Inside nix-shell --pure -p hello
the CC
variable is set to gcc
on Linux and to clang
on aarch64 Darwin. Where is the logic that decides this? I figured it gets set by stdenv
but with nix-shell -p stdenvNoCC
the result is the same.
nix-shell -p
always uses stdenv
, since it constructs an evironment based on stdenv.mkDerivation
with the supplied packages in buildInputs
Running nix-shell -E 'with import <nixpkgs> {}; stdenvNoCC.mkDerivation { name = "f"; }' --pure
will drop you in a shell without CC
set. The variables are actually set by cc-wrapper
, not stdenv
itself, in pkgs/build-support/cc-wrapper/setup-hook.sh
