I’m new to Nix/NixOS and trying to get to a point where I understand how things work. Right now I’m experimenting with use of flakes for both NixOS and Home Manager, in a multi-user configuration.
Below is the flake.nix I’m currently using, which appears to work well. However I have questions, to see if I’m understanding it properly, or missing anything.
I’m using nixpkgs-unstable, and I have home-manager.inputs.nixpkgs.follows = "nixpkgs", which I believe means it uses the nixpkgs.url I defined, and will also use nixpkgs-unstable, right?
Since I’m using flakes, this means both nixos-rebuild and home-manager updates will always pull from the same set of flake packages until I update the flake.lock file right? There is no possibility of either update command pulling in updates if I haven’t run nix flake lock --update-input nixpkgs right?
Who should own this flake.nix file? It points to the system configuration.nix, as well as each user’s home.nix. So far, testing with a single user, I have the user owning the file. This works fine as I have to run nix-rebuild as sudo anyway, and allows home-manager to update without sudo. But as this file contains more than just the info for one user, it seems like it should be owned by root. But that could create permission issues when I try to update home manager. I know giving root ownership of flake.lock means future lock updates require sudo. How to I keep the flake.nix/flake.lock files accessible without sudo, but not tied to a particular user’s ownership?
If you want a multi-user setup, I wouldn’t put every user’s home configuration in the system flake. Allow each user to control their own home-manager flake so they own their own files. Otherwise everyone needs sudo to update their home configs, and you have to have weird file permissions
Nix will automatically resolve the input from the registry. It does require users to also rebuild whenever you pull in a new version at the system level, so that’s a bit awkward. Maybe you could fix that with a homebrew nixos-rebuild that also rebuilds each users’ configuration.
This is VERY helpful, thanks! I don’t entirely understand what a flake registry is or where that gets setup (configuration.nix?) but I’ll try to do more reading. Using a separate flake per user is very promising!
It’s unusual in that not many people have multi-user systems. Personally I just use home-manager’s NixOS module to install my home-manager stuff with the rest of the system; convenient for single user setups, but obviously unworkable for you.
Yes, having every user use a different nixpkgs input version will waste some disk space. Potentially quite a bit of it, if they all have mismatching glibcs and a ton of software. That’s unfortunately one of the paper cuts you have to deal with by nix’s design; being able to use mismatching software versions between different users without system updates randomly breaking an individual users’ setup is a core part of the idea.
With non-flake systems the same thing happens, though, because the home-manager generations aren’t automatically updated anyway and will go out of sync over time.
In other words, if you’ve used this with channels before, you won’t notice much of an increase.
