Running a `nix-shell` shebang script inside a derivation
I’m trying to run a nix-shell script inside a derivation like this:
postPatch = ''
  ${./python-script.py}
python-script.py:
#!/usr/bin/env nix-shell
#!nix-shell -i python3 -p python3
print("hello world")
But I’m getting a cannot execute: required file not found error, when building the derivation. The script runs just fine outside of the derivation.
What’s the right way to do this?
This wouldn’t work because /usr/bin/env is not available in the sandbox, and even if it (and nix-shell) does, you would need internet access and store access, which isn’t available easily.
Instead, you can omit the shebang and do something like this
postPatch = ''
  ${python3.interpreter} ${./python-script.py}
and if you need some python dependencies
postPatch = ''
  ${(python3.withPackages (p: [ p.tomli-w ])).interpreter} ${./python-script.py}
You can also just add python3 to nativeBuildInputs and use python3 instead of ${python3.interpreter}
