Hello! I would really appreciate some help with this issue, which involves SCons and DBus.
TL/DR version (detailed context below)
The package, among other stuff, installs a dBus file. It is SCons based. Scons is printing the following error:
Insufficient rights to install the system-wide dbus service file.
Please run the "scons install" command with higher authority.
How can I fix this?
Detailed context
Situation
The situation is there’s a package that stopped working for me around a year ago, which is [ffado-mixer]( nixpkgs/pkgs/os-specific/linux/ffado/default.nix at 25f538306313eae3927264466c70d7001dcea1df · NixOS/nixpkgs · GitHub ).
The issue seems to be it isn’t building its associated DBus service (I directly arrived to that conclussion discussing this wit the main developer).
When I looked into the buiilding logs using nix log I could clearly see that Scons was scanning for some dependencies for this service, not finding them and therefore not building the DBus portion.
I moved one of the dependencies (dbus-cplusplus) from buildInputs into nativeBuildInputs and that error stopped happening, but I got a new one which is still stopping it from building, the one in TL/DR above.
I’m assuming there must be a way to trick SCons into thinking it is inside a normal system and all the privileges it wants are arond, but I don’t know how to do it in this situation.
Derivation
lib,
stdenv,
argp-standalone,
dbus,
dbus_cplusplus,
fetchurl,
glibmm,
libavc1394,
libconfig,
libiec61883,
libraw1394,
libxmlxx3,
libxcb,
xcb-util-cursor,
pkg-config,
python3,
scons,
which,
qt5,
python = python3.withPackages (
pkgs:
with pkgs;
distutils
++ lib.optionals withMixer [
pyqt5
dbus-python
withMixer = true;
stdenv.mkDerivation rec {
pname = "ffado";
version = "2.5.0";
outputs = [
"out"
"bin"
"dev"
src = fetchurl {
url = "http://www.ffado.org/files/libffado-${version}.tgz";
hash = "sha256-JcEtk9U5iPPK+ZZSNu03nxZ6vePqTMYzsTTuYlTYfKE=";
prePatch =
substituteInPlace ./support/tools/ffado-diag.in \
--replace /lib/modules/ "/run/booted-system/kernel-modules/lib/modules/"
# prevent build tools from leaking into closure
substituteInPlace support/tools/SConscript --replace-fail \
'support/tools/ffado-diag --static' \
"echo '"'See `nix-store --query --tree ${placeholder "out"}`.'"'"
+ lib.optionalString (!stdenv.buildPlatform.canExecute stdenv.hostPlatform) ''
# skip the CC sanity check, since that requires invoking cross-compiled binaries during build
substituteInPlace SConstruct \
--replace-fail 'conf.CompilerCheck()' 'True' \
--replace-fail "pkg-config" "$PKG_CONFIG"
substituteInPlace admin/pkgconfig.py \
nativeBuildInputs =
scons
pkg-config
which
dbus
dbus_cplusplus
python
python.pkgs.pyqt5
qt5.wrapQtAppsHook
libxcb
xcb-util-cursor
prefixKey = "PREFIX=";
sconsFlags = [
"CUSTOM_ENV=True" # tell SConstruct to use nixpkgs' CC/CXX/CFLAGS
"DETECT_USERSPACE_ENV=False"
"DEBUG=False"
"ENABLE_ALL=True"
"BUILD_TESTS=True"
"BUILD_MIXER=${if withMixer then "True" else "False"}"
"UDEVDIR=${placeholder "out"}/lib/udev/rules.d"
"PYPKGDIR=${placeholder "out"}/${python.sitePackages}"
"BINDIR=${placeholder "bin"}/bin"
"INCLUDEDIR=${placeholder "dev"}/include"
"PYTHON_INTERPRETER=${python.interpreter}"
buildInputs =
dbus
dbus_cplusplus
glibmm
libavc1394
libconfig
libiec61883
libraw1394
libxmlxx3
python
++ lib.optionals (!stdenv.hostPlatform.isGnu) [
argp-standalone
NIX_LDFLAGS = lib.optionalString (!stdenv.hostPlatform.isGnu) "-largp";
enableParallelBuilding = true;
dontWrapQtApps = true;
strictDeps = true;
preFixup = lib.optionalString withMixer ''
wrapQtApp "$bin/bin/ffado-mixer"
meta = with lib; {
homepage = "http://www.ffado.org";
description = "FireWire audio drivers";
license = licenses.gpl3;
maintainers = with maintainers; [
michojel
platforms = platforms.linux;
System details
- nixos version: 25.11
