Ah, I think I somewhat understand what you meant, there this file /lib/pkgconfig/libfprint-2.pc in libfprint derivation which had the following contents
$ cat /nix/store/48b5w5isr70y14vx38nmbpjfz8ww3i5c-libfprint-1.94.6/lib/pkgconfig/libfprint-2.pc
prefix=/nix/store/48b5w5isr70y14vx38nmbpjfz8ww3i5c-libfprint-1.94.6
includedir=/nix/store/48b5w5isr70y14vx38nmbpjfz8ww3i5c-libfprint-1.94.6/include
libdir=${prefix}/lib
Description: Generic C API for fingerprint reader access
Version: 1.94.6
Requires: gio-unix-2.0 >= 2.56, gobject-2.0 >= 2.56
Libs: -L${libdir} -lfprint-2
Cflags: -I${includedir}/libfprint-2
Yes, the location is hardcoded in this, and copying it directly to my our derivation wonā't change it. Iāll test this out and let you know.
Let me know if that is what you were referring to.
Ah, I meant to look at the difference between those files. The unix CLI utility to do that is diff (I prefer diff -u) which is why thatās the colloquial term used to describe looking at the difference between two files.
The respective pkg-config files. Upstream distributes one and apparently the fprintd drv canāt make use of it (thatās what the error message implies).
Okay, so I updated the install phase to correctly add pkg-config file, the custome derivation didnāt contain one. I ensured that the paths lead to the custom derivation and not libfprint (which was the case when I simply copied all the files from libfprint derivation.
This time the libfprint-2 not found error didnāt show up. Instead a python module error was there, which I solved by adding the lib/girepository-1.0 from libfprint derivation. Also lib/pkgconfig/libfprint-2.pc file mentioned the header libraries include/ so I directly copied that to the custom derivation (along with libexec because it looked important (update: error message is same without libexec)).
Running nixos-rebuild switch, this time python error was also absent, but it hit an error during later in fprintd derivation.
which is mainly a bunch of reference errors to symbol g_usb_{some_variable_name}@LIBGUSB_0.1.0
Here is the diffoscope of the two derivations (libfprint and the custom one) generated with --exclude 'libfprint-2*' flag. This would exclude the .so library and some files in libexec. They are too verbose and I donāt believe are relevant. (diff file size is 3.3mb when zipped, 27mb unpacked)
[109/109] Linking target src/fprintd
FAILED: src/fprintd
gcc -o src/fprintd src/fprintd.p/meson-generated_.._fprintd-enums.c.o src/fprintd.p/meson-generated_.._fprintd-dbus-interactive.c.o src/fprintd.p/file_storage.c.o src/fprintd.p/main.c.o -Wl,--as-needed -Wl,--no-undefined -Wl,--start-group src/libfprintd-private.a /nix/store/sr6skahp2mvi6y8d4g89a9vwk4yh4z0p-glib-2.80.2/lib/libglib-2.0.so /nix/store/sr6skahp2mvi6y8d4g89a9vwk4yh4z0p-glib-2.80.2/lib/libgio-2.0.so /nix/store/sr6skahp2mvi6y8d4g89a9vwk4yh4z0p-glib-2.80.2/lib/libgobject-2.0.so -Wl,--export-dynamic /nix/store/sr6skahp2mvi6y8d4g89a9vwk4yh4z0p-glib-2.80.2/lib/libgmodule-2.0.so -pthread /nix/store/q528qpiby9fxlzf0f2y21885fsmdgyc8-libfprint-ft9366-1.94.4/lib/libfprint-2.so /nix/store/yv61rp99d3qzdlbx6x6z5n3ll7ksx744-polkit-124/lib/libpolkit-gobject-1.so -Wl,--end-group
/nix/store/q3sm4x963a996qc3d6baw54609ryifak-binutils-2.41/bin/ld: /nix/store/q528qpiby9fxlzf0f2y21885fsmdgyc8-libfprint-ft9366-1.94.4/lib/libfprint-2.so: undefined reference to `g_usb_interface_get_subclass@LIBGUSB_0.1.0'
/nix/store/q3sm4x963a996qc3d6baw54609ryifak-binutils-2.41/bin/ld: /nix/store/q528qpiby9fxlzf0f2y21885fsmdgyc8-libfprint-ft9366-1.94.4/lib/libfprint-2.so: undefined reference to `g_usb_interface_get_protocol@LIBGUSB_0.1.0'
/nix/store/q3sm4x963a996qc3d6baw54609ryifak-binutils-2.41/bin/ld: /nix/store/q528qpiby9fxlzf0f2y21885fsmdgyc8-libfprint-ft9366-1.94.4/lib/libfprint-2.so: undefined reference to `g_usb_device_get_interfaces@LIBGUSB_0.1.0'
