Hey everyone, just signed up because I could not find anything whatsoever on this situation.
TLDR:
I updated nixos to 25.11 and tried to rebuild, and the package pkgs.kdePackages.plasma-vault fails to build, despite not being in the config anymore!
nix-store -l /nix/store/fn0vfg5016pypnpw8qwdrqqlv3f41gii-plasma-vault-6.5.4.drv
gives me:
Running phase: qtPreHook { “action”: “setPhase”, “phase”: “qtPreHook” }Running phase: unpackPhase { “action”: “setPhase”, “phase”: “unpackPhase” }unpacking source archive /nix/store/a5l24prgav03c2p2kv6ybq94yjvbvz94-plasma-vault-6.5.4.tar.xzsource root is plasma-vault-6.5.4separate-debug-info: recording checksum of source files for debug support…setting SOURCE_DATE_EPOCH to timestamp 1765274015 of file “plasma-vault-6.5.4/vim-extrarc”Running phase: patchPhase { “action”: “setPhase”, “phase”: “patchPhase” }applying patch /nix/store/c0c7dh4k1m4kb13ld1hhjp572h2q4ny5-hardcode-paths.patchpatching file kded/engine/backends/cryfs/cryfsbackend.cpppatching file kded/engine/backends/encfs/encfsbackend.cpppatching file kded/engine/backends/gocryptfs/gocryptfsbackend.cpppatching file kded/engine/fusebackend_p.cpppatching file kded/engine/vault.cppHunk #1 FAILED at 485.Hunk #2 succeeded at 546 (offset 8 lines).1 out of 2 hunks FAILED – saving rejects to file kded/engine/vault.cpp.rejpatching file kded/ui/cryfscypherchooserwidget.cpp
However, that’s only part of the issue.
I have then removed it from my configuration.nix, rebuilt, but it still fails with this error and on this package, despite it not even being in the config anymore??
I had some other packagaes that failed after updating to 25.11, which I didn’t need and just commented out, which solved it for the time being.
But not so with this one. What’s going on?
Edit: It’s not actually conclusively failing, it just stops after the error message until ended manually.
Is this intended? And how can I get to a buildable state again?
Let me know what other information is needed.
Thanks
