Package requirement for glib not met when trying to install mu4e
I am trying to install mu4e on nixos using the instructions here. When I get to the step to run ./configure, I get the error message
configure: error: Package requirements (glib-2.0 >= 2.50 gobject-2.0 gio-2.0) were not met:
No package 'glib-2.0' found
No package 'gobject-2.0' found
No package 'gio-2.0' found
Consider adjusting the PKG_CONFIG_PATH environment variable if you
installed software in a non-standard prefix.
Alternatively, you may set the environment variables GLIB_CFLAGS
and GLIB_LIBS to avoid the need to call pkg-config.
See the pkg-config man page for more details.
I made sure to install the nixos.glib package, but the error still persists. The version of glib installed by nix is 2.68.2, is this the issue? If so, how would I install 2.0?
Thanks in advance!
We already have mu4e: nixpkgs/default.nix at 9fcf2a8a2cb0f5b78edc8ec7ca877240e7fe3009 · NixOS/nixpkgs · GitHub
If you’ve just cloned the repository, you will need to bring in the dependencies into your session and nix-env or nix-shell are your friends here. This has nothing to do with mu(4e) as such, but just how things work on NixOS:
https://nix.dev/tutorials/declarative-and-reproducible-developer-environments