/nix/store/q3sm4x963a996qc3d6baw54609ryifak-binutils-2.41/bin/ld: /nix/store/q528qpiby9fxlzf0f2y21885fsmdgyc8-libfprint-ft9366-1.94.4/lib/libfprint-2.so: undefined reference to `g_usb_interface_get_number@LIBGUSB_0.1.0'
/nix/store/q3sm4x963a996qc3d6baw54609ryifak-binutils-2.41/bin/ld: /nix/store/q528qpiby9fxlzf0f2y21885fsmdgyc8-libfprint-ft9366-1.94.4/lib/libfprint-2.so: undefined reference to `g_usb_device_get_release@LIBGUSB_0.1.0'
/nix/store/q3sm4x963a996qc3d6baw54609ryifak-binutils-2.41/bin/ld: /nix/store/q528qpiby9fxlzf0f2y21885fsmdgyc8-libfprint-ft9366-1.94.4/lib/libfprint-2.so: undefined reference to `g_usb_interface_get_class@LIBGUSB_0.1.0'
collect2: error: ld returned 1 exit status
ninja: build stopped: subcommand failed.
Full logs
@nix { "action": "setPhase", "phase": "unpackPhase" }
Running phase: unpackPhase
unpacking source archive /nix/store/xg9nw7ic88c7dnbwfx2avd38yjc7fcf7-source
source root is source
@nix { "action": "setPhase", "phase": "patchPhase" }
Running phase: patchPhase
applying patch /nix/store/hszpvhcafv7wx31z160vjw6k8h3w3pq9-ae04fa989720279e5558c3b8ff9ebe1959b1cf36.patch
patching file tests/pam/test_pam_fprintd.py
patching file tests/test_fprintd_utils.py
patching script interpreter paths in po/check-translations.sh tests/unittest_inspector.py
po/check-translations.sh: interpreter directive changed from "#!/bin/bash" to "/nix/store/516kai7nl5dxr792c0nzq0jp8m4zvxpi-bash-5.2p32/bin/bash"
tests/unittest_inspector.py: interpreter directive changed from "#! /usr/bin/env python3" to "/nix/store/h723hb9m43lybmvfxkk6n7j4v664qy7b-python3-3.11.9/bin/python3"
substituteStream() in derivation fprintd-1.94.2: WARNING: '--replace' is deprecated, use --replace-{fail,warn,quiet}. (file 'tests/fprintd.py')
@nix { "action": "setPhase", "phase": "updateAutotoolsGnuConfigScriptsPhase" }
@nix { "action": "setPhase", "phase": "configurePhase" }
Running phase: configurePhase
mesonConfigurePhase flags: --prefix=/nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2 --libdir=/nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/lib --libexecdir=/nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/libexec --bindir=/nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/bin --sbindir=/nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/sbin --includedir=/nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/include --mandir=/nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/share/man --infodir=/nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/share/info --localedir=/nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/share/locale -Dauto_features=enabled -Dwrap_mode=nodownload --buildtype=plain -Dgtk_doc=true -Dpam_modules_dir=/nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/lib/security -Dsysconfdir=/nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/etc -Ddbus_service_dir=/nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/share/dbus-1/system-services -Dsystemd_system_unit_dir=/nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/lib/systemd/system
e[1mThe Meson build systeme[0m
Version: 1.4.2
Source dir: e[1m/build/sourcee[0m
Build dir: e[1m/build/source/builde[0m
Build type: e[1mnative builde[0m
Project name: e[1mfprintde[0m
Project version: e[1m1.94.2e[0m
C compiler for the host machine: e[1mgcce[0m (gcc 13.2.0 "gcc (GCC) 13.2.0")
C linker for the host machine: e[1mgcce[0m ld.bfd 2.41
Host machine cpu family: e[1mx86_64e[0m
Host machine cpu: e[1mx86_64e[0m
Compiler for C supports arguments -fno-strict-aliasing: e[1;32mYESe[0m
