Problems in Nix syntax creating VM
I am an absolute beginner using the Nix configuration.
Context: I am interested in the way Nixos makes it possible to create virtual machines. I recently achieved creating VM’s by using Proxmox. Now I want to achieve the same with NixOs.
Therefore I copied the code from the NixOps/Virtualization - NixOS Wiki website.
  machine = {host, port ? 22, name, hostNic, guests ? {}}: {pkgs, lib, ...}@args:
      imports = [ ./baseline.nix ];
      # We still want to be able to boot, adjust as needed based on your setup
      boot = {
        loader = {
          systemd-boot.enable = true;
        kernelParams = [ "nomodeset" ];
      fileSystems = {
          device = "/dev/disk/by-label/${name}-root";
        "/boot" = {
          device = "/dev/disk/by-label/${name}-boot";
      boot.initrd.availableKernelModules = [ "xhci_pci" "ehci_pci" "ahci" "usbhid" "usb_storage" "sd_mod" ];
      # Tell NixOps how to find the machine
      deployment.targetEnv = "none";
      deployment.targetHost = host;
      deployment.targetPort = port;
      networking.privateIPv4 = host;
    # Tell NixOps about the hosts it should manage
    athens = machine {
      host = "192.168.0.2";
      name = "athens";
      hostNic = "enp30s0";
      guests = {
        some-athens-guest = {
          memory = "4"; # GB
          diskSize = "50"; # GB
          mac = "D2:91:69:C0:14:9A";
          ip = "192.168.0.101"; # Ignored, only for personal reference
    rome = machine {
      host = "192.168.0.3";
      name = "rome";
      hostNic = "enp3s0";
When I entered the command nixos rebuild switch, the following error message appeared:
error: 'machine' at /etc/nixos/network.nix:2:13 called with unexpected argument 'rome'
  at /etc/nixos/network.nix:33:14
33|       athens = machine {
34|       host = "192.168.0.2";
Did you mean name?
For me the Nix language is a little bit confusing.
My questions are:
  1. why am I getting this error?
  2. How can I fix it?
