Hello everyone,
I’m running into an issue whilst adding a script into my configuration.nix file.
When I add this script to my Autostart section in Budgie on NixOS it just works as expected. However in the vain of reproducibility I’d like to add it to my configuration.nix (or a separate file I could include), but when I add it as systemd.user.services.autorotate-sam as a linked file (because the file itself works, so why not just link to it?) it throws errors at me. And when I copy in the content of the script into my config only the screen rotation works, the pointer matrices aren’t changing. Below I’ll paste both versions to help diagnose the issue (sorry for the long post in advance!);
# Autorotate S.A.M. as NixOS script
# WIP!!!
systemd.user.services.autorotate-sam = {
after = [ "network-online.target" ];
description = "Automatically rotate the display orientation and pointer matrixes";
script = [ "/home/ryukurisu/SDcard/.bin/autorotate-sam.sh" ];
# WIP!!!
script = with pkgs; ''
#!/bin/sh
# Use multistage grep to find the display connector (VGA-1/eDP-1/etc)
SCREEN=$(xrandr | grep 'connected' | grep -v 'disconnected' | grep -oE '[a-zA-Z]+[\-]+[^ ]')
function Mice {
for i in $(xinput list | grep -e "slave pointer" | grep -Po 'id=\K[0-9]+') ; do
xinput set-prop "$i" "Coordinate Transformation Matrix" $MATRIX #1 0 0 0 1 0 0 0 1
done
# Launch monitor-sensor - store output in a variable on tmpfs (RAM) to be parsed by the rest script
#killall monitor-sensor
monitor-sensor >> /dev/shm/sensor.log 2>&1 &
# Parse output of monitor-sensor to get the new orientation whenever the log file is updated. Possibles are: normal, bottom-up, right-up, left-up. Light data will be ignored
while inotifywait -e modify /dev/shm/sensor.log; do
ORIENTATION=$(tail -n 1 /dev/shm/sensor.log | grep 'orientation' | grep -oE '[^ ]+$') # Read the last line that was added to the file and get the orientation
case "$ORIENTATION" in # Set the actions to be taken for each possible orientation
normal)
if [ ! -f /dev/shm/.rotation-lock ]; then
xrandr --output $SCREEN --rotate normal
MATRIX="1 0 0 0 1 0 0 0 1" ; Mice $?=$MATRIX;
fi;;
bottom-up)
xrandr --output $SCREEN --rotate inverted
MATRIX="-1 0 1 0 -1 1 0 0 1" ; Mice $?=$MATRIX ;
fi;;
right-up)
if [ ! -f /dev/shm/.rotation-lock ] ; then
xrandr --output $SCREEN --rotate right
MATRIX="0 1 0 -1 0 1 0 0 1" ; Mice $?=$MATRIX ;
fi;;
left-up)
xrandr --output $SCREEN --rotate left
MATRIX="0 -1 1 1 0 0 0 0 1" ; Mice $?=$MATRIX ;
fi;;
esac
done
My preferred solution would be to link to an external file, maybe even a fetchFromGit(Hub?) (as Codeberg is a git repository).