Compiler for C supports arguments -Wcast-align: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=address: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=array-bounds: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=empty-body: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=implicit: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=init-self: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=int-to-pointer-cast: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=main: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=missing-braces: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=nonnull: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=pointer-to-int-cast: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=redundant-decls: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=return-type: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=sequence-point: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=trigraphs: e[1;32mYESe[0m
Compiler for C supports arguments -Werror=write-strings: e[1;32mYESe[0m
Compiler for C supports arguments -Wformat-nonliteral: e[1;32mYESe[0m
Compiler for C supports arguments -Wformat-security: e[1;32mYESe[0m
Compiler for C supports arguments -Wformat=2: e[1;32mYESe[0m
Compiler for C supports arguments -Wignored-qualifiers: e[1;32mYESe[0m
Compiler for C supports arguments -Wimplicit-function-declaration: e[1;32mYESe[0m
Compiler for C supports arguments -Wlogical-op: e[1;32mYESe[0m
Compiler for C supports arguments -Wmissing-declarations: e[1;32mYESe[0m
Compiler for C supports arguments -Wmissing-format-attribute: e[1;32mYESe[0m
Compiler for C supports arguments -Wmissing-include-dirs: e[1;32mYESe[0m
Compiler for C supports arguments -Wmissing-noreturn: e[1;32mYESe[0m
Compiler for C supports arguments -Wmissing-prototypes: e[1;32mYESe[0m
Compiler for C supports arguments -Wnested-externs: e[1;32mYESe[0m
Compiler for C supports arguments -Wold-style-definition: e[1;32mYESe[0m
Compiler for C supports arguments -Wpointer-arith: e[1;32mYESe[0m
Compiler for C supports arguments -Wshadow: e[1;32mYESe[0m
Compiler for C supports arguments -Wstrict-prototypes: e[1;32mYESe[0m
Compiler for C supports arguments -Wtype-limits: e[1;32mYESe[0m
Compiler for C supports arguments -Wundef: e[1;32mYESe[0m
Compiler for C supports arguments -Wunused: e[1;32mYESe[0m
Compiler for C supports arguments -Wno-unused-parameter: e[1;32mYESe[0m
Compiler for C supports arguments -Wno-pedantic: e[1;32mYESe[0m
Compiler for C supports arguments -DGLIB_VERSION_MIN_REQUIRED=GLIB_VERSION_2_56: e[1;32mYESe[0m
Compiler for C supports arguments -DGLIB_VERSION_MAX_ALLOWED=GLIB_VERSION_2_56: e[1;32mYESe[0m
Found pkg-config: e[1;32mYESe[0m e[1m(/nix/store/4lssw6pk59r654j0yrfydv0kngk8zrqp-pkg-config-wrapper-0.29.2/bin/pkg-config)e[0m e[1;34m0.29.2e[0m
Run-time dependency e[1mglib-2.0e[0m found: e[1;32mYESe[0m e[36m2.80.2e[0m
Run-time dependency e[1mgio-2.0e[0m found: e[1;32mYESe[0m e[36m2.80.2e[0m
Run-time dependency e[1mgio-unix-2.0e[0m found: e[1;32mYESe[0m e[36m2.80.2e[0m
Run-time dependency e[1mgmodule-2.0e[0m found: e[1;32mYESe[0m e[36m2.80.2e[0m
Run-time dependency e[1mlibfprint-2e[0m found: e[1;32mYESe[0m e[36m1.94.6e[0m
Run-time dependency e[1mpolkit-gobject-1e[0m found: e[1;32mYESe[0m e[36m124e[0m
Run-time dependency e[1mdbus-1e[0m found: e[1;32mYESe[0m e[36m1.14.10e[0m
Run-time dependency e[1mlibsystemde[0m found: e[1;32mYESe[0m e[36m255e[0m
Has header "e[1msecurity/pam_modules.he[0m" : e[1;32mYESe[0m
Library e[1mpame[0m found: e[1;32mYESe[0m
Program e[1mpod2mane[0m found: e[1;32mYESe[0m (/nix/store/5ydyzdwlar4ssmhfjg154dy2s2bbyhj3-perl-5.38.2/bin/pod2man)
Program e[1mxsltproce[0m found: e[1;32mYESe[0m (/nix/store/jb02zq14sa5fn52xcb82fhpwpnrv59rh-libxslt-1.1.39-bin/bin/xsltproc)
Run-time dependency e[1msystemde[0m found: e[1;32mYESe[0m e[36m255e[0m
Run-time dependency e[1mpam_wrappere[0m found: e[1;32mYESe[0m e[36m1.1.3e[0m
Program e[1mxmllinte[0m found: e[1;31mNOe[0m
Program e[1mpython3e[0m found: e[1;32mYESe[0m (/nix/store/h723hb9m43lybmvfxkk6n7j4v664qy7b-python3-3.11.9/bin/python3)
e[1;33mWARNING:e[0m You should add the boolean check kwarg to the run_command call.
It currently defaults to false,
but it will default to true in future releases of meson.
See also: https://github.com/mesonbuild/meson/issues/9300
Configuring e[1mconfig.he[0m using configuration
Program e[1mbashe[0m found: e[1;32mYESe[0m (/nix/store/516kai7nl5dxr792c0nzq0jp8m4zvxpi-bash-5.2p32/bin/bash)
Dependency e[1mgio-2.0e[0m found: e[1;32mYESe[0m e[36m2.80.2e[0m e[1;34m(cached)e[0m
Program e[1m/nix/store/f8y44c3k32piprp8wj999cdlakpz86kz-glib-2.80.2-dev/bin/gdbus-codegene[0m found: e[1;32mYESe[0m (/nix/store/f8y44c3k32piprp8wj999cdlakpz86kz-glib-2.80.2-dev/bin/gdbus-codegen)
Program e[1mpatche[0m found: e[1;32mYESe[0m (/nix/store/cjjaglbcsg30bc7rf6xajpp73fkna2mk-patch-2.7.6/bin/patch)
Dependency e[1mglib-2.0e[0m found: e[1;32mYESe[0m e[36m2.80.2e[0m e[1;34m(cached)e[0m
Program e[1m/nix/store/f8y44c3k32piprp8wj999cdlakpz86kz-glib-2.80.2-dev/bin/glib-mkenumse[0m found: e[1;32mYESe[0m (/nix/store/f8y44c3k32piprp8wj999cdlakpz86kz-glib-2.80.2-dev/bin/glib-mkenums)
Configuring e[1mnet.reactivated.Fprint.servicee[0m using configuration
Configuring e[1mfprintd.servicee[0m using configuration
Program e[1mmsgfmte[0m found: e[1;32mYESe[0m (/nix/store/zz3kckpl8ag09cr4qrlwi2q691ckqvgj-gettext-0.21.1/bin/msgfmt)
pam/meson.build:24: e[1;31mDEPRECATION:e[0m Project uses feature that was always broken, and is now deprecated since '1.3.0': str.format: Value other than strings, integers, bools, options, dictionaries and lists thereof..
Configuring e[1mversion.xmle[0m using configuration
Program e[1mgtkdoc-scane[0m found: e[1;32mYESe[0m (/nix/store/xgnn2g97kx2hynl1l7j9aspcjia6afcm-gtk-doc-1.34.0/bin/gtkdoc-scan)
Program e[1mgtkdoc-scangobje[0m found: e[1;32mYESe[0m (/nix/store/xgnn2g97kx2hynl1l7j9aspcjia6afcm-gtk-doc-1.34.0/bin/gtkdoc-scangobj)
Program e[1mgtkdoc-mkdbe[0m found: e[1;32mYESe[0m (/nix/store/xgnn2g97kx2hynl1l7j9aspcjia6afcm-gtk-doc-1.34.0/bin/gtkdoc-mkdb)
Program e[1mgtkdoc-mkhtmle[0m found: e[1;32mYESe[0m (/nix/store/xgnn2g97kx2hynl1l7j9aspcjia6afcm-gtk-doc-1.34.0/bin/gtkdoc-mkhtml)
Program e[1mgtkdoc-fixxrefe[0m found: e[1;32mYESe[0m (/nix/store/xgnn2g97kx2hynl1l7j9aspcjia6afcm-gtk-doc-1.34.0/bin/gtkdoc-fixxref)
Configuring e[1mfprintd-pam-teste[0m using configuration
e[1mMessage:e[0m Found library pam_wrapper as /nix/store/krs8ai3q6ki5jp69w6anz49f0l4hppvx-libpam-wrapper-1.1.3/lib/libpam_wrapper.so
tests/pam/meson.build:30: e[1;31mDEPRECATION:e[0m Project uses feature that was always broken, and is now deprecated since '1.3.0': str.format: Value other than strings, integers, bools, options, dictionaries and lists thereof..
