Hi,
I’ve tried to add ntfs support to my working just fine nixOS. As I’ve already had zfs support I’ve modifed the line:
boot.supportedFilesystems = [ "zfs" "ntfs" ];
However it didn’t work:
# nixos-rebuild switch --show-trace
building Nix...
/nix/store/1q4klhg04z38sz1ryqwhi6q9qnfmp2s6-stage-2-init.sh.drv
/nix/store/bjh7i791mi5j00qbhwiq647sdmkkyc55-system-path.drv
/nix/store/a2s4fx8rg0m4hx8gvyc1kyajyw4kqs81-dbus-1.drv
/nix/store/yxgqg4rmyvffc7jqa60zzyki3wdrs4l9-unit-dbus.service.drv
/nix/store/2anan8xp4lnhnywz9hd69in6868nvx8a-user-units.drv
/nix/store/4a10qm09k07mdzw6qx74by1avzirq00c-unit-dbus.service.drv
/nix/store/6y0dy2irad2fmzl7ywj6nyd21z5dgw61-unit-polkit.service.drv
/nix/store/s7nbbij84q5d6qficzddjniwclp8j4va-unit-systemd-fsck-.service.drv
/nix/store/ail4y79aqip0hfbsmz8i77l63rkrxiqq-system-units.drv
/nix/store/c0cvvlb9i5i49yv084wz3xmjki9mbjym-etc.drv
/nix/store/2f5z2m85wyldxxc5nnanj8k001lllqbn-nixos-system-nixos-19.09.941.27a5ddcf747.drv
these paths will be fetched (0.05 MiB download, 0.06 MiB unpacked):
/nix/store/4fv75rir86ddgqbg18vdg47b6bhyblm4-ntfs3g-2017.3.23-doc
/nix/store/5i84zmdzcykz1d3nkd86rlv0mpwgfywh-ntfs3g-2017.3.23-man
copying path '/nix/store/4fv75rir86ddgqbg18vdg47b6bhyblm4-ntfs3g-2017.3.23-doc' from 'https://cache.nixos.org'...
copying path '/nix/store/5i84zmdzcykz1d3nkd86rlv0mpwgfywh-ntfs3g-2017.3.23-man' from 'https://cache.nixos.org'...
building '/nix/store/1q4klhg04z38sz1ryqwhi6q9qnfmp2s6-stage-2-init.sh.drv'...
building '/nix/store/bjh7i791mi5j00qbhwiq647sdmkkyc55-system-path.drv'...
created 6225 symlinks in user environment
building '/nix/store/a2s4fx8rg0m4hx8gvyc1kyajyw4kqs81-dbus-1.drv'...
building '/nix/store/6y0dy2irad2fmzl7ywj6nyd21z5dgw61-unit-polkit.service.drv'...
building '/nix/store/s7nbbij84q5d6qficzddjniwclp8j4va-unit-systemd-fsck-.service.drv'...
building '/nix/store/4a10qm09k07mdzw6qx74by1avzirq00c-unit-dbus.service.drv'...
building '/nix/store/yxgqg4rmyvffc7jqa60zzyki3wdrs4l9-unit-dbus.service.drv'...
building '/nix/store/ail4y79aqip0hfbsmz8i77l63rkrxiqq-system-units.drv'...
building '/nix/store/2anan8xp4lnhnywz9hd69in6868nvx8a-user-units.drv'...
building '/nix/store/c0cvvlb9i5i49yv084wz3xmjki9mbjym-etc.drv'...
building '/nix/store/2f5z2m85wyldxxc5nnanj8k001lllqbn-nixos-system-nixos-19.09.941.27a5ddcf747.drv'...
mktemp: failed to create directory via template ‘initrd-secrets.XXXXXXXXXX’: Read-only file system
File "/nix/store/w2qf4b1gyb0bkk9r5vq0fnh27x3k047x-systemd-boot-builder.py", line 240, in <module>
main()
File "/nix/store/w2qf4b1gyb0bkk9r5vq0fnh27x3k047x-systemd-boot-builder.py", line 209, in main
write_entry(*gen, machine_id)
File "/nix/store/w2qf4b1gyb0bkk9r5vq0fnh27x3k047x-systemd-boot-builder.py", line 95, in write_entry
subprocess.check_call([append_initrd_secrets, "/boot%s" % (initrd)])
File "/nix/store/zqr5sy6dxnas41s0axyhhvlqnhwj0ywk-python3-3.7.5/lib/python3.7/subprocess.py", line 363, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/nix/store/fhc7by398nqhsrckxmwkib0yknpimf98-append-initrd-secrets/bin/append-initrd-secrets', '/boot/efi/nixos/hyka0zhzpcqrgvksq1brdah7fa0rs07s-initrd-linux-4.19.80-initrd.efi']' returned non-zero exit status 1.
Trying to remove that line caused:
building Nix...
main()
Unfortunately I rebooted the machine hoping to just use older generation, instead of that I’ve got one liner menu with:
"Reboot Into Firmware Interface"
Could someone elaborate what has happened?
Is there any chance to revive my system or should I revert it from my backups?
