I’m trying to set up a NixOS container from which to run docker images. The container isn’t able to start docker instances because:
Mar 04 22:03:23 docker-host docker[863]: /nix/store/jmxkz7wqs5ln1vlgsh8zd0hmqzxbcpgy-docker-19.03.5/libexec/docker/docker: Error response from daemon: OCI runtime create failed: container_linux.go:346: starting container process caused "process_linux.go:297: applying cgroup configuration for process caused \"mkdir /sys/fs/cgroup/cpuset/docker/54e82a476fb76089dcb9db0eacd7aa767da72752e6eb7ec96892499ac8ff8979: read-only file system\"": unknown.
This makes sense, letting containers create sub-containers seems a bit dangerous. Can that be overridden, though? Can I bindMount /sys/… rw? I don’t see any container options that seem promising, except ‘capabilities’, but it looks like those don’t cover container creation.
Is this possible?
