Proper way of applying patch to system managed via flake
If I read this correctly, thats IFD?
I would be happy if there was a blessed and officially supported way to apply patches to any flake inputs that would not cause IFD.
Of course I understand that this would require an additional evaluation phase if patches have been used.
Still I think flakes would improve overall if thats supported
Yes, pretty sure it is IFD. I only do this on my flake for my NixOS systems.
I wonder if that could actually be a nix builtin, some kind of syntax around inputs. “I want to patch my input” is a generic problem, even if nixpkgs’ size makes it more frequent, and nix needs git support to pull the inputs already, so why not have it patch the input before evaluation?
edolstra already has a WIP PR which makes this a builtin, although it’s slightly more limited as you have to have the patch files in the flake rather than fetching.
https://github.com/NixOS/nix/pull/6530
ryantm’s approach only patches pkgs, which doesn’t work if the patch contains fix for nixosmodule for example.
Here’s attempt version to patch the whole nixpkgs for use:
      system = "x86_64-linux";
      pkgs-init = import inputs.nixpkgs { inherit system; };
      patches = [
        (pkgs-boot.fetchpatch {
          url = "https://patch-diff.githubusercontent.com/raw/NixOS/nixpkgs/pull/207758.patch";
          hash = "sha256-1bxn+U0NslCTElG+EhJe43FRf+5tIgMh7gvPKAyGe0U=";
      nixpkgs-patched =
        pkgs-boot.applyPatches {
          name = "nixpkgs-patched";
          src = inputs.nixpkgs;
          inherit patches;
      pkgs = import nixpkgs-patched {
        inherit system;
        config.allowUnfree = true;
        overlays = [
          emacs-overlay.overlays.default
      nixpkgs = (import "${nixpkgs-patched}/flake.nix").outputs { self = inputs.self; };
The trick is the last line of the import, which would expose back a patched nixpkgs which has lib and nixosModules, so you can use the same old nixpkgs.lib.nixosSystem for example. The patched nixpkgs is a bit different than the original inputs.nixpkgs, but that’s as good as I can get it to work.
Somebody did the similar thing for darwin as well. Support flake references to patches · Issue #3920 · NixOS/nix · GitHub
The results of builtins.fetchTree is not a derivation, and therefore, can be used to avoid IFD in this situation, at least until the new patch builtin is finally merged.
