Can you elaborate on how you do that? I’m looking for a similar solution but I ended up using shell runner to be able to use the local nix store but its really bad for reproducibility…
My build machine runs NixOS and so I mount /nix
, /run/current-system
, /etc/ssl/certs/ca-bundle.crt:/etc/ssl/certs/ca-bundle.crt
and /etc/ssl/certs/ca-certificates.crt
from the host in the runner and then use a small alpine docker image built from this Dockerfile
FROM alpine:edge
RUN apk add bash curl
ENV \
ENV=/etc/profile \
TMP=/tmp \
NIX_REMOTE=daemon \
PATH=/run/current-system/sw/bin:/bin:/usr/bin \
GIT_SSL_CAINFO=/etc/ssl/certs/ca-certificates.crt \
NIX_SSL_CERT_FILE=/etc/ssl/certs/ca-certificates.crt
CMD ["/bin/bash", "-l"]
This is the part of my Gitlab Runner config.toml
that configures docker for this setup:
[runners.docker]
disable_cache = false
disable_entrypoint_overwrite = false
image = "lisberg/ci-host-nix"
oom_kill_disable = false
privileged = false
shm_size = 0
tls_verify = false
volumes = ["/nix:/nix", "/run/current-system:/run/current-system", "/etc/ssl/certs/ca-bundle.crt:/etc/ssl/certs/ca-bundle.crt", "/etc/ssl/certs/ca-certificates.crt:/etc/ssl/certs/ca-certificates.crt", "/cache"]
In my setup I also have a custom helper image but I don’t actually think that is needed any more so I have left it out. If you try to use this setup and you have problems with permissions you might need the custom helper image bit but I am pretty confident that it is no longer needed.
I’ve been lately exploring buildkite.com (free for open source) and I’m very happy with the results
- You can launch machines on an autoscaling group or in a single machine using NixOS
- Each machine is configured like this so that N agents run inside N systemd nspawn containters, and by default, all N nsspawn containers share the host /nix/store so it’s very shared and fast
- Builds are as fast as If I run them locally, the overhead of buildkite, the agents, and the nsspawn containers is imperceptible. I push and the jobs immediately start, all deps already cached, just delicious
@kamadorueda : Do you have an opensource reference how you use that?
