Raspberry Pi 4B No USB in initrd with mainline kernel
Hello all,
I am trying to set up NixOS on a raspberry pi 4b with the mainline kernel booting from a USB. However, every single time, I get a message like “Timed out waiting for device…” or that relevant systemd mounting service failed. There’s no /dev/sd* in emergency shell, and I see in journalctl -xb that various USB devices are loaded from the hub. I’ve already ensured my EEPROM firmware is updated.
At the moment, I am trying to use U-Boot with systemd-boot, which is directly outputs an image file that is written to a USB stick. This gets me booting to initrd just fine. I’ve tried using the vendor kernel and systemd-boot successfully mounts the root partition, but the login prompt doesn’t show up. I’m not sure why it doesn’t finish successfully booting, but the point is that systemd-boot can see the USB drive with the vendor kernel unlike the mainline kernel. Thus, I must be missing some kernel module or device tree overlay that vendor kernel has that mainline doesn’t.
I’ve tried a lot of different modules, but general consensus seems to be that the kernel modules defined in nixos-hardware (usbhid, usb-storage, vc4, pcie-brcmstb, reset-raspberrypi) are enough. I don’t need the uas module since the storage device is a USB plugged into the raspberry pi directly and is not an enclosure.
I’ve spent a lot of time on this, but it seems that I shouldn’t be running into such problems (e.g., I had the same config as Eisfunke and was using the same UEFI firmware, but still ran into all the issues listed above, leading me to this config). I would appreciate any assistance!
Here are the relevant parts of my config:
{inputs, pkgs, lib, modulesPath, ...}: {
  imports = [
    inputs.nixos-hardware.nixosModules.raspberry-pi-4
    "${modulesPath}/profiles/minimal.nix"
  boot = {
    loader = {
      systemd-boot.enable = true;
      generic-extlinux-compatible.enable = false;
      efi.canTouchEfiVariables = false;
    initrd.systemd = {
      emergencyAccess = true;
    kernelPackages = lib.mkForce pkgs.linuxPackages_latest;
    blacklistedKernelModules = [
      # Disable wifi
      "brcmfmac"
      "brcmutil"
      # Disable bluetooth
      "btbmc"
      "hci_uart"
  console.enable = false;
    libraspberrypi
    raspberrypi-eeprom
  hardware.deviceTree = let
    # Using pinned firmware or else my HDMI doesn't work
    # See comment at https://git.eisfunke.com/config/nixos/-/blob/90b677e694dfccc079ce8d4d40b931082c9639d8/devices/amethyst.nix#L68
    # All CPUs come up in `journalctl -xb` without the mentioned overlay for me
    raspberrypifw = pkgs.raspberrypifw.overrideAttrs {
      version = "pinned-2023.05.12";
      src = pkgs.fetchFromGitHub {
        owner = "raspberrypi";
        repo = "firmware";
        rev = "b49983637106e5fb33e2ae60d8c15a53187541e4";
        hash = "sha256-Ia+pUTl5MlFoYT4TrdAry0DsoBrs13rfTYx2vaxoKMw=";
    dtbSource = pkgs.device-tree_rpi.override {inherit raspberrypifw;};
    name = "broadcom/bcm2711-rpi-4-b.dtb";
    overlays = let
      upstreamOverlay = name: raspberrypifw + /share/raspberrypi/boot/overlays/${name}.dtbo;
    in [
        name = "upstream-pi4";
        dtboFile = upstreamOverlay "upstream-pi4";
  facter.reportPath = ./facter.json;
  powerManagement.cpuFreqGovernor = "ondemand";
  services.jitterentropy-rngd.enable = true;
  boot.kernelModules = ["jitterentropy_rng"];
and I am generating the sd image used the repart module:
# Reference: https://github.com/MatthewCroughan/raspberrypi-nixos-example/blob/a4d2595b0839a7e7f1bc297dc9f006042d1d958d/repart.nix
{lib, config, pkgs, modulesPath, ...}: let
  efiArch = pkgs.stdenv.hostPlatform.efiArch;
  configTxt = pkgs.writeText "config.txt" ''
    [pi4]
    kernel=u-boot.bin
    enable_gic=1
    armstub=armstub8-gic.bin
    disable_overscan=1
    arm_boost=1
    [all]
    arm_64bit=1
    enable_uart=1
    avoid_warnings=1
  imports = [
    "${modulesPath}/image/repart.nix"
  systemd.repart.enable = true;
  systemd.repart.partitions."01-root".Type = "root";
  boot.initrd.systemd.root = "gpt-auto";
  boot.initrd.supportedFilesystems.ext4 = true;
  image.repart = {
    name = "image";
    partitions = {
      "01-esp" = {
        contents = {
          "/EFI/BOOT/BOOT${lib.toUpper efiArch}.EFI".source = "${pkgs.systemd}/lib/systemd/boot/efi/systemd-boot${efiArch}.efi";
          "/EFI/Linux/${config.system.boot.loader.ukiFile}".source = "${config.system.build.uki}/${config.system.boot.loader.ukiFile}";
          "/u-boot.bin".source = "${pkgs.ubootRaspberryPi4_64bit}/u-boot.bin";
          "/armstub8-gic.bin".source = "${pkgs.raspberrypi-armstubs}/armstub8-gic.bin";
          "/config.txt".source = configTxt;
          "/".source = "${pkgs.raspberrypifw}/share/raspberrypi/boot";
        repartConfig = {
          Type = "esp";
          Format = "vfat";
          Label = "ESP";
          SizeMinBytes = "512M";
      "02-root" = {
        storePaths = [config.system.build.toplevel];
        repartConfig = {
          Type = "root";
          Format = "ext4";
          Label = "nixos";
          Minimize = "guess";
          GrowFileSystem = true;
Additional notes:
  • I’ve thrown together the above snippets from my actual configuration, please let me know if there’s any mistakes, as I haven’t had any major problems with evaluating nor building. For example, I’ve excluded my systemd-network configuration
  • I also have a wireguard configuration in systemd-network and a systemd service for mounting at multi-user.target, but I don’t think either of these contribute to my issue
  • Perhaps the issue lies in whether the device tree is from systemd-boot (installed via boot.loader.systemd-boot.installDeviceTree since hardware.deviecTree.name is not null) or from U-Boot (firmware in ESP partition), but I don’t think that’s the issue since the HDMI doesn’t work without pinning raspberrypifw and overriding hardware.deviceTree.dtboSource with the pinned version, so systemd-boot device tree must be the one being used? (I’m not too well-versed in the boot process besides what I’ve learned from this week)
EDIT: I just realized that the image building process is using raspberrypifw from nixpkgs, but as stated above, the HDMI functionality is sensitive to the pinned version of raspberrypifw, so I don’t think this is the source of the problem. Plus, I’ve experienced this with the other UEFI firmware as well.
I found your post due to timeouts on my usb boot rpi4.
I got my Pi working by configuring what you described above and setting it in the hardware.nix file.
my currently booting line looks like this:
boot.initrd.availableKernelModules = [ “xhci_pci” “usbhid” “uas” “usb-storage” “vc4” “pcie-brcmstb” “reset-raspberrypi”];
But that said, you are already consuming nix-hardware, so this is uninteresting news for you but might help others finding this post via search.
Good luck!
