Over arching module for configuring home-manager
I am working on a over arching module which encapsulates my home-manager configuration. The goal is to provide a common configuration for machines with just enough options to meet specific needs.
As an example, I want full documentation on my main machines but want to turn documentation off on the firewall. I also want a set of shell aliases on all machines. Here is what I came up with so far.
~/.config/nixpkgs/home.nix:
{ config, pkgs, ... }:
  imports = [ ./mkg ];
  mkg.enable = true;
  mkg.docs.enable = false;
~/.config/nixpkgs/mkg/default.nix:
{ config, lib, pkgs, ... }:
  inherit (lib) types mkOption mkIf mkMerge;
  cfg = config.mkg;
  options.mkg = {
    enable = mkOption {
      type = types.bool;
      default = true;
      description = "Enable profile for mkg.";
    docs.enable = mkOption {
      type = types.bool;
      default = false;
      description = "Whether to install all documentation.";
  config = mkIf cfg.enable (mkMerge [
    (mkIf true {  # AWKWARD
      nixpkgs.config.time.timeZone = "US/Eastern";
      nixpkgs.config.environment = {
        shellAliases = {
    (mkIf cfg.docs.enable {
      nixpkgs.config.documentation = {
        enable = cfg.docs.enable;
        nixos.enable = cfg.docs.enable;
        man.enable = cfg.docs.enable;
One thing that troubles me is the mkIf true I used to make the shell aliases available everywhere. This seems like a code smell to me. How could I do it better?
Does anyone have an example of using a single unified module in this manner to encapsulate their configuration?
The awkward section is better as
        shellAliases = {
I’m surprised that mkg.enable = true provides the exact same result as mkg.enable = false (regardless of the setting of mkg.docs.enable). The same result for all four combinations of true and false for the two attributes suggests that they aren’t being used at all (or are in the wrong place).
$ home-manager build
/nix/store/zc9yrvb46wqj95mgwzcv81cjcc7lsry5-home-manager-generation
