Is there a way to get PyCharm to use nix-shell and not a venv?
All answers I found were more than 5 years old, and maybe there are better solutions now possible.
system ? builtins.currentSystem,
pkgs ? import <nixpkgs> { inherit system; }
pythonEnv = pkgs.python3.withPackages (ps: [
ps.numpy
ps.scipy
ps.matplotlib
ps.pandas
ps.jupyter
pkgs.mkShell {
packages = [ pythonEnv ];
shellHook = ''
ln -snf ${pythonEnv} .python-env
Then use .python-env in PyCharm
Thank you so much! I spent too many hours with horrible workarounds and should have asked earlier.
In the solution above, a “;” is missing so I add the working code below if someone else has the same problem as I had.
# shell.nix
ps.numpy
ps.scipy
ps.matplotlib
ps.pandas
ps.jupyter
in pkgs.mkShell {
shellHook = ''
