I am trying to package some Ada libraries to contribute to the ecosystem on NixOS.
I was starting out with Prettier-Ada, since it only needed one other package (VSS) that is also not in nixpkgs yet.
This is my VSS default.nix for nixpkgs
{ stdenv
, lib
, fetchFromGitHub
, gnat
, gprbuild
stdenv.mkDerivation rec {
pname = "vss";
version = "0.0.1";
src = fetchFromGitHub {
owner = "AdaCore";
repo = "VSS";
rev = "v24.0.0";
sha256 = "sha256-Tgu+0vlfgM6uZo5SwQk6nV67YCGI6VOOj32pHlOtjU0=";
nativeBuildInputs = [
gnat
gprbuild
buildPhase = ''
make build-libs-static
installPhase = ''
PREFIX=$out DESTDIR= make install-libs-static
I ran nix-build $NIXPKGS -A gnatPackages.vss
and it builds and I can see it in my nix store path.
If I try to now to package prettier-ada, which takes in the vss package and gnatcoll-core package I get the following error
error: builder for '/nix/store/fh1qd7p368330cf9b2l48yx0zygcmdrk-prettier-ada-0.0.1.drv' failed with exit code 2;
last 25 log lines:
> Running phase: unpackPhase
> unpacking source archive /nix/store/qh420a79mbwww846kbm2xjbmj2w8xdan-source
> source root is source
> Running phase: patchPhase
> Running phase: updateAutotoolsGnuConfigScriptsPhase
> Running phase: configurePhase
> no configure script, doing nothing
> Running phase: buildPhase
> gprbuild \
> -v \
> -k \
> -XLIBRARY_TYPE=static \
> -XPRETTIER_ADA_LIBRARY_TYPE=static \
> -XPRETTIER_ADA_BUILD_MODE=prod \
> -P prettier_ada.gpr \
> -p \
> -j0 ; \
> ==============Messages for file: /build/source/prettier_ada.gpr
> 6. with "gnatcoll_core";
> >>> imported project file "gnatcoll_core" not found
> gprbuild: "prettier_ada.gpr" processing failed
> make: *** [Makefile:13: lib] Error 5
For full logs, run 'nix log /nix/store/fh1qd7p368330cf9b2l48yx0zygcmdrk-prettier-ada-0.0.1.drv'.
It seems to not find gnatcoll-core and I am assuming also vss
This is prettier-ada’s default.nix
{ stdenv
, lib
, fetchFromGitHub
, gnat
, gprbuild
, gnatcoll-core
, vss
pname = "prettier-ada";
version = "0.0.1";
owner = "AdaCore";
repo = "prettier-ada";
rev = "8fc0463fd3ed92d1e49e72e51d19cf2e43dd5f04";
sha256 = "sha256-cEUbcdry8XhUyM8RsgxefFdLa/Kmb9sKgV1hQ/zKTpY=";
gnat
gprbuild
buildInputs = [
gnatcoll-core
vss
buildPhase = ''
LIBRARY_TYPE=static BUILD_MODE=prod make lib
installPhase = ''
PREFIX=$out LIBRARY_TYPE=static BUILD_MODE=prod make install
I am not sure if I am missing something in the install step for packaging correctly or something else.