Program e[1munittest_inspector.pye[0m found: e[1;32mYESe[0m (/build/source/tests/unittest_inspector.py)
Program e[1mvalgrinde[0m found: e[1;31mNOe[0m
Program e[1mmsginite[0m found: e[1;32mYESe[0m (/nix/store/zz3kckpl8ag09cr4qrlwi2q691ckqvgj-gettext-0.21.1/bin/msginit)
Program e[1mmsgmergee[0m found: e[1;32mYESe[0m (/nix/store/zz3kckpl8ag09cr4qrlwi2q691ckqvgj-gettext-0.21.1/bin/msgmerge)
Program e[1mxgettexte[0m found: e[1;32mYESe[0m (/nix/store/zz3kckpl8ag09cr4qrlwi2q691ckqvgj-gettext-0.21.1/bin/xgettext)
Program e[1mcheck-translations.she[0m found: e[1;32mYESe[0m (/build/source/po/check-translations.sh)
e[1mMessage:e[0m
System paths:
prefix: /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2
fprintd daemon directory: /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/libexec
fprintd modules directory: /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/lib/fprintd/modules
fprintd prints storage directory: /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/var/lib/fprint
DBus configuration directory: /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/share/dbus-1/system.d
DBus service directory: /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/share/dbus-1/system-services
DBus interfaces directory: /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/share/dbus-1/interfaces
Polkit policy directory: /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/share/polkit-1/actions
Systemd service directory: /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/lib/systemd/system
PAM module directory: /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/lib/security
Optional features:
PAM module: true
Manuals: true
GTK Doc: true
XML Linter false
Test setup:
With address sanitizer: false
Build targets in project: e[1m97e[0m
e[1mNOTICE:e[0m Future-deprecated features used:
* 0.56.0: {'dependency.get_pkgconfig_variable', 'meson.build_root', 'meson.source_root'}
e[1;33mWARNING:e[0m Broken features used:
* 1.3.0: {'str.format: Value other than strings, integers, bools, options, dictionaries and lists thereof.'}
fprintd e[36m1.94.2e[0m
e[1mUser defined optionse[0m
auto_features : enabled
bindir : /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/bin
buildtype : plain
includedir : /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/include
infodir : /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/share/info
libdir : /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/lib
libexecdir : /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/libexec
localedir : /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/share/locale
mandir : /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/share/man
prefix : /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2
sbindir : /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/sbin
sysconfdir : /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/etc
wrap_mode : nodownload
dbus_service_dir : /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/share/dbus-1/system-services
gtk_doc : true
pam_modules_dir : /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/lib/security
systemd_system_unit_dir: /nix/store/vny62l4vb85im29nxv7zkaz17iiybs0x-fprintd-1.94.2/lib/systemd/system
Found ninja-1.11.1 at /nix/store/j8ly6xc733w2wz98mz9avhy2bmibbcg9-ninja-1.11.1/bin/ninja
mesonConfigurePhase: enabled\ parallel\ building
@nix { "action": "setPhase", "phase": "buildPhase" }
Running phase: buildPhase
build flags: -j16
[1/109] Building translation po/af/LC_MESSAGES/fprintd-af.mo
[2/109] Building translation po/ar/LC_MESSAGES/fprintd-ar.mo
[3/109] Building translation po/as/LC_MESSAGES/fprintd-as.mo
[4/109] Building translation po/ast/LC_MESSAGES/fprintd-ast.mo
[5/109] Building translation po/az/LC_MESSAGES/fprintd-az.mo
[6/109] Building translation po/be/LC_MESSAGES/fprintd-be.mo
[7/109] Building translation po/bg/LC_MESSAGES/fprintd-bg.mo
[8/109] Building translation po/bn_IN/LC_MESSAGES/fprintd-bn_IN.mo
[9/109] Building translation po/ca/LC_MESSAGES/fprintd-ca.mo
[10/109] Building translation po/ca@valencia/LC_MESSAGES/fprintd-ca@valencia.mo
