Remote building not working
I am trying to deploy my nixos configuration to a remote x86 machine from my aarch64 laptop.
  inputs.nixpkgs.url = "github:NixOS/nixpkgs/nixpkgs-unstable";
  outputs =
      nixpkgs,
      nixosConfigurations.rebuild= nixpkgs.lib.nixosSystem {
        system = "x86_64-linux";
        modules = [
          ./configuration.nix
          ./hardware-configuration.nix
However when I deploy using:
nixos-rebuild switch \
  --flake ".#rebuild" \
  --build-host james@192.168.1.253 \
  --target-host james@192.168.1.253 \
  --use-remote-sudo
I get the following error:
error: a 'x86_64-linux' with features {} is required to build '/nix/store/1gdwjhp6b5wv3d6s9333jp8i59w4prkb-nixos-rebuild.drv', but I am a 'aarch64-linux' with features {benchmark, big-parallel, gccarch-armv8-a, kvm, nixos-test}
This is obviously saying that my arm64 cpu doesn’t know how to build x86 packages however this doesn’t make sense as I have told it to offload the build (via --build-host above).
I must be missing something. Does anybody know what is going on here?
boot.binfmt.emulatedSystems = [ "x86_64-linux" ];
You could also try using the --fast flag which doesn’t rebuild nixos-rebuild before building your system.
@con-f-use I think this would build the packages locally and then copy them. I’m trying to perform a remote build so that it builds the packages on the remote system using it’s own nix store.
Please note that on macOS you also need to provide the --fast flag.
Does that flag help?
Yes --fast worked! Thank you :slight_smile:
