So the following package:
{ lib, buildPythonPackage, fetchPypi, tensorflow }:
buildPythonPackage rec {
pname = "tfjs-graph-converter";
version = "1.0.0";
src = fetchPypi {
inherit pname version;
hash = "sha256-2NCRbV36/Hb4epeVBAY/Qj2Ia0RwR1mDonzEGVvtY88=";
propaprgatedBuildInputs = [ tensorflow ];
meta = with lib; {
description = "A tensorflowjs Graph Model Converter";
homepage = "https://github.com/patlevin/tfjs-to-tf";
license = licenses.mit;
mantainers = with mantainers;[ pasqui23 ];
fails to build with the error that there is no tensorflow package,even through it is packaged for python nixpkgs/default.nix at 42809feaa9f7474f5566a5c6e8e317e15e39160e · NixOS/nixpkgs · GitHub
Where am I doing wrong?
FRidh
February 27, 2021, 6:44am
3
typo. Should be propagatedBuildInputs
nrj
February 27, 2021, 10:47pm
4
Would it be possible to generate a “pedantic” warning for typos like that?
not in its current state. As all attrs also manifest themselves as shell variable within the build. So there’s not a good way to differentiate accident or purposeful spellings.
nrj
February 28, 2021, 1:26am
6
Has anybody talked about changing that to separate the namespaces, e.g. by introducing a shellVars
attribute?
It would be a massive breaking change to implement this now.
nrj
February 28, 2021, 2:43am
8
It could be the next generation build function, with a different name to avoid breaking existing usage.
I think it’s going to be harder than you think, shellHooks and a bunch of other assumptions would also be invalidated.
I think it would be better to have a linter which can do a fuzzy search, and say, "Hey, this is close to this commonly used mkDerivation Attr: Did you mean propagatedBuildInputs
instead of propaprgatedBuildInputs
Nixpkgs-hammering includes the basics of such a linter, although it may need some improvements to deal with buildPythonPackage packages.
r-burns
February 28, 2021, 7:51am
11
I think we are actually already moving in this direction – with __structuredAttrs, env variables are specified explicitly, so we could do more rigorous checking on the derivation args.
But it’s true that this is a massively breaking change, so it would have to be introduced in an opt-in fashion.
https://github.com/NixOS/nixpkgs/pull/85042
Even with the correct attribute name, I still have the same build error
nix log /nix/store/axjlays9drvz2fjavxdrwr8lhi2hqhxr-python3.8-tfjs-graph-converter-1.0.0.drv
Sourcing python-remove-tests-dir-hook
Sourcing python-catch-conflicts-hook.sh
Sourcing python-remove-bin-bytecode-hook.sh
Sourcing setuptools-build-hook
Using setuptoolsBuildPhase
Using setuptoolsShellHook
Sourcing pip-install-hook
Using pipInstallPhase
Sourcing python-imports-check-hook.sh
Using pythonImportsCheckPhase
Sourcing python-namespaces-hook
Sourcing setuptools-check-hook
Using setuptoolsCheckPhase
@nix { "action": "setPhase", "phase": "unpackPhase" }
unpacking sources
unpacking source archive /nix/store/x54clglnk6bhxymrgqri5vr2l6bjnj81-tfjs-graph-converter-1.0.0.tar.gz
source root is tfjs-graph-converter-1.0.0
setting SOURCE_DATE_EPOCH to timestamp 1587954824 of file tfjs-graph-converter-1.0.0/tfjs_graph_converter.egg-info/top_level.txt
@nix { "action": "setPhase", "phase": "patchPhase" }
patching sources
@nix { "action": "setPhase", "phase": "configurePhase" }
configuring
@nix { "action": "setPhase", "phase": "buildPhase" }
building
Executing setuptoolsBuildPhase
running bdist_wheel
running build
running build_py
file tfjs_graph_converter.py (for module tfjs_graph_converter) not found
creating build
creating build/lib
creating build/lib/tfjs_graph_converter
copying tfjs_graph_converter/__init__.py -> build/lib/tfjs_graph_converter
copying tfjs_graph_converter/version.py -> build/lib/tfjs_graph_converter
copying tfjs_graph_converter/api.py -> build/lib/tfjs_graph_converter
copying tfjs_graph_converter/common.py -> build/lib/tfjs_graph_converter
copying tfjs_graph_converter/converter.py -> build/lib/tfjs_graph_converter
copying tfjs_graph_converter/util.py -> build/lib/tfjs_graph_converter
copying tfjs_graph_converter/convert_prelu.py -> build/lib/tfjs_graph_converter
copying tfjs_graph_converter/graph_rewrite_util.py -> build/lib/tfjs_graph_converter
copying tfjs_graph_converter/optimization.py -> build/lib/tfjs_graph_converter
copying tfjs_graph_converter/quirks.py -> build/lib/tfjs_graph_converter
installing to build/bdist.linux-x86_64/wheel
running install
running install_lib
creating build/bdist.linux-x86_64
creating build/bdist.linux-x86_64/wheel
creating build/bdist.linux-x86_64/wheel/tfjs_graph_converter
copying build/lib/tfjs_graph_converter/__init__.py -> build/bdist.linux-x86_64/wheel/tfjs_graph_converter
copying build/lib/tfjs_graph_converter/version.py -> build/bdist.linux-x86_64/wheel/tfjs_graph_converter
copying build/lib/tfjs_graph_converter/api.py -> build/bdist.linux-x86_64/wheel/tfjs_graph_converter
copying build/lib/tfjs_graph_converter/common.py -> build/bdist.linux-x86_64/wheel/tfjs_graph_converter
copying build/lib/tfjs_graph_converter/converter.py -> build/bdist.linux-x86_64/wheel/tfjs_graph_converter
copying build/lib/tfjs_graph_converter/util.py -> build/bdist.linux-x86_64/wheel/tfjs_graph_converter
copying build/lib/tfjs_graph_converter/convert_prelu.py -> build/bdist.linux-x86_64/wheel/tfjs_graph_converter
copying build/lib/tfjs_graph_converter/graph_rewrite_util.py -> build/bdist.linux-x86_64/wheel/tfjs_graph_converter
copying build/lib/tfjs_graph_converter/optimization.py -> build/bdist.linux-x86_64/wheel/tfjs_graph_converter
copying build/lib/tfjs_graph_converter/quirks.py -> build/bdist.linux-x86_64/wheel/tfjs_graph_converter
running install_egg_info
running egg_info
writing tfjs_graph_converter.egg-info/PKG-INFO
writing dependency_links to tfjs_graph_converter.egg-info/dependency_links.txt
writing entry points to tfjs_graph_converter.egg-info/entry_points.txt
writing requirements to tfjs_graph_converter.egg-info/requires.txt
writing top-level names to tfjs_graph_converter.egg-info/top_level.txt
reading manifest file 'tfjs_graph_converter.egg-info/SOURCES.txt'
writing manifest file 'tfjs_graph_converter.egg-info/SOURCES.txt'
Copying tfjs_graph_converter.egg-info to build/bdist.linux-x86_64/wheel/tfjs_graph_converter-1.0.0-py3.8.egg-info
running install_scripts
creating build/bdist.linux-x86_64/wheel/tfjs_graph_converter-1.0.0.dist-info/WHEEL
creating 'dist/tfjs_graph_converter-1.0.0-py3-none-any.whl' and adding 'build/bdist.linux-x86_64/wheel' to it
adding 'tfjs_graph_converter/__init__.py'
adding 'tfjs_graph_converter/api.py'
adding 'tfjs_graph_converter/common.py'
adding 'tfjs_graph_converter/convert_prelu.py'
adding 'tfjs_graph_converter/converter.py'
adding 'tfjs_graph_converter/graph_rewrite_util.py'
adding 'tfjs_graph_converter/optimization.py'
adding 'tfjs_graph_converter/quirks.py'
adding 'tfjs_graph_converter/util.py'
adding 'tfjs_graph_converter/version.py'
adding 'tfjs_graph_converter-1.0.0.dist-info/METADATA'
adding 'tfjs_graph_converter-1.0.0.dist-info/WHEEL'
adding 'tfjs_graph_converter-1.0.0.dist-info/entry_points.txt'
adding 'tfjs_graph_converter-1.0.0.dist-info/top_level.txt'
adding 'tfjs_graph_converter-1.0.0.dist-info/RECORD'
removing build/bdist.linux-x86_64/wheel
Finished executing setuptoolsBuildPhase
@nix { "action": "setPhase", "phase": "installPhase" }
installing
Executing pipInstallPhase
/build/tfjs-graph-converter-1.0.0/dist /build/tfjs-graph-converter-1.0.0
Processing ./tfjs_graph_converter-1.0.0-py3-none-any.whl
ERROR: Could not find a version that satisfies the requirement tensorflowjs>=1.5.2 (from tfjs-graph-converter)
ERROR: No matching distribution found for tensorflowjs>=1.5.2
This complains about a missing tensorflowjs
package, not tensorflow
package. I don’t think we have packaged tensorflowjs