[11/109] Building translation po/cs/LC_MESSAGES/fprintd-cs.mo
[12/109] Building translation po/cy/LC_MESSAGES/fprintd-cy.mo
[13/109] Building translation po/da/LC_MESSAGES/fprintd-da.mo
[14/109] Building translation po/de/LC_MESSAGES/fprintd-de.mo
[15/109] Building translation po/en_GB/LC_MESSAGES/fprintd-en_GB.mo
[16/109] Building translation po/el/LC_MESSAGES/fprintd-el.mo
[17/109] Building translation po/eo/LC_MESSAGES/fprintd-eo.mo
[18/109] Building translation po/es/LC_MESSAGES/fprintd-es.mo
[19/109] Building translation po/et/LC_MESSAGES/fprintd-et.mo
[20/109] Building translation po/eu/LC_MESSAGES/fprintd-eu.mo
[21/109] Building translation po/fa/LC_MESSAGES/fprintd-fa.mo
[22/109] Building translation po/fi/LC_MESSAGES/fprintd-fi.mo
[23/109] Building translation po/fo/LC_MESSAGES/fprintd-fo.mo
[24/109] Building translation po/fr/LC_MESSAGES/fprintd-fr.mo
[25/109] Building translation po/ga/LC_MESSAGES/fprintd-ga.mo
[26/109] Building translation po/fur/LC_MESSAGES/fprintd-fur.mo
[27/109] Building translation po/gl/LC_MESSAGES/fprintd-gl.mo
[28/109] Building translation po/gu/LC_MESSAGES/fprintd-gu.mo
[29/109] Building translation po/he/LC_MESSAGES/fprintd-he.mo
[30/109] Building translation po/hi/LC_MESSAGES/fprintd-hi.mo
[31/109] Building translation po/hr/LC_MESSAGES/fprintd-hr.mo
[32/109] Building translation po/hu/LC_MESSAGES/fprintd-hu.mo
[33/109] Building translation po/ia/LC_MESSAGES/fprintd-ia.mo
[34/109] Building translation po/id/LC_MESSAGES/fprintd-id.mo
[35/109] Building translation po/it/LC_MESSAGES/fprintd-it.mo
[36/109] Building translation po/ja/LC_MESSAGES/fprintd-ja.mo
[37/109] Building translation po/ka/LC_MESSAGES/fprintd-ka.mo
[38/109] Building translation po/kk/LC_MESSAGES/fprintd-kk.mo
[39/109] Building translation po/kn/LC_MESSAGES/fprintd-kn.mo
[40/109] Building translation po/ko/LC_MESSAGES/fprintd-ko.mo
[41/109] Building translation po/ky/LC_MESSAGES/fprintd-ky.mo
[42/109] Building translation po/lt/LC_MESSAGES/fprintd-lt.mo
[43/109] Building translation po/lv/LC_MESSAGES/fprintd-lv.mo
[44/109] Building translation po/ml/LC_MESSAGES/fprintd-ml.mo
[45/109] Building translation po/mr/LC_MESSAGES/fprintd-mr.mo
[46/109] Building translation po/ms/LC_MESSAGES/fprintd-ms.mo
[47/109] Building translation po/nb/LC_MESSAGES/fprintd-nb.mo
[48/109] Building translation po/nl/LC_MESSAGES/fprintd-nl.mo
[49/109] Building translation po/nn/LC_MESSAGES/fprintd-nn.mo
[50/109] Building translation po/oc/LC_MESSAGES/fprintd-oc.mo
[51/109] Building translation po/or/LC_MESSAGES/fprintd-or.mo
[52/109] Building translation po/pa/LC_MESSAGES/fprintd-pa.mo
[53/109] Building translation po/pl/LC_MESSAGES/fprintd-pl.mo
[54/109] Building translation po/pt/LC_MESSAGES/fprintd-pt.mo
[55/109] Building translation po/pt_BR/LC_MESSAGES/fprintd-pt_BR.mo
[56/109] Building translation po/ro/LC_MESSAGES/fprintd-ro.mo
[57/109] Building translation po/ru/LC_MESSAGES/fprintd-ru.mo
[58/109] Building translation po/sk/LC_MESSAGES/fprintd-sk.mo
[59/109] Building translation po/sl/LC_MESSAGES/fprintd-sl.mo
[60/109] Building translation po/sq/LC_MESSAGES/fprintd-sq.mo
[61/109] Building translation po/sr/LC_MESSAGES/fprintd-sr.mo
[62/109] Building translation po/sr@latin/LC_MESSAGES/fprintd-sr@latin.mo
[63/109] Building translation po/sv/LC_MESSAGES/fprintd-sv.mo
[64/109] Building translation po/ta/LC_MESSAGES/fprintd-ta.mo
[65/109] Building translation po/te/LC_MESSAGES/fprintd-te.mo
[66/109] Building translation po/th/LC_MESSAGES/fprintd-th.mo
[67/109] Building translation po/tr/LC_MESSAGES/fprintd-tr.mo
[68/109] Building translation po/uk/LC_MESSAGES/fprintd-uk.mo
[69/109] Building translation po/vi/LC_MESSAGES/fprintd-vi.mo
[70/109] Building translation po/wa/LC_MESSAGES/fprintd-wa.mo
[71/109] Building translation po/zh_HK/LC_MESSAGES/fprintd-zh_HK.mo
[72/109] Building translation po/zh_CN/LC_MESSAGES/fprintd-zh_CN.mo
[73/109] Building translation po/zh_TW/LC_MESSAGES/fprintd-zh_TW.mo
[74/109] Generating data/man_pam_fprintd.8 with a custom command
