PRs ready for review _
Hey commiters kindly if you have the time, can I have one of you merge this in, it’s been two weeks since approval and no more reviewers have commented: bluej: add darwin support by Eveeifyeve · Pull Request #489990 · NixOS/nixpkgs · GitHub It’s getting to the point I am just getting sick of it being there not merged or anything. Thanks eveeifyeve
Performance Co Pilot package and service
Modeled after: Nix refactor by randomizedcoder · Pull Request #2501 · performancecopilot/pcp · GitHub
YouTube demo video:
A default nginx config for the ntfy-sh module (push notification service):
PR from March where an option is added to `gollum` service (git-based wiki service). It is not enabled by default so should not be disruptive but important when you want to use a bare repository as the wiki source.
Packaged a DBus interface for opening the directory a file is in using terminal file managers
Would appreciate it a lot if someone left a review!
Not my PR, I’d loved display-managers: add Hyprland to list of systemd-aware display managers by VlaDexa · Pull Request #493701 · NixOS/nixpkgs · GitHub to get merged.
This PR should fix the bug that the Ly display manager cannot start Hyprland with UWSM: #727 - [Bug] Incompatibility with UWSM? - fairyglade/ly - Codeberg.org , an issue with 5 upvotes.
The problem with the current situation (before this PR) is explained in add nixos/ly module and package update by Vonfry · Pull Request #297434 · NixOS/nixpkgs · GitHub, which mentions a workaround, but causes an undesirable side-effect: #727 - [Bug] Incompatibility with UWSM? - fairyglade/ly - Codeberg.org
The current PR should allow Ly to start Hyprland with UWSM, without any side effect that I know of. I haven’t tried Ly myself due to those bug reports, and I look forward to after this PR is merged.
Hello
this is a PR that is quite old but since it has helped some people around I would like to get it merged.
Here is the corresponding Issue.
I’d love to get this update to libfprint merged as it fixes my ROG Ally fingerprint reader :slight_smile:
I’d like to get this PR reviewed: aws-cloudformation-languageserver: init at 1.4.0 by mbarneyjr · Pull Request #489310 · NixOS/nixpkgs · GitHub
This is my first package init contribution, I’d love to maintain aws-cloudformation-languageserver package in nixpkgs. I’ve read through the contributing doc and I believe I’ve done everything for a new package PR. If there’s anything missing I’m more than happy to fix it!
Isabelle update to fix multiple builds running at the same time on darwin:
sc update:
