Hi. I’ve been trying to replace the bundled glibc (2.34) from the wrapped gcc 10.3.0 with a newer one (2.35). After days of investigations I’m getting to a point where derivations shown in nix repl
seem to be OK (Gist link below):
stdenv = with pkgs; overrideCC buildPackages.stdenv (wrapCCWith {
cc = buildPackages.gcc10.cc;
libc = glibcPkgs.buildPackages.gcc10.libc;
bintools = glibcPkgs.binutils.override {
libc = glibcPkgs.buildPackages.gcc10.bintools.libc;
The cross compiler:
stdenv.cc.cc = aarch64-unknown-linux-gnu-stage-final-gcc-debug-10.3.0
where I can find the executable aarch64-unknown-linux-gnu-gcc
And the libc:
stdenv.cc.libc = glibc-aarch64-unknown-linux-gnu-2.35-163.drv
However, this setup will confuse CMake setup and result in wrong flags (buildlog_badcc.txt):
-DCMAKE_C_COMPILER=cc
-DCMAKE_CXX_COMPILER=c++
If I add a cmakeFlags
attribute to tell this is a cross-compiling project, it is then having trouble linking the standard C library (buildlog_cmakeFlags.txt).
I have also tried using both gcc
and glibc
from pkgsCross
stdenv = with pkgs; overrideCC pkgsCross.aarch64-multiplatform.stdenv (wrapCCWith {
cc = pkgsCross.aarch64-multiplatform.gcc10.cc;
libc = glibcPkgs.pkgsCross.aarch64-multiplatform.gcc10.libc;
bintools = glibcPkgs.pkgsCross.aarch64-multiplatform.binutils.override {
libc = glibcPkgs.pkgsCross.aarch64-multiplatform.buildPackages.gcc10.bintools.libc;
Unfortunately, gcc10 cannot build in this configuration (buildlog_pkgsCross.txt). What’s the difference between the two different derivations of gcc?
Here is the full (GitHub Gist) including the stripped flake.nix
, default.nix
and build logs. Has anyone run into similar use cases as I do?
Thanks everyone.