[75/109] Generating doc/dbus/docbook_xml_header with a custom command (wrapped by meson because command contains newlines, to capture output)
[76/109] Generating data/man_fprintd.1 with a custom command
[77/109] Generating gdbus header src/fprintd-dbus.h
[78/109] Generating gdbus source src/fprintd-dbus.c
[79/109] Generating src/fprintd-dbus-interactive with a custom command
patching file src/fprintd-dbus-interactive.c (read from src/fprintd-dbus.c)
[80/109] Merging translations for data/net.reactivated.fprint.device.policy
[81/109] Generating GObject enum file src/fprintd-enums.h (wrapped by meson because command contains newlines, to capture output)
[82/109] Generating GObject enum file src/fprintd-enums.c (wrapped by meson because command contains newlines, to capture output)
[83/109] Generating doc/dbus/net.reactivated.Fprint.Manager_ref with a custom command (wrapped by meson to capture output)
[84/109] Generating doc/dbus/net.reactivated.Fprint.Device_ref with a custom command (wrapped by meson to capture output)
[85/109] Compiling C object pam/pam_fprintd.so.p/pam_fprintd.c.o
[86/109] Compiling C object src/libfprintd-private.a.p/meson-generated_.._fprintd-enums.c.o
[87/109] Compiling C object utils/fprintd-list.p/list.c.o
[88/109] Compiling C object utils/fprintd-verify.p/verify.c.o
[89/109] Compiling C object utils/fprintd-delete.p/delete.c.o
[90/109] Compiling C object utils/fprintd-enroll.p/enroll.c.o
[91/109] Compiling C object src/fprintd.p/meson-generated_.._fprintd-enums.c.o
[92/109] Linking target pam/pam_fprintd.so
[93/109] Generating tests/pam/services/pam_test_service_file with a custom command
[94/109] Compiling C object src/fprintd.p/file_storage.c.o
[95/109] Compiling C object src/libfprintd-private.a.p/manager.c.o
[96/109] Compiling C object src/fprintd.p/main.c.o
[97/109] Compiling C object src/libfprintd-private.a.p/device.c.o
[98/109] Compiling C object utils/fprintd-verify.p/meson-generated_.._.._src_fprintd-dbus-interactive.c.o
[99/109] Compiling C object utils/fprintd-delete.p/meson-generated_.._.._src_fprintd-dbus-interactive.c.o
[100/109] Compiling C object utils/fprintd-enroll.p/meson-generated_.._.._src_fprintd-dbus-interactive.c.o
[101/109] Compiling C object src/libfprintd-private.a.p/meson-generated_.._fprintd-dbus-interactive.c.o
[102/109] Linking static target src/libfprintd-private.a
[103/109] Compiling C object utils/fprintd-list.p/meson-generated_.._.._src_fprintd-dbus-interactive.c.o
[104/109] Compiling C object src/fprintd.p/meson-generated_.._fprintd-dbus-interactive.c.o
[105/109] Linking target utils/fprintd-enroll
[106/109] Linking target utils/fprintd-verify
[107/109] Linking target utils/fprintd-delete
[108/109] Linking target utils/fprintd-list
FAILED: src/fprintd
This is slightly tangential to what we have discussed till now.
I noticed the word ātodā on the github repo of debian file from which Iām building. Which made me think maybe I should refer other tod libfprint derivations. I referred to libfprint-2-tod1-elan
I went to its build source and got to know it is working just by copying a bare OEM .so shared object library file into its derivation (library file is already downloaded and unpacked from zip after fetch). And as per nix docs, all they need to do is in their configuration.nix file. NixOS Search
# Start the driver at boot
systemd.services.fprintd = {
serviceConfig.Type = "simple";
# Install the driver
services.fprintd.enable = true;
# If simply enabling fprintd is not enough, try enabling fprintd.tod...
services.fprintd.tod.enable = true;
# ...and use one of the next four drivers
services.fprintd.tod.driver = pkgs.libfprint-2-tod1-elan;
I tried to implement this as well. Here is my attempt
$ sudo fprintd-enroll
Impossible to enroll: GDBus.Error:net.reactivated.Fprint.Error.NoSuchDevice: No devices available
It feels like Iāve done something wrong in my life.
Update: Okay, thatās on the library, after inspecting journalctl -e | rg fprint here is what I found.
The error is libfprint-2-tod1-focaltech.so doesn't expose the required entry point symbol
nix-config on ī main [$!?]
⯠journalctl -e | rg fprint
Nov 07 20:06:05 seattle systemd[1]: fprintd.service: Deactivated successfully.
⯠sudo fprintd-enroll
[sudo] password for seattle:
nix-config on ī main [$!?] took 2s
Nov 07 20:06:50 seattle dbus-daemon[1458]: [system] Activating via systemd: service name='net.reactivated.Fprint' unit='fprintd.service' requested by ':1.61' (uid=1000 pid=3135 comm="/run/current-system/sw/bin/systemsettings" label="kernel")
Nov 07 20:06:50 seattle fprintd[3258]: Library /nix/store/s0xznywyzrwyc9r9rmazh48cvaiigbbj-libfprint-2-tod1-focaltech-0.0.1/lib/libfprint-2/tod-1/libfprint-2-tod1-focaltech.so doesn't expose the required entry point symbol
Nov 07 20:06:59 seattle sudo[3290]: seattle : TTY=pts/0 ; PWD=/home/seattle/nix-config ; USER=root ; COMMAND=/run/current-system/sw/bin/fprintd-enroll
tldr (of whole discourse): Iām too dumb. Sorry for so much trouble. Thank you for all the help. Here is the derivation which should work.
Apparently the derivation obtained at Request for libfprint port for 2808:a658 - #28 by imsick was totally fine. I didnāt notice the amd64 in downloaded debian file name, and worked under assumption that it is for my system. I updated the download link and hash to that of rpm file in the given download git repo, and now fingerprint sensor work as expected!
I tried the tod method, but that didnāt work. But okay, I find this message to be much more cleaner and better, and everything is good when it works.
Compiler for C supports arguments -Wtype-limits: YES
Compiler for C supports arguments -Wundef: YES
Compiler for C supports arguments -Wunused: YES
Compiler for C supports arguments -Wno-unused-parameter: YES
Compiler for C supports arguments -Wno-pedantic: YES
Compiler for C supports arguments -DGLIB_VERSION_MIN_REQUIRED=GLIB_VERSION_2_64: YES
Compiler for C supports arguments -DGLIB_VERSION_MAX_ALLOWED=GLIB_VERSION_2_64: YES
Found pkg-config: YES (/nix/store/2crk9xnq5x9v7yf0r2nwkgj8qsmxr4ly-pkg-config-wrapper-0.29.2/bin/pkg-config) 0.29.2
Run-time dependency glib-2.0 found: YES 2.84.1
Run-time dependency gio-2.0 found: YES 2.84.1
Run-time dependency gio-unix-2.0 found: YES 2.84.1
Run-time dependency gmodule-2.0 found: YES 2.84.1
Dependency libfprint-2 found: NO. Found 1.94.4 but need: '>=1.94.9'
Did not find CMake 'cmake'
Found CMake: NO
Run-time dependency libfprint-2 found: NO
meson.build:91:16: ERROR: Dependency lookup for libfprint-2 with method 'pkgconfig' failed: Invalid version, need 'libfprint-2' ['>=1.94.9'] found '1.94.4'.
pardon me if i am doing anything wrong, i dunno how this works.
This āerrorā is due to the fact that fprintd version in NixOS-25.05 was updated to v1.94.5, and the newer version of fprintd is not compatible with libfprint version <1.94.9
The compiled library which the developer of this focaltech fingerprint library provided is compiled against libfprint v1.94.4, hence the fprintd compilation fails here.
If you want to use fingerprint on NixOS-25.05 (or above), you will need either upgrade the package provided by dev (which is not straightforward as we donāt have the source code) or downgrade the libfprint version.
On a flake based system, you can achieve this by
# flake.nix
pinned-pkgs.url = "github:NixOS/nixpkgs/nixos-24.11";
# in output pass this as `specialArgs`
I havenāt tested it yet, but it looks particularly relevant to the FocalTech 2808:a658 / FT9366 sensor discussed here.
From what I understand, the project provides a compatibility shim for the proprietary FocalTech libfprint driver, addressing the libgusb ABI incompatibility with newer Linux systems. The author also reports NixOS compatibility.
Iām wondering if anyone here has already looked into this approach, or whether it could be a viable basis for bringing proper support back to nixpkgs.
Iām fairly new to Nixpkgs development, but Iād be interested in working on it myself if this is something that could realistically be packaged and submitted as a PR. I can also test it on actual 2808:a658 hardware.
If anyone with more experience packaging proprietary drivers / libfprint for nixpkgs could point me in the right direction, Iād be happy to give it a try.
