sudo apt install libsoxr-dev is the debian command,
how to install the same lib in nixos
new user to nixos,
Thanks in advance
new user to nixos,
Thanks in advance
You need to install the soxr
package in a development environment for the header files to be available:
# shell.nix
pkgs ? import <nixpkgs> { },
pkgs.mkShell { buildInputs = [ pkgs.soxr ]; }
$ nix-shell
installed soxr package using nix-shell -p soxr
installation is success,
but in runtime got a error - libsoxr-sys
was not found
I couldn’t find that with nix-index:
$ nix-locate libsoxr-sys
You might need to compile that, yourself. I don’t know if it’s part of soxr
, but all I could find is GitHub - lrbalt/libsoxr-sys: Rust raw FFI bindings for libsoxr (resampling library for sounds)
Are you building a Rust application?
yes am building a rust based audio application
