Nwg-look installation help
Hi there,
Has anyone been able to get nwg-look running on nixos? I had tried a few of the code snippets I found on github without success.
I am using Hyprland/Wayland. Or if there are any alternatives for dealing with appearance, I am all ears. lxappearence is a nogo for Wayland I believe.
Hey!
I have been exactly where you at. I manged to build nwg-look but found a better way in Nix using home manager.
you can use for example.
 gtk = {
      font.name = "TeX Gyre Adventor 10";
      theme = {
        name = "Juno";
        package = pkgs.juno-theme;
      iconTheme = {
        name = "Papirus-Dark";
        package = pkgs.papirus-icon-theme;
      gtk3.extraConfig = {
      Settings = ''
        gtk-application-prefer-dark-theme=1
      gtk4.extraConfig = {
      Settings = ''
my repo for reference might help you.
Perfect! I’ll try this out. I think this is a better way anyways!
I also got interested in the way you did a bunch of stuff in here. I love the way you themed it all up.
Glad I could help! :pray:
