I’m running nix shell to setup a ptyhon development environment in a directory. Installing Librosa and Streamlit libraries works fine. But when I add Music21 I get this error:
error: attribute 'music21' missing
at /my/path/to/shell.nix:10:7:
9| ps.streamlit
10| ps.music21
11| ]))
This is the shell.nix
file:
with pkgs;
mkShell {
buildInputs = [
(python3.withPackages (ps: [
ps.librosa
ps.streamlit
ps.music21
I don’t quite get why Librosa and Streamlit get installed fine but Music21 doesn’t. The installation instructions for all of them use pip
. I assumed nix-shell is a replacement and would work for all cases, but it doesn’t.
Is there something I should be considering?
Those packages come from Nixpkgs. To use that library you’ll have to package it or use an option like uv2nix or poetry2nix if you want it automated.
Edit: You can also try GitHub - nix-community/pip2nix: Freeze pip-installable packages into Nix expressions [maintainer=@datakurre] to create the package
thanks, I’ll look into that
This worked great. Thanks!
- Created a
music21.nix
file in the same directory as shell.nix
with all the needed dependencies:
# music21.nix
lib,
buildPythonPackage,
fetchPypi,
setuptools,
wheel,
# ... adding the following to the wiki example
hatchling,
chardet,
joblib,
jsonpickle,
matplotlib,
more-itertools,
numpy,
requests,
webcolors,
buildPythonPackage rec {
pname = "music21";
version = "9.5.0";
src = fetchPypi {
inherit pname version;
hash = "sha256-+IioT3q/pucntwKM2/e3vZ+nRgCbdmymBPt0mmcHjRo=";
# do not run tests
doCheck = false;
# specific to buildPythonPackage, see its reference
pyproject = true;
build-system = [
setuptools
wheel
hatchling
chardet
joblib
jsonpickle
matplotlib
more-itertools
numpy
requests
webcolors
- Then used it in the
shell.nix
file:
# shell.nix
pkgs = import <nixpkgs> {};
python = pkgs.python3.override {
self = python;
packageOverrides = pyfinal: pyprev: {
music21 = pyfinal.callPackage ./music21.nix { };
in pkgs.mkShell {
packages = [
(python.withPackages (python-pkgs: [
# select Python packages here
# ... more packages
python-pkgs.music21
- running
nix-shell
should install everything.
