If this were the case then tensorflow, pytorch, jaxlib, and every other package on PyPI that ever links against CUDA would be illegal. I am also not a lawyer, but I’m fairly certain that Google/Facebook’s lawyers must have signed off on their distribution.
Relevant thread:
I understand this is around 2 years old but it seems like the issue is still ongoing especially for tensorflowWithCuda. I even tried using https://cuda-maintainers.cachix.org but it still forced a full recompile of everything when setting cudaSupport = true.
I went around it a different way by changing my tensorFlow derivation to use the wheel
mtensorflowWithCuda = buildPythonPackage rec {
pname = "tensorflow";
version = "2.14.1";
format = "wheel";
src = fetchurl {
name = "${pname}-${version}-py3-none-any.whl";
url = "https://files.pythonhosted.org/packages/99/77/4f31cd29cab69ebc344a529df48b91a14543a83b6fb90efbf82db29a34be/tensorflow-2.14.1-cp310-cp310-manylinux_2_17_x86_64.manylinux2014_x86_64.whl";
sha256 = "sha256-mpVcQhZO/011FzLBJ0ykvwWdtgyeI2IJjOHu1xd8P+k=";
nativeBuildInputs = [ pyPkgs.wheel ] ++ lib.optionals stdenv.isLinux [ autoPatchelfHook ];
# tensorflow/tools/pip_package/setup.py
propagatedBuildInputs = with pyPkgs; [
absl-py
# abseil-cpp
astunparse
flatbuffers
gast
google-pasta
grpcio
h5py
keras-preprocessing
numpy
opt-einsum
packaging
# protobuf-python
six
tensorflow-estimator-bin
termcolor
typing-extensions
wrapt
scipy
dm-tree
# No longer in 310 packages, had to be copied
# from upstream's 311 packages
(pyPkgs.callPackage (import ./mldtypes.nix) { })
(pyPkgs.callPackage (import ./keras.nix) { })
] ++ lib.optionals withTensorboard [
tensorboard
# During installation it can't find the deps provided above
# but if we disable this, can assert the module works after
pipInstallFlags = "--no-deps";
postFixup = ''
find $out -type f \( -name '*.so' -or -name '*.so.*' \) | while read lib; do
# addOpenGLRunpath "$lib"
echo [MANUAL] patching $lib
patchelf --set-rpath "${cudatoolkit}/lib64:${cudatoolkit.lib}/lib:${cudnn_8_7}/lib:${nccl}/lib:$(patchelf --print-rpath "$lib")" "$lib"
done
doCheck = false;
I had to override a couple of packages to get specific versions that work with TF 2.14, but it worked ok so far and did not require a full recompile.
I’ve shared this for two reasons
- In case anyone else was still looking for a hacky solution without switching to virtual env and keep a full nix build
- See if we can take advantage of wheels more often to avoid building from source, as great as it would be to have a build script from source, for certain components like this that aren’t cached by Hydra, its infeasible and would be great if we can pull the wheel along with its dependencies (it took me nearly a full day to get to this point, mainly stuck with getting cuda bindings to eventually work)
