Please help merging package fix
master β rokokol:epson_201310w-resource-path
opened 05:08PM - 30 Sep 26 UTC
Every print job to an Epson L120 through `EPSON_L120.ppd` ends in `Filter failed⦠`, and the printer prints nothing.
`postFixup` replaces `Epson_201310w.1.data` in the PPD with `$out/resource/Epson_201310w.1.data`. The filter prefixes its own resource directory to this value, so it tries to open `$out/resource/$out/resource/Epson_201310w.1.data`. `strace` shows the failed `openat`. The filter then exits with status 1 after it wrote only the job header.
This change keeps the bare file name that Epson's PPD has. The watermark paths still get the store path, because the filter reads them as they are.
Tested on an Epson L120 over USB with CUPS 2.4.19: a PDF page prints correctly through the fixed PPD. The PPD that this change builds is identical to the tested one, except for the store path.
cc @nukdokplex
## Things done
- Built on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] aarch64-darwin
- Tested, as applicable:
- Nixpkgs Release Notes
- NixOS Release Notes
- [x] Follows the [automation/AI policy].
[automation/AI policy]: https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#automationai-policy
*Assisted-by: Claude Code (claude-opus-5-5), disclosed separately from the commit per the automation/AI policy. The diagnosis, the build and the test print above were done on my own machine, and I have reviewed both the change and this summary.*
Hello! Could I ask the committers to take a look at my package? Iβve already received two approvals from reviewers, and I could really use some help from people who have the authority to add the package to the repository. portprotonqt: init at 1.5.0 by dark-siders Β· Pull Request #575244 Β· NixOS/nixpkgs Β· GitHub
Hi, I put together this package like two weeks ago and it was never assigned a reviewer.
master β KMalone42:master
opened 01:06AM - 24 Oct 26 UTC
## Things done
Created nixpkgs derivation of genoffice an "AI-native office suit⦠e: Word, Excel, PowerPoint, PDF and Markdown in one local app" and added self as maintainer to be the packages maintainer.
- [ x ] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
- [ x ] Follows the [automation/AI policy].
- [ x ] x86_64-linux
- [ ] aarch64-linux
- [ x ] Basic functionality of all binary files, usually in `./result/bin/`.
kiri
November 5, 2026, 10:07pm
7922
I would like to introduce a new package called Maintainerr. It is a supplemental service to the Starr apps that uses a rules engine to automatically remove stale media from your server.
master β kiriwalawren:maintainerr
opened 06:49PM - 23 Oct 26 UTC
Adds [Maintainerr](https://github.com/Maintainerr/Maintainerr), a self-hosted, r⦠ules-based media library maintenance tool for Plex and Jellyfin. Titles that match user-defined rules (for example unwatched or unrequested) are gathered into a collection and given a grace period. After that they are removed from the media server, the \*arrs, and Seerr or Ombi. Upstream is MIT-licensed and actively maintained.
The package has been maintained in [nixflix](https://github.com/kiriwalawren/nixflix) since the Maintainerr implementation (kiriwalawren/nixflix#242). Users asked for it in nixpkgs so they get binary cache substitutes instead of building from source on low-powered servers (kiriwalawren/nixflix#386).
`passthru.updateScript` is a custom script, because nix-update regenerates the `offlineCache` hash but not `missing-hashes.json`. The script is modelled on `outline/update.sh`.
## AI disclosure
This PR was prepared with the help of Claude Code (claude-opus-5-5). The `maintainerr: init at 3.31.0` commit carries an `Assisted-by:` trailer. The `maintainers: add kiriwalawren` commit was written without AI assistance. I reviewed and tested all of the changes listed below.
### Written by me in nixflix, before any AI involvement
- [`pkgs/maintainerr/default.nix`](https://github.com/kiriwalawren/nixflix/blob/b668fa4159b9a294efd6e49ea3b889ecdd77e809/pkgs/maintainerr/default.nix): the derivation structure, which builds with `yarn turbo build` and `yarn workspaces focus --production`. It also contains:
- the install layout
- the `__PATH_PREFIX__` UI base path handling
- the canvas `buildInputs`
- the `UV_USE_IO_URING=0` wrapper
- `meta`
- [`pkgs/maintainerr/update.sh`](https://github.com/kiriwalawren/nixflix/blob/b668fa4159b9a294efd6e49ea3b889ecdd77e809/pkgs/maintainerr/update.sh): the update logic, which fetches the latest release, regenerates `missing-hashes.json` and recomputes the hashes.
### Changed by the AI, with the reason for each change
- **Converted to nixpkgs conventions:** `finalAttrs`, a top-level `offlineCache` aliased in `passthru` for nix-update, and `maintainers`. This was done so the package follows `pkgs/README.md` and the yarn-berry layout used by `outline`.
- **Version 3.30.1 β 3.31.0, with a regenerated `missing-hashes.json`:** 3.31.0 was released while this PR was being prepared.
- **`nodejs_24` β `nodejs_26`, with `yarn-berry` and its config hook overridden to the same node:** upstream declares `engines.node >=26.0.0`. Without the override, the hook would compile native modules such as canvas against the default node's headers instead of the node that runs them.
- **Removed `YARN_LOCKFILE_VERSION_OVERRIDE` and the `.yarnrc.yml` `postPatch`/`preBuild` edits:** they worked around nixflix's older yarn, and the nixpkgs yarn-berry_4 (4.18.1) builds the upstream lockfile without them.
