Running AP on Raspberry Pi
Greetings! I am trying to configure an access point on NixOS. This is my current config:
{ lib, pkgs, ... }:
  wifi = "wlan0";
  ipAddress = "10.23.45.1";
  prefixLength = 24;
  servedAddressRange = "10.23.45.2,10.23.45.150,12h";
  ssid = "palosiot";
  wifiPassword = "hovno134";
  # todo only open needed ports
  networking.firewall.trustedInterfaces = [ wifi ];
  networking.networkmanager.unmanaged = [ wifi ];
  networking.dhcpcd.denyInterfaces = [ wifi ];
  networking.interfaces."${wifi}".ipv4.addresses = [{
    address = ipAddress;
    prefixLength = prefixLength;
    services.hostapd = {
      interface = wifi;
      hwMode = "g";
      ssid = ssid;
      /* wpaPassphrase = wifiPassword; */
      wpa = false;
  services.dnsmasq = {
    extraConfig = ''
      # Only listen to routers' LAN NIC.  Doing so opens up tcp/udp port 53 to
      # localhost and udp port 67 to world:
      interface=${wifi}
      # Explicitly specify the address to listen on
      listen-address=${ipAddress}
      # Dynamic range of IPs to make available to LAN PC and the lease time.
      # Ideally set the lease time to 5m only at first to test everything works okay before you set long-lasting records.
      dhcp-range=${servedAddressRange}
The service seems to be fine. This is output of journalctl -ru hostapd.service:
-- Journal begins at Tue 1980-01-01 01:00:00 CET, ends at Thu 2022-03-17 17:46:20 CET. --
Mar 17 17:46:14 nixpi hostapd[1815]: wlan0: AP-ENABLED
Mar 17 17:46:14 nixpi hostapd[1815]: wlan0: interface state UNINITIALIZED->ENABLED
Mar 17 17:46:13 nixpi systemd[1]: Started hostapd wireless AP.
But no AP is detected by either my phone or laptop.
