I’m having an issue with the Realtek 8125b network chipset on my MB. It worked fine in windows but when i swapped to nixos i started having connection issues. My connection is wired. Every 2 to 6 hours my connection just stops working. It says it’s fully connected but just drops all packets.
From what i can find online, it’s that I’m using the wrong driver (r8169) and it has issues supporting that chipset at the 2.5G link i have. I seen recommendation to use the r8125 driver but im not sure how i configure nixos to do this.
I’ve check the package search and it has bunch of entries for it. i just don’t know what i need to do in my configuration file to get it to use the right driver.
Update:
found how to install the driver, the connection issue still happens. have ordered a PCIe network card with an intel chipset. hopefully that works
