kmf
December 16, 2024, 11:23am
1
Here is my current working config.
description = "My system configuration";
# nixpkgs.url = "github:nixos/nixpkgs/nixos-unstable";
nixpkgs-unstable.url = "github:nixos/nixpkgs/nixos-unstable";
nixpkgs.url = "github:nixos/nixpkgs/nixos-24.11";
catppuccin.url = "github:catppuccin/nix";
home-manager = {
url = "github:nix-community/home-manager/release-24.11";
nixvim = {
url = "github:nix-community/nixvim";
outputs =
self,
nixpkgs,
nixpkgs-unstable,
home-manager,
}@inputs:
system = "x86_64-linux";
# nixos - system hostname
nixosConfigurations.oakenshield = nixpkgs.lib.nixosSystem {
specialArgs = {
pkgs = import nixpkgs {
inherit system;
config.allowUnfree = true;
inherit inputs system;
modules = [
./nixos/configuration.nix
inputs.nixvim.nixosModules.nixvim
inputs.catppuccin.nixosModules.catppuccin
nixosConfigurations.rpi4 = nixpkgs.lib.nixosSystem {
specialArgs = {
inherit system;
modules = [
./systems/rpi4/configuration.nix
homeConfigurations.kmf = home-manager.lib.homeManagerConfiguration {
modules = [
./home-manager/home.nix
inputs.catppuccin.homeManagerModules.catppuccin
It works …
I want to add aarch64-linux
How would I modify my code should I use flake-parts
or flake-utils
it’s not very clear?
How would I do it using just Nix
What is the right way?
# not working just an example
system = if hostName == "rpi4" then "aarch64-linux"; else "x86_64-linux";
Setting system
to x86_64-linux
in the let-in for outputs
doesn’t really make sense if not all your nixosConfigurations
are x86_64-linux
. I would move the system let-in to the individual nixosConfigurations
(also note that I changed the system reference in the home-manager configuration):
outputs =
self,
nixpkgs,
nixpkgs-unstable,
home-manager,
}@inputs:
nixosConfigurations.oakenshield = let
in nixpkgs.lib.nixosSystem {
specialArgs = {
inherit system;
modules = [
nixosConfigurations.rpi4 = let
system = "aarch64-linux";
specialArgs = {
inherit system;
modules = [
pkgs = nixpkgs.legacyPackages.x86_64-linux;
modules = [
A couple more points:
can take a system
argument. Then you don’t have to import pkgs
yourself, because nixpkgs.lib.nixosSystem
will automatically import the pkgs
from the input it’s from. This also makes it possible to use the nixpkgs.config
options (which will have no effect if you use an imported pkgs
). There you can set allowUnfree
(nixpkgs.config.allowUnfree = true;
The system
special arg is also superfluous, because pkgs
has the attribute system
, so you can just use pkgs.system
outputs =
self,
nixpkgs,
nixpkgs-unstable,
home-manager,
}@inputs:
inherit system;
specialArgs = {
inherit inputs;
modules = [
({...}: { nixpkgs.config.allowUnfree = true; })
inherit system;
specialArgs = {
inherit inputs;
modules = [
modules = [
(I set nixpkgs.config.allowUnfree
via an “anonymous” module here, but you could obviously do that in any of your existing module files)
Since quite recently I would use nixpkgs.hostPlatform = "x86_64-linux";
This way your main flake can be system agnostic.
I have as well aarch64-linu
and 86_64-linu
in my configs.
If you need the system somewhere you can then refere to it like this:
config,
inputs,
lib,
pkgs,
cfg = config.programs.az-emacs;
unstable = inputs.nixpkgs-unstable.legacyPackages.${pkgs.system};
options = {
programs.az-emacs.enable = lib.mkEnableOption "Enable emacs.";
config = lib.mkIf cfg.enable {
home.packages = [
pkgs.fd
pkgs.multimarkdown
This is the commit I made when I migrated away from the system
variable: Replace system with hostPlatform · Nebucatnetzer/nixos@b92e801 · GitHub
Using hostname in a conditional will make your config unmaintainable very quickly.
And yes as mentioned above passing system
to lib.nixosSystem
is deprecated, and nixpkgs.hostPlatform
is the current method. Passing pkgs
is discouraged as well unless you use readOnlyPkgs
kmf
December 16, 2024, 5:13pm
6
Thanks for answering
I agree, the idea to modular and not hard code anything as far possible
kmf
7
Thanks for this I’ll investigate further.
kmf
December 16, 2024, 5:14pm
8
@edwinistrator thanks for putting in a lot of effort in your answer, I’ll refactor my code.
kmf
December 17, 2024, 8:21am
9
my assumption here is that home-manager will on work on x86_64-linux
Yes. If you also need the home-manager configuration for aarch64-linux
, you should create a separate one with the same config (except pkgs
being for aarch64-linux
, of course). The reason is that the same home-manager configuration with pkgs
for different systems will result in different store paths.
If you can I would use the home-manger module directly in your NixOS configuration, then you don’t have to care about the system in home-manager.
I only have a separate home-manager configuration for an Ubuntu system I have to use at work.
kmf
December 17, 2024, 4:11pm
12
Thanks all it’s working great.
