I get an error while building my config after a small change.
error: infinite recursion encountered
at /nix/store/i0mxmspkbn8bzdz4g71gp441lrpv4r8r-nixpkgs-patched-d471a92/lib/modules.nix:182:21:
I want to install/build a new system without agenix using a hashed password. Afterwards I flip the ncfg.age
option to true and rebuild the system. Now the system uses the agenix protected secrets
In my host/machine’s config I set the option ncfg.age = true;
I think it has something to do with the config.ncfg.age
option.
What could I do to fix this?
Thank you
{ config, lib, pkgs, inputs, ... }:
cfg = config.ncfg;
imports = [
./bluetooth
./network
./nix
./selinux
./shell
./smartd
./ssh
./sshd
./zfs
options.ncfg = {
age = lib.mkEnableOption "Enable age encrypted configurations";
primaryUser.name = lib.mkOption {
default = "myuser";
example = "myuser";
# 'mkpasswd -m sha-512 | xclip'
primaryUser.psswrd-age = lib.mkOption {
default = "passwords/users/myuser";
rootUser.psswrd-age = lib.mkOption {
default = "passwords/users/root";
personal = lib.mkEnableOption "Enable personal configurations";
stateVersion = lib.mkOption {
example = "21.11";
config = {
system.stateVersion = cfg.stateVersion;
home-manager.users = {
"${cfg.primaryUser.name}" = { ... }: {
home.stateVersion = cfg.stateVersion;
"root" = { ... }: {
i18n = {
defaultLocale = "en_IE.UTF-8";
extraLocaleSettings = {
LC_TIME = "en_GB.UTF-8";
console = {
# https://github.com/NixOS/nixpkgs/issues/114698
earlySetup = true; # Sets the font size much earlier in the boot process
colors = [
"f8f8f8"
"a60000"
"005e00"
"813e00"
"0031a9"
"721045"
"00538b"
"282828"
"ffffff"
"972500"
"315b00"
"70480f"
"2544bb"
"8f0075"
"30517f"
"000000"
font = "Lat2-Terminus16";
# font = "ter-v20n"
# keyMap = "us";
# keyMap = "colemak/colemak";
useXkbConfig = true; # Use same config for linux console
services.xserver = {
enable = false; # but still here so we can copy the XKB config to TTYs
xkbVariant = "colemak";
xkbOptions = "caps:super,compose:ralt,shift:both_capslock";
autoRepeatDelay = 300;
autoRepeatInterval = 35;
systemd.services.numLockOnTty = {
serviceConfig = {
ExecStart = lib.mkForce (pkgs.writeShellScript "numLockOnTty" ''
for tty in /dev/tty{1..6}; do
/run/current-system/sw/bin/setleds -D +num < "$tty";
done
security = {
# sudo.enable = false;
sudo.enable = true; # TODO: Can we make the move to doas, should we?
doas = {
extraRules = [
users = [ cfg.primaryUser.name ];
noPass = true;
cmd = "nix-collect-garbage";
runAs = "root";
services.fwupd.enable = true; # firmware update
users = {
mutableUsers = false;
users = {
isNormalUser = true;
home = "/home/${cfg.primaryUser.name}";
uid = 1000;
description = "The primary user account";
extraGroups = [ "systemd-journal" "wheel" ];
passwordFile = config.age.secrets."${cfg.primaryUser.psswrd-age}".path;
root.passwordFile = config.age.secrets."${cfg.rootUser.psswrd-age}".path;
### true builds
# } // lib.optionalAttrs (true) {
### config.ncfg.age doesn't build
} // lib.optionalAttrs (config.ncfg.age) {
age.secrets."passwords/users/${cfg.primaryUser.name}".file = ../../secrets/passwords/users/${cfg.primaryUser.name}.age;
age.secrets."passwords/users/root".file = ../../secrets/passwords/users/root.age;
