Success!(?) I restarted 3 times and it worked all 3. Logs were still empty though…
This is the config so far
# Enable the KDE Plasma Desktop Environment.
services.displayManager.sddm.enable = true;
services.desktopManager.plasma6.enable = true;
# Test
services.displayManager.sddm.wayland.enable = false;
services.displayManager.ly.enable = false;
great. So it is wayland related.
If you want more infos this is the Github issue.
opened 07:26PM - 13 May 24 UTC
closed 08:28PM - 15 Aug 24 UTC
0.kind: bug
6.topic: nixos
6.topic: qt/kde
### Describe the bug
If kwin is the compositor of sddm you only get a black scr… een after boot. It worked fine before I updated my nixos flake.
### Steps To Reproduce
Steps to reproduce the behavior:
1. Enable sddm like this:
```nix
service.displayManager.sddm = {
wayland = {
compositor = "kwin";
autoNumlock = true;
2. Build config `nixos-rebuild boot`
3. Reboot system
### Expected behavior
The Login screen should appear and `CTRL + F1` - `CTRL + F6` should give an terminal output.
### Additional context
output of `journalctl -b -1 -u display-manager.service`:
```console
Mai 13 21:06:33 Yon systemd[1]: Started Display Manager.
Mai 13 21:06:33 Yon sddm[1545]: Initializing...
Mai 13 21:06:33 Yon sddm[1545]: Starting...
Mai 13 21:06:33 Yon sddm[1545]: Logind interface found
Mai 13 21:06:33 Yon sddm[1545]: Adding new display...
Mai 13 21:06:33 Yon sddm[1545]: Loaded empty theme configuration
Mai 13 21:06:33 Yon sddm[1545]: Using VT 7
Mai 13 21:06:33 Yon sddm[1545]: Display server started.
Mai 13 21:06:33 Yon sddm[1545]: Socket server starting...
Mai 13 21:06:33 Yon sddm[1545]: Socket server started.
Mai 13 21:06:33 Yon sddm[1545]: Loading theme configuration from "/run/current-system/sw/share/sddm/themes/breeze/theme.conf"
Mai 13 21:06:33 Yon sddm[1545]: Greeter starting...
Mai 13 21:06:33 Yon sddm-helper[1550]: Detected locale "C" with character encoding "ANSI_X3.4-1968", which is not UTF-8.
Qt depends on a UTF-8 locale, and has switched to "C.UTF-8" instead.
If this causes problems, reconfigure your locale. See the locale(1) manual
for more information.
Mai 13 21:06:33 Yon sddm-helper[1550]: [PAM] Starting...
Mai 13 21:06:33 Yon sddm-helper[1550]: [PAM] Authenticating...
Mai 13 21:06:33 Yon sddm-helper[1550]: [PAM] returning.
Mai 13 21:06:33 Yon sddm[1545]: Greeter session started successfully
Mai 13 21:06:35 Yon sddm[1545]: Message received from greeter: Connect
Mai 13 21:06:56 Yon sddm[1545]: Error from greeter session: "Process crashed"
Mai 13 21:06:56 Yon sddm[1545]: Auth: sddm-helper (--socket /tmp/sddm-auth-28334843-3453-40d7-b871-f96a6180049c --id 2 --start /nix/store/4vr0hbjmbnmr8k5gv4mdwfvc36csr6pr-sddm-wrapped/bin/sddm-greeter-qt6 --socket /tmp/sddm--UJfsPi --theme /run/current-system/sw/share/sddm/themes/breeze --user sddm --display-server /nix/store/rizf7g8a5w26lxamz1f5d41knd01pivk-kwin-6.0.4.1/bin/kwin_wayland --no-global-shortcuts --no-kactivities --no-lockscreen --locale1 --greeter) crashed (exit code 1)
Mai 13 21:06:56 Yon sddm[1545]: Auth: sddm-helper exited with 1
Mai 13 21:06:56 Yon sddm[1545]: Greeter stopped. SDDM::Auth::HELPER_AUTH_ERROR
Mai 13 21:06:56 Yon systemd[1]: Stopping Display Manager...
Mai 13 21:06:56 Yon sddm[1545]: Signal received: SIGTERM
Mai 13 21:06:56 Yon sddm[1545]: Socket server stopping...
Mai 13 21:06:56 Yon sddm[1545]: Socket server stopped.
Mai 13 21:06:56 Yon systemd[1]: display-manager.service: Deactivated successfully.
Mai 13 21:06:56 Yon systemd[1]: Stopped Display Manager.
### Notify maintainers
@SuperSandro2000
@abbradar
@ttuegel
@k900
### Metadata
```console
[user@system:~]$ nix-shell -p nix-info --run "nix-info -m"
- system: `"x86_64-linux"`
- host os: `Linux 6.8.9, NixOS, 24.05 (Uakari), 24.05.20240512.2057814`
- multi-user?: `yes`
- sandbox: `yes`
- version: `nix-env (Nix) 2.23.0pre20240502_00ca2b05`
- channels(root): `"nixos"`
- nixpkgs: `/nix/store/vsbi6gfwf2bdamw0d0d9xndb1rrxfnbk-source`
Add a :+1: [reaction] to [issues you find important].
[issues you find important]: https://github.com/NixOS/nixpkgs/issues?q=is%3Aissue+is%3Aopen+sort%3Areactions-%2B1-desc
Maybe something with the localisation.
But if it works that is great. No need to run sddm in wayland
Thank you so much for your help and dedication. You’ve solved quite the problem for me.
Which of our posts should I select as solution from this topic?
no problem. The solve is sddm.wayland.enable = false
