i meant to check if it was built in the nix cache, so that i could rule it being a me problem or a package problem. Since i’m building it not using nix cache, if the cache happend to be ok, then it was a me problem, if the cache was broken, it would be a packaging/versioning problem.
Beware, you are like the third person I hear of who is actually trying to build a full nixos system with musl libc, so this is very much not ready for prime time or ‘polished’ yet. Feel free to continue to try, but the go issue will not be the last one you run into, and upgrading your system will require significant time and effort because things are not tested against musl.
Guess i’ll be testing against musl, this will also be a great opportunity to learn more about nixOS
i went fedora → arch → gentoo → nixos, i like to learn new things and learned a lot with other distros, however I was facing 2 learning impairments with nixos:
after setting it up, it didn’t break, nor behaved unexpectedly after a update
after you learn the basics of configuring the system, you have no reason to understand what goes under the hood, why i rarely compile software in a source based distro? why flakes? how does it build a package from a file like 100 lines and not need any input from me?
those are the questions I was asking myself and honestly, can’t seem to get a good doc for nixos, it is scattered around the nixoswiki, nixpkgs reference manual, flake reference manual, nixos reference manual… They are full of info, but lacking in the conciseness and explanation departments
using musl to break stuff will teach me a lot, and will help me to give back to the community
