How can I guarantee that these will run in order (if possible/necessary)? I know all three of these have systemd units. Is it sufficient / a good idea to override each of the units with systemd ordering directives? (See e.g. this SE issue.)
You can see the dependencies of a service at runtime with systemctl list-dependencies --after container@my-service.service. In this case, it will be ordered after mounts and tmpfiles because it is a service unit and it has the default dependencies of service units described in man systemd.service, which includes After=sysinit.target, which itself is ordered after both local-fs.target and systemd-tmpfiles-setup.service.
Thanks @ElvishJerricco! That guarantees 3 runs after 1 & 2, but is 2 (tmpfiles) guaranteed to run after 1 (mounting)? I don’t see that in the systemd dependency tree using the command you gave.
EDIT: never mind, silly mistake on my part. Configuring it the way I said I did does result in the correct dependency tree.
But when actually booting the system the tmpfiles commands do run before before persistent.mount (the directories are created and then overmounted). How can I fix the ordering?
Weirdly, having rebooted the system several times, I’m unable to reproduce the issue (though I’m certain it happened—I used different directory names in the tmpfiles rules specifically to test for it).
Hello @Invariance-NaN, I was just debugging a very similar issue and noticed this:
Is it possible that you previously had /persistent configured with the "nofail" mount option? That would exclude persistent.mount from local-fs.target (and therefore systemd-tmpfiles-setup.service could have started before /persistent was mounted).
I’m having a similar issue and I think it’s because systemd-tmpfiles-setup.service is not set to run after remote-fs.target so there is no guarantee that tmpfiles are created after NFS (or other) is mounted (although it might happen just by chance).
I have a feeling that ordering systemd-tmpfiles-setup.service after remote-fs.target could be asking for trouble. For example, if some part of NFS needs tmpfiles.d setup, then you have a dependency cycle.
What might be better is to create your own systemd-tmpfiles-setup-mnt-remote.service with a separate config file given on the systemd-tmpfiles command line. I haven’t tried this myself yet though.
