha256 = "1hjd9drqs4dynikrgc3x4pilgpbiqxfmxjgkjfg6g1v1hp4jsals";
propagatedBuildInputs = [
absl-py
markdown
numpy
grpcio
werkzeug
google-auth-oauthlib
in a nix-shell.
Am I missing something in some phases in buildPythonPackage