- **Removed `sqlite` and `npm_config_sqlite`:** that variable is only read by `node-sqlite3`, which isn't a dependency. better-sqlite3 compiles its bundled SQLite.
- **Removed the `sed` rewrites of `/opt/data` in the logging module:** since 3.31.0 upstream reads `DATA_DIR` itself (`apps/server/src/app/config/dataDir.ts`).
- **The migrations path rewrite moved from a `sed` on compiled JS in `installPhase` to `substituteInPlace --replace-fail` on the TypeScript source in `postPatch`:** if upstream changes this code, the build now fails instead of silently skipping the rewrite.
- **better-sqlite3 and sharp are now built from source (sharp against nixpkgs `vips`) instead of using their bundled prebuilt binaries:** better-sqlite3 13 always loads a matching prebuild over a local build, and upstream's README notes that sharp's prebuilt binaries need an x86-64-v2 CPU.
- **Added `npm_package_version` to the wrapper:** upstream's `docker/start.sh` sets it so the app reports its real version and doesn't fall back to `0.0.1`.
- **Removed `node-gyp` and native build artifacts from the output, and added `disallowedReferences = [ python3 ]`:** node-gyp is only needed at build time, and its patched shebangs added python to the closure. The closure dropped from 807 MiB to 661 MiB.
- **Added comments documenting each special packaging choice:** required by the new-package review checklist in `pkgs/README.md`.
- **Added `passthru.tests.simple`:** a sandbox smoke test that starts the server and checks `/api/health/ready` and the UI, so CI exercises every automated update.
- **Rewrote `update.sh` with a `nix-shell` shebang, `common-updater-scripts` and `nix-instantiate`/`nix-build` lookups:** it now follows the nixpkgs update script conventions used by `outline`, instead of editing hashes with `sed`/`awk` by position.
## Testing
- `nix-build -A maintainerr` and `nix-build -A maintainerr.tests` on x86_64-linux with the sandbox enabled.
- Checked that better-sqlite3, sharp and canvas all load their source-built binaries under node 26.
- Ran nixflix's `maintainerr-basic` NixOS VM test with `nixflix.maintainerr.package` set to this package. It covers service startup and the settings, rules and overlay configuration APIs, and it passes.
- Ran `update.sh` starting from 3.30.1. It produced files identical to the ones in this PR.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [x] Basic functionality of all binary files, usually in `./result/bin/`.
- [x] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
- [x] [Package tests] at `passthru.tests`.
yazeed
November 7, 2026, 12:45am
7924
master β yazeed:proc-cli-init
opened 03:11AM - 31 Oct 26 UTC
proc is a command-line tool for process and port management: it finds, inspects,β¦ stops and frees processes by port, PID, name or directory, with JSON output and fixed exit codes for scripts and coding agents. Homepage: https://proc-cli.com, source: https://github.com/yazeed/proc-cli. I'm its author and add myself as its maintainer.
The package installs the man page and the bash, zsh and fish completions that `proc` prints, runs the whole test suite with nothing skipped (`procps` on Linux, `darwin.ps` and `lsof` on macOS as check inputs, since the tests call `ps` and proc reads ports with `lsof` on macOS), checks the version with `versionCheckHook`, and has `nix-update-script` as its update script. On macOS it sets `__darwinAllowLocalNetworking`, since the tests listen on 127.0.0.1. From 2.2.0 proc also runs on FreeBSD and NetBSD, so `meta.platforms` lists them.
AI disclosure: the package expression and this description were written with Claude Code (Claude Opus 5.5) and reviewed by me before submitting; both commits carry an `Assisted-by:` trailer. It was checked by building it with its tests against this branch's `master` in the `nixos/nix` image (aarch64-linux), and with `nixfmt --check`; the project's CI also builds this exact package with its tests on x86_64-linux and on aarch64-darwin with `sandbox = relaxed`.
## Things done
- [ ] x86_64-linux
- [x] aarch64-linux
proc-cli: init at 2.3.0, a Rust CLI for finding and stopping processes by port, PID, name or path. Iβm the upstream author and the listed maintainer. It builds on Linux and Darwin, the full test suite runs in the sandbox, all 22 checks pass, and it has had one review. It just needs a committer to take a look.
payas
November 7, 2026, 9:18am
7926
A PR to remove myself from maintainers. Iβm removing myself because I already lack time to maintain packages. I wouldnβt have time to track this PR either. Kindly review/merge at earliest convenience so as to let other maintainers know these packages are now unmaintained:
master β bhankas:master
opened 08:58AM - 07 Nov 26 UTC
Also drop `glas`, a language server for gleam that appears to be unmaintained fo⦠r more than a year.
I have not used most or all of the packages under my maintenance, and due to other priorities am not able to contribute sufficient time to maintain these packages. As such I'd like to be removed from the maintainers. I have requested the same for multiple PRs for packages with my name in past year or so, but it was (understandably) not the priority for other contributors, hence this PR.
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
iopq
November 7, 2026, 11:26am
7927
master β iopq:patch-1
opened 05:54AM - 04 Nov 26 UTC
## Things done
fixes
https://github.com/NixOS/nixpkgs/issues/359699
this versi⦠on successfully connects to the server
I used an LLM to help me fix the build
- [x] x86_64-linux
- [ ] aarch64-linux
- [x] Module update: when the change is significant.
Looking for someone who doesnβt mind reviewing LLM-assisted PRs
