iefo
July 15, 2026, 5:25am
7235
There is is really annoying regression that came with systemd 261, that causes keyboard layout issues for anything that relies on systemd-localed (niri, Plasma have been reported).
The fix is trivial and we already have three open PRs addressing this issue:
master ← Evanev7:fix-desktop-conf-plasma-67
opened 07:03PM - 11 Jul 26 UTC
systemd-loacled 261 string_is_safe fails "", rejecting nixos X11/00-keyboard.con… f. this causes keyboard layouts to failover to defaults on KDE Plasma 6.7.
test validates that localed emits xkb information correctly in the presence of null variants in the keymap.qwertz test.
## Things done
- Built on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] aarch64-darwin
- Tested, as applicable:
- [x] [NixOS tests] in [nixos/tests].
- [x] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
- Nixpkgs Release Notes
- NixOS Release Notes
- [x] Follows the [automation/AI policy].
[automation/AI policy]: https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#automationai-policy
master ← haansn08:fix-00-keyboard.conf
opened 02:33AM - 12 Jul 26 UTC
This PR fixes https://github.com/NixOS/nixpkgs/issues/540709.
It includes the r… egression test https://github.com/NixOS/nixpkgs/pull/540754 .
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
master ← ncguilbeault:nixos/graphical-desktop-omit-empty-xkb-options
opened 11:06AM - 14 Jul 26 UTC
`00-keyboard.conf` is generated with all four `Option` entries unconditionally, … including empty ones such as `Option "XkbVariant" ""` when `services.xserver.xkb.variant` is unset (the default).
Since systemd 261, `string_is_safe()` rejects empty strings (systemd/systemd@812aa57d2c), and systemd-localed applies it to every field parsed from `00-keyboard.conf`, discarding the entire parsed X11 context when any field fails. As a result `localectl status` reports `X11 Layout: (unset)` and the `X11Layout` property on `org.freedesktop.locale1` is empty, even though the file names a valid layout.
This has a serious user-facing consequence on Plasma 6: the SDDM greeter runs `kwin_wayland --locale1`, which reads the keymap from locale1 and falls back to the `us` layout when the property is empty. Users with a non-us layout and layout-dependent characters in their password cannot log in through the display manager (TTY logins still work since the console keymap does not go through localed).
This change writes only non-empty `Option` values, which is equivalent as far as the X server is concerned and restores correct localed behavior on systemd 261. The generated file is unchanged for configurations where all four xkb settings are non-empty.
The localed regression is also reported upstream: systemd/systemd#43007.
Closes #541408.
Verification: with a minimal NixOS VM (`services.graphical-desktop.enable`, `services.xserver.xkb.layout = "gb"`, systemd 261 from this branch), `localectl status` reports `X11 Layout: gb` with this change and `X11 Layout: (unset)` without it. Rendering the generated file with an empty and a non-empty variant confirms only the empty `Option` line is dropped. This PR adds `nixosTests.localed-keyboard` covering the localed path (fails without the fix, passes with it), and the existing `keymap` tests (`azerty`, `qwertz`, `colemak`) pass against this branch, confirming the X server treats the omitted empty options the same as explicitly empty ones.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
Maybe one of those PRs could be reviewed?
shouya
July 15, 2026, 7:05am
7236
master ← shouya:patch-1
opened 08:13AM - 23 May 26 UTC
This PR contains two fixes related to brscan5 (brother scanner driver for sane) … due to libredirect misconfiguration:
- fix invalid `brsaneconfig5` binary from `brscan5` package due to a typo
- fix ineffective `hardware.sane.brscan5.netDevices` config due to conflicting path name
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
both fixes are relatively trivial. the pr has been sitting for a month now without any any feedback. it would be great if someone can have a look.
master ← jsqu4re:add-wtp
opened 10:45AM - 09 Jul 26 UTC
https://github.com/satococoa/wtp with 520 Stars at the time:
> A powerful Git… worktree management tool that extends git's worktree functionality with automated setup, branch tracking, and project-specific hooks.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
Adds a package that allows to manage git worktrees a little neater.
This was my first Nixpkgs contribution. Followup on comments in the first PR are in the following PR
staging-nixos ← juancnuno:handle-other-attributes
opened 01:14PM - 08 Jul 26 UTC
## Things done
- [x] x86_64-linux
- [ ] aarch6… 4-linux
Could someone review this PR please?
master ← jayadeep-km-sonarsource:sonarqube-cli-init
opened 09:20AM - 30 Jun 26 UTC
Adds sonarqube-cli, official cli from Sonarqube
## Things done
- Built… on platform:
- [x] x86_64-linux
- [x] aarch64-linux
- [x] aarch64-darwin
I made the PR from my work account. This is my first time contributing a new package. Thanks for your support!
SeTSeR
July 16, 2026, 4:48pm
7251
master ← SeTSeR:far2l-plugins
opened 07:44PM - 28 Jun 26 UTC
Enable far2l plugins brought with recent updates. Export library required for fa… r2l Arclite plugin from _7zz package.
PR is based on #519180.
Closes #447724.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
I already have two approves on my package, one stale change request and no feedback for last two weeks. Please review or merge this.
