home-manager switch --flake .
error:
at /nix/store/ilqr95vggnjqpbh6r0fiz2dw43iljg93-source/lib/lists.nix:142:18:
141| len = length list;
142| fold' = n: if n == len then nul else op (elemAt list n) (fold' (n + 1));
143| in
… while calling the 'length' builtin
at /nix/store/ilqr95vggnjqpbh6r0fiz2dw43iljg93-source/lib/lists.nix:141:13:
140| let
error: The option `NIX_CFLAGS_COMPILE' does not exist. Definition values:
- In `<unknown-file>': "-msse4.1"
as far as changes I made to my home manager, it was just adding pkgs.suyu to it:
there’s probably better/shorter ways to do it but I don’t know.
this got me to start building suyu when doing home-manager switch --flake . but it has some dependency erros now that I’m not sure about:
home-manager switch --flake . --show-trace
error: builder for '/nix/store/c9142lj33v46vfnvdxnwx82lx7by4dig-suyu-0.0.3.drv' failed with exit code 2;
last 25 log lines:
> [ 52%] Building CXX object src/video_core/CMakeFiles/video_core.dir/renderer_vulkan/vk_scheduler.cpp.o
> [ 52%] Building CXX object src/video_core/CMakeFiles/video_core.dir/renderer_vulkan/vk_shader_util.cpp.o
> [ 52%] Building CXX object src/video_core/CMakeFiles/video_core.dir/renderer_vulkan/vk_staging_buffer_pool.cpp.o
> [ 52%] Building CXX object src/video_core/CMakeFiles/video_core.dir/renderer_vulkan/vk_state_tracker.cpp.o
> [ 52%] Building CXX object src/video_core/CMakeFiles/video_core.dir/renderer_vulkan/vk_swapchain.cpp.o
> [ 52%] Building CXX object src/video_core/CMakeFiles/video_core.dir/renderer_vulkan/vk_texture_cache.cpp.o
> [ 52%] Building CXX object src/video_core/CMakeFiles/video_core.dir/renderer_vulkan/vk_texture_cache_base.cpp.o
> [ 52%] Building CXX object src/video_core/CMakeFiles/video_core.dir/renderer_vulkan/vk_turbo_mode.cpp.o
> In file included from /build/suyu/src/./video_core/vulkan_common/vk_enum_string_helper.h:8,
> from /build/suyu/src/video_core/renderer_vulkan/vk_swapchain.cpp:15:
> /build/suyu/externals/Vulkan-Utility-Libraries/include/vulkan/vk_enum_string_helper.h: In function 'const char* string_VkDriverId(VkDriverId)':
> /build/suyu/externals/Vulkan-Utility-Libraries/include/vulkan/vk_enum_string_helper.h:3481:14: error: 'VK_DRIVER_ID_MESA_AGXV' was not declared in this scope; did you mean 'VK_DRIVER_ID_MESA_V3DV'?
> 3481 | case VK_DRIVER_ID_MESA_AGXV:
> [ 52%] Building CXX object src/video_core/CMakeFiles/video_core.dir/renderer_vulkan/vk_update_descriptor.cpp.o
> [ 52%] Building CXX object src/video_core/CMakeFiles/video_core.dir/shader_cache.cpp.o
> [ 52%] Building CXX object src/video_core/CMakeFiles/video_core.dir/shader_environment.cpp.o
> [ 52%] Building CXX object src/video_core/CMakeFiles/video_core.dir/shader_notify.cpp.o
> [ 52%] Building CXX object src/video_core/CMakeFiles/video_core.dir/surface.cpp.o
> [ 53%] Building CXX object src/video_core/CMakeFiles/video_core.dir/texture_cache/accelerated_swizzle.cpp.o
> make[2]: *** [src/video_core/CMakeFiles/video_core.dir/build.make:1661: src/video_core/CMakeFiles/video_core.dir/renderer_vulkan/vk_swapchain.cpp.o] Error 1
> make[2]: *** Waiting for unfinished jobs....
> make[1]: *** [CMakeFiles/Makefile2:1420: src/video_core/CMakeFiles/video_core.dir/all] Error 2
> make: *** [Makefile:136: all] Error 2
For full logs, run 'nix log /nix/store/c9142lj33v46vfnvdxnwx82lx7by4dig-suyu-0.0.3.drv'.
error: 1 dependencies of derivation '/nix/store/z6rqqshc7rlyn80fgy6zg03clfmywgcn-home-manager-path.drv' failed to build
error: 1 dependencies of derivation '/nix/store/5flzad6y4300vk1zdrp3vkmgdqhiippd-man-paths.drv' failed to build
error: 1 dependencies of derivation '/nix/store/007v8p4cj1q4k94xfi9b0qs5ivyx6cl4-suyu-0.0.3-fish-completions.drv' failed to build
error: 1 dependencies of derivation '/nix/store/a45aw9kkgksrc2hy4mg2w97pbdn467c4-home-manager-generation.drv' failed to build
Yeah suyu not building is a whole other thing, it hasn’t been updated in 7 months so that’s not surprising. You’ll have to go full-on c++ developer mode to fix that, probably a missing header or maybe the vulkan API’s changed since then, no idea offhand.
