Nvidia + i3: problems with external monitor change
I have a Thinkpad P50, with nvidia GM107GLM (not my choice). I use NixOs with i3 as wm. I use it sometimes with two monitors connected through display port (in daisy chain) or with a single monitor connected via HDMI. In any case I must connect the external monitors before login. If I detach a monitor and/or attach a new monitor later, some strange things may happen (e.g. still see old monitors as connected, don’t see new monitors, black screen, see only the mouse cursor, …). The solution I found is to log out the user and relogin, but it is not a good one since all programs will close this way. I use lightdm as display manager.
Sometimes (not many times) it happens that when the screen goes blank for inactivity, and I move the mouse to reactivate it, the screen is black, except for polybar which is visible but freezed (the clock time is the reactivation one). In this case also if I try to move to a tty the screen remains frozen.
  • NixOs: 24.11
  • Linux: 6.6.81
  • i3: 4.24
  • nvidia driver: 565.77
I use the following NixOs hardware modules:
imports = with inputs.hardware.nixosModules; [
    common-pc-laptop
    common-pc-laptop-ssd
    lenovo-thinkpad-p50
hardware.nvidia.prime.offload.enable = false;
❯ lspci -vs 01:00.0
01:00.0 VGA compatible controller: NVIDIA Corporation GM107GLM [Quadro M1000M] (rev a2) (prog-if 00 [VGA controller])
	Subsystem: Lenovo Device 2230
	Flags: bus master, fast devsel, latency 0, IRQ 139
	Memory at b2000000 (32-bit, non-prefetchable) [size=16M]
	Memory at a0000000 (64-bit, prefetchable) [size=256M]
	Memory at b0000000 (64-bit, prefetchable) [size=32M]
	I/O ports at 4000 [size=128]
	Expansion ROM at 000c0000 [virtual] [disabled] [size=128K]
	Capabilities: <access denied>
	Kernel driver in use: nvidia
	Kernel modules: nvidiafb, nouveau, nvidia_drm, nvidia
How can I start debugging this?
